最近在使用FreeRTOS的任务消息功能替代事件组,遇到一个毫无头绪的问题:当在中断函数中置位任务消息osSignalSet(TaskHandle,1);时会导致osEvent ReadEvent = osSignalWait(2,100);退出等待状态。仿真调试此时的ReadEvent.value.v=1,但是osSignalWait(2,100);却并没有阻塞100毫秒,不知是何原因?请大神们指教!
以下我附上我的源码:
#define CPL_U3TX_SIG 0x00000001u
#define ACK_U3TX_SIG 0x00000002u
- void StartTaskAndroidTx(void const * argument)
- MyDataStruct_t *tx_buffer;
- osSignalSet(AndroidTxHandle,CPL_U3TX_SIG);//osSemaphoreRelease(myBinarySemU3TxHandle);
- /* Infinite loop */
- for(;;)
- if (pdPASS==xQueueReceive(U3TxQueueHandle, (uint8_t*)&tx_buffer, osWaitForever))
- if (NULL!=tx_buffer) {
- uint8_t data_len=tx_buffer->length;
- if (0!=data_len) {
- osEvent ReadEvent;
- osSignalWait(CPL_U3TX_SIG,100);
- osSignalWait(ACK_U3TX_SIG,0);
- memcpy(DMA_USART3_TxBuf,tx_buffer->DatArea,data_len);
- vPortFree((uint8_t*)tx_buffer);
- for (int i = 0; i < 10; ++i) {
- LCD_RS485_DE=LCD_RS485_RE=1;
- LL_DMA_DisableStream(DMA1,LL_DMA_STREAM_3);
- LL_DMA_SetDataLength(DMA1,LL_DMA_STREAM_3,data_len);
- LL_DMA_EnableStream(DMA1,LL_DMA_STREAM_3);
- ReadEvent = osSignalWait(ACK_U3TX_SIG,100);
- if (ReadEvent.value.v & ACK_U3TX_SIG)break;
- else vPortFree((uint8_t*)tx_buffer);
以下为中断中发送任务消息:- void DMA1_Stream3_IRQHandler(void)
- /* USER CODE BEGIN DMA1_Stream3_IRQn 0 */
- if (LL_DMA_IsEnabledIT_TC(DMA1,LL_DMA_STREAM_3)!=RESET && LL_DMA_IsActiveFlag_TC3(DMA1) != RESET)
- LL_DMA_ClearFlag_TC3(DMA1);
- /* USER CODE END DMA1_Stream3_IRQn 0 */
- /* USER CODE BEGIN DMA1_Stream3_IRQn 1 */
- /* USER CODE END DMA1_Stream3_IRQn 1 */
当DMA传输完成后置位“CPL_U3TX_SIG”任务消息,此时任务中ReadEvent = osSignalWait(ACK_U3TX_SIG,100);也退出等待了,我的本意是要收到ACK_U3TX_SIG消息才退出阻塞
