[其他产品] picsimlab 关于pic16f877A 无中断按键使用
648|0
 楼主| 磨砂 发表于 2022-6-13 15:31 | 显示全部楼层 |阅读模式
这次通过板上自带按键  RB3  和 RB4  完成
按下RB3  数字加一
按下RB4  数字减一
最大为9
最小为1
主函数 main.c
// PIC16F877A Configuration Bit Settings
// 'C' source line config statements
// CONFIG
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = ON         // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3/PGM pin has PGM function; low-voltage programming enabled)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
//__CONFIG(0xFF32);//??xc8?????????????
#include "lcd1602.h"
#define uchar unsigned char
#define uint  unsigned int
#define    K1   RB3
#define    K2   RB4
unsigned char Tempmin = '0'; //  最小问题
unsigned char Tempmax = '1'; //  最大问题
uchar kflag = 0;
uchar ge=1;//????
void delay_1ms(void)
    unsigned int n;
    for(n=0;n<50;n++)
    NOP();
void delay_ms(unsigned int time)
    for(;time>0;time--)
        delay_1ms();
void Key()
    if(K1&&K2)  // 按键没有按下
       kflag = 1;
    else  // 按键按下
       if(kflag == 1)
          kflag = 0;
          if(K1 == 0)
              if(++Tempmax >= '9')
                   Tempmax  = '9';
          if(K2 == 0)
              if(Tempmax > Tempmin+1)
                  --Tempmax;
void main()
    TRISB1=1;
    LCD1602_GPIO_Init(); //????1602?????
    LCD1602_init(); //1602?????
  while(1)
          DisplayListChar(0,0,"SPEED = ");
      //    Tempvalue =  ReadTemperature();
       //   Lcd_Display(7,1,Tempvalue);  //  显示温度值
         DisplayOneChar(8,0,Tempmax);    //  最高温度
          Key();                       //  按键程序
lcd1602.c
//???pmlab x??????????????gb2312??
lcd1602.c?lcd1602.h?????????????
DisplayListChar(unsigned charx, unsigned char y,unsigned char* str)???????
DisplayOneChar(unsigned charx, unsigned char y,unsigned char str)??????
x???y???ch?????'a'?str??????"i am a string"?
????????????lcd1602.h???#define??????
??lcd1602.c???void LCD1602_GPIO_Init(void)???????
#include <pic.h>           //??PIC16F87XA???????
//1602???????
void delay(void)
        int i;
        for (i = 0;i < 200;i++);
//???1602?????
void LCD1602_Write_Instruction(unsigned char combuf)
     Lcd_Date=combuf;     //??????RD???DB
     RS=0;                //???????
//     RW=0;                //?????
     E=0;
     delay();             //?????
     E=1;                 //E?????????1602??
     asm("NOP");          //????????????????1us
     E=0;                 //???????E???
//???1602?????
void LCD1602_Write_data(unsigned char databuf)
     Lcd_Date=databuf;    //??????RD???DB
     RS=1;                //???????
   //  RW=0;                //?????
     E=0;
     delay();             //?????
     E=0;                 //???????E???
//???1602???????
void LCD1602_init(void)
     LCD1602_Write_Instruction(0x38);  //8?????????????5*7????
     LCD1602_Write_Instruction(0x08);  //?????????
     LCD1602_Write_Instruction(0x01);  //??
     LCD1602_Write_Instruction(0x06);  //???????????????????
     LCD1602_Write_Instruction(0x0C);  //?????????
void DisplayOneChar(unsigned char X,unsigned char Y,const unsigned char DData)
    Y&=1;
    X&=15;
    if(Y)X|=0x40;               //?y?1???????????+0X40
    X|=0x80;                    //???????+0X80
    LCD1602_Write_Instruction(X);
    LCD1602_Write_data(DData);
void DisplayListChar(unsigned char X,unsigned char Y,const unsigned char *DData)
    unsigned char ListLength=0;
    Y&=0x01;
    X&=0x0f;
    while(X<16 && DData[ListLength])
        DisplayOneChar(X,Y,DData[ListLength]);
        ListLength++;
        X++;
    ADCON1=0X07;//??A?????????????????IO
    TRISE=0B11111001;      //RA5 RA2 RA3??
    TRISD=0B00000000;      //RD7-RD0??
    PORTA=0B00000000;      //???RA7-RA0???
    PORTD=0B00000000;      //???RD7-RD0???
lcd1602.h
#ifndef  __LCD1602_H
#define  __LCD1602_H
//1602????I/O??
#define E   RE1            //1602???E???RA3??
//#define RW  RW          //1602???RW???RA2??
#define RS  RE2           //1602???RS???RA5??
#define Lcd_Date PORTD     //LCD1602????
void delay(void);
void LCD1602_Write_Instruction(unsigned char combuf);
void LCD1602_Write_data(unsigned char databuf);
void LCD1602_init(void);
void DisplayOneChar(unsigned char X,unsigned char Y,const unsigned char DData);
void DisplayListChar(unsigned char X,unsigned char Y,const unsigned char *DData);
void LCD1602_GPIO_Init(void);
#endif
