[无线通信] Routerboard DR5018 IPQ5018 wifi6 802.11ax wireless
1821|0
 楼主| wallysJane 发表于 2022-5-19 14:05 | 显示全部楼层 |阅读模式
QCN9074/QCN9024/QCN9072/IPQ6010/IPQ6018/IPQ6000/IPQ4029/IPQ4019/IPQ5018/IPQ8074A/IPQ8072A/QCA9880/QCA9882
Support 2x wifi6E card Wireless:On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/g/n/ax,max 23dBm per chain, 2x IPEX Connectors Dual-core ARM 64bit A53@1.0GHz Processor 512MB DDRL3L System Memory 4MB NOR Flash, 128MB NAND Flash 2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate Support BT5.1 Two PCIe2.0 connector can support QCN90xx production
WEB: https://www.wallystech.com/
Wallys Communications(SuZhou)Co.,Ltd
https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
