STM8S参考指南上说:“没有使用的I/O引脚必须连接到一个固定的电平值。或者是上拉或者是下拉”。原话如下
Unused I/O pins must be connected to fixed voltage levels and configured as input floating.Either connect a pull-up or pull-down to the unused I/O pins, or use the internal weak pull-up if it is available on the pins.
但是,如果不用连接到一个固定的电平,就让该未用的腿配置为悬浮输入不知道行不行 |
