我想通过以下函数去实现TIM2定时器一次出两个通道脉冲,一次出单个通道脉冲,我用定时6每隔10ms去重新调用一下定时器2的配置,希望出现的单通道和双通道来回切换,但是从单通道切换到双通道的时候出现的波形不对,没有实现我的延时,而且出现两个脉冲
static void MX_TIM2_Init(uint8_t Flag_out)
/* USER CODE BEGIN TIM2_Init 0 */
/* USER CODE END TIM2_Init 0 */
if(Flag_out)
TIM_ClockConfigTypeDef sClockSourceConfig = {0};
TIM_MasterConfigTypeDef sMasterConfig = {0};
TIM_OC_InitTypeDef sConfigOC = {0};
/* USER CODE BEGIN TIM2_Init 1 */
/* USER CODE END TIM2_Init 1 */
htim2.Instance = TIM2;
htim2.Init.Prescaler = 35;
htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
htim2.Init.Period = 20000;
htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
Error_Handler();
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
Error_Handler();
if (HAL_TIM_OC_Init(&htim2) != HAL_OK)
Error_Handler();
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
Error_Handler();
sConfigOC.OCMode = TIM_OCMODE_TOGGLE;
sConfigOC.Pulse = Data_Pwm[1];
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
if (HAL_TIM_OC_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
Error_Handler();
sConfigOC.Pulse = Data_Pwm1[1];
if (HAL_TIM_OC_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN TIM2_Init 2 */
/* USER CODE END TIM2_Init 2 */
HAL_TIM_MspPostInit(&htim2);
__HAL_TIM_DISABLE_OCxPRELOAD(&htim2,TIM_CHANNEL_1);
__HAL_TIM_DISABLE_OCxPRELOAD(&htim2,TIM_CHANNEL_2);
HAL_TIM_OC_Start_DMA(&htim2, TIM_CHANNEL_1,Data_Pwm,2);
htim2.State = HAL_TIM_STATE_READY;
HAL_TIM_OC_Start_DMA(&htim2, TIM_CHANNEL_2,Data_Pwm1,2);
else
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
Error_Handler();
