收藏0 举报
#include "keyboard.h" /* * @Description: 初始化 矩阵按键的I/O口 * @param 1 – 参数 1:无 * [url=home.php?mod=space&uid=266161]@return[/url] – 返回值:无 */ void Keyboard_GPIO_Config(void) { GPIO_InitTypeDef GPIO_InitStruct; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //LINE GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOA, &GPIO_InitStruct); //ROW GPIO_InitStruct.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPU; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz; GPIO_Init(GPIOA, &GPIO_InitStruct); } /* * @Description: 矩阵按键扫描函数 * @param 1 – *key_val:存储 当前按键的数值 * @return – 返回值:无 */ void keyboard_scan(u16 *key_val) { uint16_t temp=0; GPIOA->ODR=0X00; GPIOA->ODR=0XF7; if((GPIOA->IDR&0XF0)!=0XF0){ delay_ms(10); if((GPIOA->IDR & 0XF0)!=0XF0){ temp=(GPIOA->IDR&0XF7); switch(temp){ case 0xE7: *key_val = 13; break; case 0xD7: *key_val = 14; break; case 0xB7: *key_val = 15; break; case 0x77: *key_val = 16; break; default: *key_val = 0; break; } }while((GPIOA->IDR&0XF7) != 0XF7); } GPIOA->ODR=0X00; GPIOA->ODR=0XFB; if((GPIOA->IDR&0XF0)!=0XF0){ delay_ms(10); if((GPIOA->IDR & 0XF0)!=0XF0){ temp=(GPIOA->IDR&0XFB); switch(temp){ case 0xEB: *key_val = 9; break; case 0xDB: *key_val = 10; break; case 0xBB: *key_val = 11; break; case 0x7B: *key_val = 12 ; break; default: *key_val = 0; break; } }while((GPIOA->IDR&0XFB) != 0XFB); } GPIOA->ODR=0X00; GPIOA->ODR=0XFD; if((GPIOA->IDR&0XF0)!=0XF0){ //GPIOA->IDR:读取置1的IO口,这里就是读取 PA7-PA4管脚的电平 delay_ms(10); if((GPIOA->IDR & 0XF0)!=0XF0){ temp=(GPIOA->IDR&0XFD); switch(temp){ case 0xED: *key_val = 5; break; case 0xDD: *key_val = 6; break; case 0xBD: *key_val = 7; break; case 0x7D: *key_val = 8; break; default: *key_val = 0; break; } }while((GPIOA->IDR&0XFD) != 0XFD); } GPIOA->ODR=0X00; GPIOA->ODR=0XFE; if((GPIOA->IDR&0XF0)!=0XF0){ delay_ms(10); if((GPIOA->IDR & 0XF0)!=0XF0){ temp=(GPIOA->IDR&0XFE); switch(temp){ case 0xEE: *key_val = 1; break; case 0xDE: *key_val = 2; break; case 0xBE: *key_val = 3; break; case 0x7E: *key_val = 4; break; default: *key_val = 0; break; } }while((GPIOA->IDR&0XFE) != 0XFE); } } /* * @Description: 返回自定义按键数值 * @param 1 – 参数 1:无 * @return – count:按键数值 */ u16 fetch_key_value(void){ u16 key = 0,count = 22; keyboard_scan(&key); switch(key){ case 0: // 没有按键按下时 count = 22; break; case 1: // S1 count = 1; break; case 2: // S2 count = 2; break; case 3: // S3 count = 3; break; case 4: // S4 count = 17; break; case 5: // S5 count = 4; break; case 6: // S6 count = 5; break; case 7: // S7 count = 6; break; case 8: // S8 count = 18; break; case 9: // S9 count = 7; break; case 10: // S10 count = 8; break; case 11: // S11 count = 9; break; case 12: // S12 count = 12; break; case 13: // S13 count = 13; break; case 14: // S14 count = 0; break; case 15: // S15 count = 15; break; case 16: // S16 count = 16; break; }return count; }
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
142
1593
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
