[技术问答] 请教下HC32F460读SHT30,实在是搞不定了。
3480|18
 楼主| starry1028 发表于 2024-11-18 18:42 | 显示全部楼层 |阅读模式
HC32F460  模拟I2C 读SHT30,实在是搞不定了。那位大佬做过类似的,可以参考下吗?
suncat0504 发表于 2024-11-19 10:18 | 显示全部楼层
建议你先用Arduino搞通,然后对比时序信号。主要侧重于脉冲周期、ACK/NACK上。
wang369 发表于 2024-11-19 13:42 | 显示全部楼层
你先试一下你的模拟IIC信号是否对?基本就是时序周期等一类的问题
qinlu123 发表于 2024-11-19 15:51 | 显示全部楼层
要不我给你个SHT30的驱动
qinlu123 发表于 2024-11-19 16:01 | 显示全部楼层
下边是I2C.c
#include "I2C.h"
#define Delay_Time 2
void I2C_delay_nus(uint16_t time)
   uint8_t i=0;
   while(time--)
      i=1;
      while(i--) ;
static void Set_I2C1_SCL(uint8_t a)
    if(a!=0)
        PHout(5)=1;
    else
        PHout(5)=0;
static void Set_I2C1_SDA(uint8_t a)
    if(a!=0)
        PAout(4)=1;
    else
        PAout(4)=0;
static uint8_t Get_I2C1_SDA(void)
    return PAin(4);
static void Set_I2C2_SCL(uint8_t a)
    if(a!=0)
        PBout(7)=1;
    else
        PBout(7)=0;
static void Set_I2C2_SDA(uint8_t a)
    if(a!=0)
        PBout(8)=1;
    else
        PBout(8)=0;
static uint8_t Get_I2C2_SDA(void)
    return PBin(8);
static void Set_I2C3_SCL(uint8_t a)
    if(a!=0)
        PEout(2)=1;
    else
        PEout(2)=0;
static void Set_I2C3_SDA(uint8_t a)
    if(a!=0)
        PEout(3)=1;
    else
        PEout(3)=0;
static uint8_t Get_I2C3_SDA(void)
    return PEin(3);
struct I2C_Device I2C_1=
    .Set_SDA = Set_I2C1_SDA,
    .Set_SCL = Set_I2C1_SCL,
    .Get_SDA = Get_I2C1_SDA,
    .delayus = I2C_delay_nus
struct I2C_Device I2C_2=
    .Set_SDA = Set_I2C2_SDA,
    .Set_SCL = Set_I2C2_SCL,
    .Get_SDA = Get_I2C2_SDA,
struct I2C_Device I2C_3=
    .Set_SDA = Set_I2C3_SDA,
    .Set_SCL = Set_I2C3_SCL,
    .Get_SDA = Get_I2C3_SDA,
    IIC Driver
void I2C_Start(struct I2C_Device *IIcBus)
    IIcBus->Set_SDA(1);
    IIcBus->delayus(Delay_Time);
    IIcBus->Set_SCL(1);
    IIcBus->Set_SDA(0);
    IIcBus->Set_SCL(0);
void I2C_Stop(struct I2C_Device *IIcBus)
    IIcBus->Set_SDA(0);
    IIcBus->Set_SCL(1);
    IIcBus->Set_SDA(1);
uint8_t Receive_ACK(struct I2C_Device *IIcBus)
    uint32_t i;
    IIcBus->Set_SCL(0);//一定把时钟设为低电平再释放总线等待ACK
    IIcBus->Set_SDA(1);//释放总线
    while(IIcBus->Get_SDA()!=0)
        i++;
        if(i>10)
            return 0;
    IIcBus->Set_SCL(1);
    IIcBus->Set_SCL(0);
    return 1;
void I2C_WriteOneByte(struct I2C_Device *IIcBus,uint8_t Write_Data)
    uint8_t i;
    uint8_t Data=0;
    Data=Write_Data;
    for(i=0;i<8;i++)
        IIcBus->Set_SDA(Data & 0x80);
        IIcBus->Set_SCL(1);
        IIcBus->Set_SCL(0);
        Data <<= 1;
/**************Send ACK**************/
void I2C_SendACK(struct I2C_Device *IIcBus)
    IIcBus->Set_SCL(0);
    IIcBus->Set_SDA(0);//发送ACK
    IIcBus->Set_SCL(1);//拉高时钟线再拉低时钟线完成一个读周期
    IIcBus->Set_SCL(0);//空闲时保证时钟线为低
    IIcBus->Set_SDA(1);//发送完ACK后释放总线
void I2C_SendNACK(struct I2C_Device *IIcBus)
    IIcBus->Set_SCL(0);
    IIcBus->Set_SCL(1);
    IIcBus->Set_SCL(0);
uint8_t I2C_ReadOneByte(struct I2C_Device *IIcBus,uint8_t Ack)
    uint8_t i;
    uint8_t Data=0;
    for(i=0;i<8;i++)
      Data <<= 1;
        IIcBus->Set_SCL(0);
        IIcBus->Set_SCL(1);
        if(IIcBus->Get_SDA())
            Data++;
    IIcBus->Set_SCL(0);
    if(Ack)
        I2C_SendACK(IIcBus);
    else
        I2C_SendNACK(IIcBus);
    return Data;
下边是I2C.h
#ifndef __IIC_H
#define __IIC_H
#include "Header.h"
struct I2C_Device
    void (*Set_SDA)(uint8_t a);
    void (*Set_SCL)(uint8_t a);
    uint8_t (*Get_SDA)(void);
    void (*delayus)(uint16_t us);
extern struct I2C_Device I2C_1,I2C_2,I2C_3;
void I2C_delay_nus(uint16_t time);
void I2C_Start(struct I2C_Device *IIcBus);
void I2C_Stop(struct I2C_Device *IIcBus);
uint8_t Receive_ACK(struct I2C_Device *IIcBus);
void I2C_WriteOneByte(struct I2C_Device *IIcBus,uint8_t Write_Data);
void I2C_SendACK(struct I2C_Device *IIcBus);
void I2C_SendNACK(struct I2C_Device *IIcBus);
uint8_t I2C_ReadOneByte(struct I2C_Device *IIcBus,uint8_t Ack);
#endif
下边是SHT3x.c
#include "Sht3x.h"
struct sht3xObj sht31_1 =
    .HardWare = &I2C_1
struct sht3xObj sht31_2 =
    .HardWare = &I2C_2
static uint8_t sht31_mode_set(struct sht3xObj *PARA, uint8_t mode_h,uint8_t mode_l)
    I2C_Start(PARA->HardWare);
    I2C_WriteOneByte(PARA->HardWare,SHT31_RHT_W);
    if(Receive_ACK(PARA->HardWare)!=1)
        return 0;
    I2C_WriteOneByte(PARA->HardWare,Mode_Set_H);
        return 0;
    I2C_WriteOneByte(PARA->HardWare,Mode_Set_L);
        return 0;
    I2C_Stop(PARA->HardWare);
    return 1;
uint8_t soft_reset_sensor(struct sht3xObj *PARA)
        return 0;
  I2C_WriteOneByte(PARA->HardWare,RESET_SET_H);
    return 0;
  I2C_WriteOneByte(PARA->HardWare,RESET_SET_L);
    return 0;
  return 1;
uint8_t StartReadRHTemperature(struct sht3xObj *PARA)
      return 0;
    I2C_WriteOneByte(PARA->HardWare,0xE0);
      return 0;
    I2C_WriteOneByte(PARA->HardWare,0x00);
      return 0;
    return 1;
uint8_t sht31ReadRHTemperature(struct sht3xObj *PARA)
    uint8_t   T_Data_MSB, T_Data_LSB, RH_Data_MSB, RH_Data_LSB;
    uint8_t   CRC8_1, CRC8_2;
    uint16_t  data_t, data_rh;
    I2C_WriteOneByte(PARA->HardWare,SHT31_RHT_R);
        return 0;
    T_Data_MSB = I2C_ReadOneByte(PARA->HardWare,ACK);
    T_Data_LSB = I2C_ReadOneByte(PARA->HardWare,ACK);
    CRC8_1 = I2C_ReadOneByte(PARA->HardWare,ACK);
    RH_Data_MSB = I2C_ReadOneByte(PARA->HardWare,ACK);
    RH_Data_LSB = I2C_ReadOneByte(PARA->HardWare,ACK);
    CRC8_2 = I2C_ReadOneByte(PARA->HardWare,NACK);
    data_rh = (RH_Data_MSB<<8)|(RH_Data_LSB);
    PARA->Humidty = 100*((float)data_rh/65535);
    data_t = (T_Data_MSB<<8)|(T_Data_LSB);
    PARA->Temperture = -45 + 175*((float)data_t/65535);
    return 1;
void sht31_thread(struct sht3xObj *PARA)
    switch(PARA->RH_Status)
    case 0:
            if(CheckDelay(&PARA->Delay_Time)==0)
                if(sht31_mode_set(PARA,Mode_Set_H,Mode_Set_L) != 0)
                    PARA->RH_Status++;
                else
                    Set_Delay_Time(1500,&PARA->Delay_Time);
    }break;
        case 1://启动温湿度检测
        if(StartReadRHTemperature(PARA)!=0)
                    Set_Delay_Time(1000,&PARA->Delay_Time);
                    PARA->RH_Read_Time = 0;
                    PARA->RH_Status++;
        else
          PARA->RH_Read_Time++;
                    Set_Delay_Time(100,&PARA->Delay_Time);
          if(PARA->RH_Read_Time > 5)
            PARA->RH_Status = 0;
        }break;
        case 2:
                if(sht31ReadRHTemperature(PARA) != 0)
                    PARA->RH_Status = 1;
                else
        }break;
        default:
        }break;
下边是sht3x.h
#ifndef __SHT3X__H__
#define __SHT3X__H__
#include "I2C.h"
#include "Header.h"
#include "Delay.h"
#define ACK 1
#define NACK 0
#define SHT31_RHT_W   0X88
#define SHT31_RHT_R   0X89
//#define SHT31_RHT_W   0X8C
//#define SHT31_RHT_R   0X8D
//MODE COMMAND
#define Mode_Set_H    0x21
#define Mode_Set_L    0x2D
//SOFTRESET COMMAND
#define RESET_SET_H   0x30
#define RESET_SET_L   0xA2
struct sht3xObj
    uint16_t Delay_Time;//别忘了需要被DelayTimeCount_ms
    struct I2C_Device *HardWare;
  uint16_t   adc_t;
  uint16_t   adc_rh;
    float   Temperture;
    float   Humidty;
    uint8_t Status;
    uint8_t RH_Status;
    uint8_t RH_Read_Time;
extern struct sht3xObj sht31_1,sht31_2;
void sht31_thread(struct sht3xObj *PARA);
#endif
下边是用到的延时函数
void DelayTimeCount_ms(uint16_t *DelayTime_Count)
    if(*DelayTime_Count==0)
        *DelayTime_Count=0;
    else
        *DelayTime_Count-=1;
void Set_Delay_Time(uint16_t Time,uint16_t *DelayTime_Count)
    *DelayTime_Count=Time;
uint8_t CheckDelay(uint16_t *DelayTime_Count)
        return 0;
    else
        return 1;
下边是函数调用
#include "TaskMgr.h"
uint8_t Sys_Status=0;
uint16_t Item_OverTime_Count=0;
uint16_t TimeTick_Count=0;
uint8_t Task_1ms_EN=0,Task_2ms_EN=0,Task_5ms_EN=0,Task_10ms_EN=0,Task_20ms_EN=0,Task_50ms_EN=0,Task_100ms_EN=0,Task_500ms_EN=0,Task_1000ms_EN=0,Task_5000ms_EN=0;
uint8_t TCL=0;
static void SysTimeTikeCounting(void)
    TCL = 1;
    if(TimeTick_Count>60000)
        TimeTick_Count=1;
    else
        TimeTick_Count++;
static void Task_1ms(void)
    TimeCountReceive(&U_D_Uart1);
    DelayTimeCount_ms(&MS8607_Para_1.PT_Thread_Time);
    DelayTimeCount_ms(&MS8607_Para_2.PT_Thread_Time);
    DelayTimeCount_ms(&RS485BusSilentTime1);
    DelayTimeCount_ms(&MMDPort1.DelayTime);
    DelayTimeCount_ms(&PTQ3040.DelayTime);
    DelayTimeCount_ms(&sht31_1.Delay_Time);
    DelayTimeCount_ms(&sht31_2.Delay_Time);
    SmiTimeCount();
static void Task_2ms(void)
static void Task_5ms(void)
static void Task_10ms(void)
static void Task_20ms(void)
static void Task_50ms(void)
    ReadEleSensorInformationWhenBooting();
static void Task_100ms(void)
static void Task_500ms(void)
static void Task_1000ms(void)
    GetDS18B20Data(&DS18B20_1);
//  GetDS18B20Data(&DS18B20_2);
//  GetDS18B20Data(&DS18B20_3);
//  GetDS18B20Data(&DS18B20_4);
    ReadEleSensorValueEnable();
    ReadLSPMValueEnable();
    ReadWSEnable();
    ReadWDEnable();
    PTQModeSetEnable();
    PTQReadEnable();
static void Task_5000ms(void)
static void TaskPolls(void)
    if(TCL)
        TCL = 0;
        if((TimeTick_Count%1)==0)
            Task_1ms_EN=1;
        if((TimeTick_Count%2)==0)
            Task_2ms_EN=1;
        if((TimeTick_Count%5)==0)
            Task_5ms_EN=1;
        if((TimeTick_Count%10)==0)
            Task_10ms_EN=1;
        if((TimeTick_Count%20)==0)
            Task_20ms_EN=1;
        if((TimeTick_Count%50)==0)
            Task_50ms_EN=1;
        if((TimeTick_Count%100)==0)
            Task_100ms_EN=1;
        if((TimeTick_Count%500)==0)
            Task_500ms_EN=1;
        if((TimeTick_Count%1000)==0)
            Task_1000ms_EN=1;
        if((TimeTick_Count%5000)==0)
            Task_5000ms_EN=1;
    if(Task_1ms_EN)
        Task_1ms_EN=0;
        Task_1ms();
    if(Task_2ms_EN)
        Task_2ms_EN=0;
        Task_2ms();
    if(Task_5ms_EN)
        Task_5ms_EN=0;
        Task_5ms();
    if(Task_10ms_EN)
        Task_10ms_EN=0;
        Task_10ms();
    if(Task_20ms_EN)
        Task_20ms_EN=0;
        Task_20ms();
    if(Task_50ms_EN)
        Task_50ms_EN=0;
        Task_50ms();
    if(Task_100ms_EN)
        Task_100ms_EN=0;
        Task_100ms();
    if(Task_500ms_EN)
        Task_500ms_EN=0;
        Task_500ms();
    if(Task_1000ms_EN)
        Task_1000ms_EN=0;
        Task_1000ms();
    if(Task_5000ms_EN)
        Task_5000ms_EN=0;
        Task_5000ms();
void Sys_INIT(void)
//  MX_GPIO_Init();
//  MX_TIM1_Init();
//  MX_TIM2_Init();
//  MX_TIM3_Init();
//  MX_USART1_UART_Init();
    UartDebugInit();
    HAL_TIM_PWM_Start(&htim2,TIM_CHANNEL_1);
    PTQModeSetEnable();
void SYSTICK_Callback(void)
    SysTimeTikeCounting();
void SystemRun(void)
    TaskPolls();
//  FlowControl(&FlowDust);
    MS8607_PT_Thread(&MS8607_Para_1);
    sht31_thread(&sht31_1);
    MS8607_PT_Thread(&MS8607_Para_2);
    sht31_thread(&sht31_2);
//  SmiRuning(&SM9541_1);
    RS485Device1Handle();
电脑有加密无法发文件凑合看吧  发表于 2024-11-19 16:09
 楼主| starry1028 发表于 2024-11-19 17:43 | 显示全部楼层
下边是I2C.c
#include "I2C.h"
感谢,今天排查后解决了。确实是时序还有SDA转换成输入时的问题。
hjl2832 发表于 2024-12-5 16:42 | 显示全部楼层
模拟IIC的SDA做输入输出切换时,在有些芯片里会产生问题,要注意切换时的逻辑顺序。用示波器会看到切换时的一个高电平跳变。所以把IO先置0再切换就好了。
yang377156216 发表于 2024-12-9 13:55 | 显示全部楼层
可以直接用 rtt,这样就不用自己写驱动了
y1n9an 发表于 2024-12-17 22:49 | 显示全部楼层
将SHT30传感器通过适当的接口(如I2C或SPI)连接到HC32F460的相应引脚。确保连接正确无误,包括电源、地线、时钟线(SCL或SDA)和数据线(SDA或SCL)。
q1d0mnx 发表于 2024-12-17 23:33 | 显示全部楼层
配置微控制器,根据HC32F460的数据手册配置相应的硬件接口模块(如I2C或SPI模块),以正确与传感器通信。这可能包括设置时钟频率、从地址、波特率等参数。
p0gon9y 发表于 2024-12-18 21:11 | 显示全部楼层
通过相应的通信协议向SHT30发送初始化命令,使其准备好接收指令并发送数据。这通常涉及设置传感器的测量模式(如连续模式或单次测量模式)、输出数据速率等。
kaif2n9j 发表于 2024-12-18 22:48 | 显示全部楼层
使用HC32F460的通信接口发送读取命令到SHT30传感器,以获取温度和湿度数据。具体的读取命令和格式取决于传感器的数据手册。通常,你需要按照传感器的指令集发送特定的命令序列,然后接收传感器返回的数据。
cen9ce 发表于 2024-12-19 19:31 | 显示全部楼层
从传感器接收到的数据可能是原始的,需要进行适当的转换和处理才能得到实际的温度和湿度值。根据SHT30的数据手册,你可能需要解析返回的数据格式,并进行必要的计算以得到最终的温湿度值。
l1uyn9b 发表于 2024-12-19 20:48 | 显示全部楼层
具体的实现细节取决于你的硬件连接、微控制器的配置以及传感器的数据手册。
g0d5xs 发表于 2024-12-19 22:09 | 显示全部楼层
建议详细阅读HC32F460和SHT30的数据手册,并根据其中的指导进行开发。
zhizia4f 发表于 2024-12-20 07:17 | 显示全部楼层
网上有很多关于模拟I2C控制SHT30的例子的,你调整一下时序也就是delay应该就可以了
w2nme1ai7 发表于 2024-12-20 08:24 | 显示全部楼层
确实你说的IO配置成输入这个问题,之前我还遇到过IO需要先打开复用时钟的
q1ngt12 发表于 2024-12-20 09:33 | 显示全部楼层
其实一般来说模拟I2C不如硬件I2C来的快而且硬件I2C还比较好调试
