烧写成功了么
1559|8
 楼主| supernan 发表于 2021-6-15 21:56 | 显示全部楼层 |阅读模式
烧写, IO, ic, TI, AD, RS
Connecting to MPLAB PICkit 4...
Currently loaded versions:
Application version............00.02.01
FPGA version...................ff.ff.ff
Script version.................00.02.23
Script build number............45a591cbc0
Application build number.......0123456789
PICKit 4 is supplying power to the target (3.30 volts).
Target Device ID (0x6180) is an Invalid Device ID. Please check your connections to the Target Device.
Erasing...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x3f
program memory: start address = 0x7fc0, end address = 0x7fff
configuration memory
Programming/Verify complete
zyf部长 发表于 2021-6-15 21:58 | 显示全部楼层
还有什么现象?能再详细描述下吗?
 楼主| supernan 发表于 2021-6-15 22:02 | 显示全部楼层
Target Device ID (0x6180) is an Invalid Device ID. Please check your connections to the Target Device. 这个问题怎么解决
jiajs 发表于 2021-6-15 22:04 | 显示全部楼层
烧写OK了, 下面的提示选对LF 和F 就不用管,提示你别将LF(3.3)的芯片 选成了F(5)的。
jlyuan 发表于 2021-6-15 22:07 | 显示全部楼层
烧写OK了
juventus9554 发表于 2021-6-15 22:12 | 显示全部楼层
看看是不是接触不好
chuxh 发表于 2021-6-15 22:16 | 显示全部楼层
断电重插
renyaq 发表于 2021-6-15 22:19 | 显示全部楼层
你这是不管三七二十一烧进去了。可是工具提示你芯片不对啊,你希望是A,工具发现焊的是B呢
 楼主| supernan 发表于 2021-6-15 22:22 | 显示全部楼层
哦,那我就知道怎么回事了,多谢大家
