[信息] STC12C5A60S2的AD转换程序,还能变换采样的位数,不懂,特...
966|6
 楼主| elephant00 发表于 2021-4-21 11:39 | 显示全部楼层 |阅读模式
#include "SocAdc.h"
Software delay function
void Delay(uint16 n)
    uint16 x;
    while (n--)
        x = 5000;
        while (x--){;}
Get ADC result
uint16 GetAdcResult(uint8 ch)
    uint16 tmp = 0;  //无符号16位整型变量
    ADC_CONTR = ADC_POWER | ADC_SPEEDHH | ch | ADC_START;
    _nop_();                        //Must wait before inquiry
    _nop_();
    _nop_();
    _nop_();
    while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag
    //ADC_CONTR &= ~ADC_FLAG;         //Close ADC
    tmp = ADC_RES;  //A/D 转换结果高8位 ADCV.9 ADCV.8 ADCV.7 ADCV.6 ADCV.5 ADCV.4 ADCV.3 ADCV.2  0000,0000
    tmp <<= 2;  //等价于  tmp = tmp<< 2   ,左移2位
    tmp |= ADC_RESL;   //等价于tmp= ADC_RESL | tmp   按位或,       A/D 转换结果低2位                                           ADCV.1 ADCV.0  0000,0000
    return tmp;                 //Return ADC result    ,即输出一个采样点的二进制表示值
  函数名:AdcInit
  参  数:
  返回值:
  描  述:ADC初始化
void AdcInit()
    P1M1 = 0x0f;
    P1M0 = 0x00;
    P1ASF = 0x0f;                   //Open 8 channels ADC function
    AUXR1 &= (~0x04);
    ADC_RES = 0;                    //Clear previous result
    ADC_RESL = 0;
    ADC_CONTR = ADC_POWER | ADC_SPEEDHH;
    Delay(2);                       //ADC power-on and delay
  函数名:GetAdc10bit
  参  数:ucChannel = 通道(0~7)
  返回值:
  描  述:10位采样
uint16 GetAdc10bit(uint8 ucChannel)
    if (ucChannel > 7) {return 0;}
    GetAdcResult(ucChannel);    //切换后的第1次舍去
    return GetAdcResult(ucChannel);
  函数名:GetAdc12bit
  返回值:
  描  述:12位采样
uint16 GetAdc12bit(uint8 ucChannel)
    uint16 sum = 0;
    uint8 i = 0;
    for (i=0; i<4; i++)   //2^2    //10bit过采样到12bit(0~4095)
        sum += GetAdcResult(ucChannel);
    return (uint16)sum;
  函数名:GetAdc14bit
  返回值:
  描  述:14位采样
uint16 GetAdc14bit(uint8 ucChannel)
    uint16 sum = 0;
    uint8 i = 0;
    for (i=0; i<16; i++)   //2^4     //10bit过采样到14bit(0~16383)
    return (uint16)sum;
  函数名:GetAdc16bit
  返回值:
  描  述:16位采样
uint16 GetAdc16bit(uint8 ucChannel)
    uint16 sum = 0;
    uint8 i = 0;
    for (i=0; i<64; i++)   //2^6     //10bit过采样到16bit(0~65535)
    return (uint16)sum;
LcwSwust 发表于 2021-4-21 14:18 | 显示全部楼层
多次采样求和,就相当于位数提高了?
https://wenku.baidu.com/view/f89 ... 1ca300a7c3f643.html
wowu 发表于 2021-5-8 16:40 | 显示全部楼层
楼主想要问什么  题目不全
xiaoqizi 发表于 2021-5-8 16:40 | 显示全部楼层
好像可以选12或者10的
木木guainv 发表于 2021-5-8 16:42 | 显示全部楼层
确实是一个好办法
aoyi 发表于 2021-5-8 16:46 | 显示全部楼层
是想要提高精度?
drer 发表于 2021-5-8 16:46 | 显示全部楼层
治标不治本啊
