[应用相关] 雅特力AT32默认非GPIO的Pin如何设置为GPIO(FAQ0016)
4304|4
 楼主| onlycook 发表于 2021-5-10 16:27 | 显示全部楼层 |阅读模式
[url=]Questions[/url]如何将以下默认非GPIOPin设置为GPIO
OSC_IN               PD0
OSC_OUT           PD1
JTMS-SWDIO    PA13
JTCK-SWCLK     PA14
JTDI                   PA15
JTDO                 PB3
NJTRST             PB4
TAMPER-RTC    PC13
OSC32_IN         PC14
OSC32_OUT     PC15
Answer将以上IO设置为GPIO,需要开启对应GPIO时钟、开启复用时钟、将IO配置为输入/输出/复用功能、设置重映射、关闭入侵检测、关闭外部时钟等相应的操作。
1.         将OSC_IN、OSC_OUT设置为GPIO输出,需要设置如下:
//开启GPIOD时钟、开启复用时钟
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_GPIOD | RCC_APB2PERIPH_AFIO, ENABLE);
//关闭外部高速时钟
RCC_HSEConfig(RCC_HSE_DISABLE);
//设置PD0、PD1为推挽输出
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_0 | GPIO_Pins_1;
GPIO_InitStructure.GPIO_MaxSpeed = GPIO_MaxSpeed_2MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
//设置重映射 JTAG-DP Disabled and SW-DP Enabled
GPIO_PinsRemapConfig(GPIO_Remap_PTD01, ENABLE);
注:如果要使用PD0PD1,则时钟初始化时不用使能HSEPLL时钟源不能选择为HSE
2.         将SWJ设置为GPIO,例如将JTDI、JTDO、NJTRST设置为GPIO输出,需要设置如下:
//开启GPIOA、GPIOB时钟、开启复用时钟
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_GPIOA | RCC_APB2PERIPH_GPIOB | RCC_APB2PERIPH_AFIO, ENABLE);
//设置PA15、PB3、PB4为推挽输出
         GPIO_InitStructure.GPIO_Pins = GPIO_Pins_15;
       GPIO_Init(GPIOA, &GPIO_InitStructure);
       GPIO_InitStructure.GPIO_Pins = GPIO_Pins_3 | GPIO_Pins_4;
       GPIO_Init(GPIOB, &GPIO_InitStructure);
       GPIO_PinsRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
关于SWJ重映射说明:
/*!< Full SWJ Enabled (JTAG-DP + SW-DP) but without JTRST */
#define GPIO_Remap_SWJ_NoJNTRST     ((uint32_t)0x01000000)
/*!< JTAG-DP Disabled and SW-DP Enabled */
#define GPIO_Remap_SWJ_JTAGDisable  ((uint32_t)0x02000000)
/*!< Full SWJ Disabled (JTAG-DP + SW-DP) */
#define GPIO_Remap_SWJ_AllDisable   ((uint32_t)0x04000000)
3.         将TAMPER-RTC、OSC32_IN、OSC32_OUT设置为GPIO输出,需要设置如下:
//开启GPIOC时钟、开启备份接口时钟、开启电源接口时钟
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_GPIOC, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_BKP, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_PWR, ENABLE);
//关闭入侵检测和外部低速时钟
PWR_BackupAccessCtrl(ENABLE);
BKP_TamperPinCmd(DISABLE);       //关闭入侵检测
RCC_LSEConfig(RCC_LSE_DISABLE);   //关闭外部低速时钟
PWR_BackupAccessCtrl(DISABLE);
//设置PC13、PC14、PC15为推挽输出
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_13 | GPIO_Pins_14 | GPIO_Pins_15;
GPIO_Init(GPIOC, &GPIO_InitStructure);
注:如果要使用PC14PC15,则时钟初始化时不用使能LSE
类型:MCU 应用
适用型号:全系列(AT32F403, AT32F403A, AT32F413,AT32F415, AT32F407
主功能:GPIO
sky8023 发表于 2021-9-3 15:30 | 显示全部楼层
AT32F415 PC13 配置成输入模式。 BKP_TamperPinCmd(DISABLE);       //关闭入侵检测
宏定义没有开启。
数据采集存储 发表于 2021-9-8 10:44 | 显示全部楼层
学会一招,感谢楼主。
hoop 发表于 2021-9-9 09:09 | 显示全部楼层
宏定义没有开启。 ...
在415上,BKP不再是一个独立的IP,其与ERTC做在了一起,所以对应BKP相关的功能函数还请去at32f4xx_ertc.h里面找。
豌豆爹 发表于 2021-9-18 09:33 来自手机 | 显示全部楼层
学会一招,感谢楼主
