[AVR单片机] 看到hotpower的“利用UDRIE实现"手动触发"”帖子,俺也凑个热
3064|7
 楼主| zsmbj 发表于 2007-9-9 22:48 | 显示全部楼层 |阅读模式
很久就在用这个功能,一直很好用。现在整理了一下,把这个软件帖出来,希望对大家有用处。
可以用于232或485通讯。通过预编译选择。
以下uart.h:
#ifndef    _uart_h
#define    _uart_h
#include "avr/io.h"
#define        TURE                    1
#define        FALSE                     0
#define        RS485MODE                TURE        //TURE:rs485   FALSE:rs232
#define        BAUDRATE                51            //baud rate
#define        UART_buffer_size        32            //must 1,2,4,8,16,32,64,128 or 256 bytes
#if    (RS485MODE == TURE)
    #define TX_EN                    PIND2
    #define TX_DDR                    DDRD
    #define TX_PORT                    PORTD
    #define    RS_485_port_init()        TX_DDR |= (1<<TX_EN)
    #define RS_485_send()             TX_PORT |= (1<<TX_EN)        //RS485 enable
    #define RS_485_receive()         TX_PORT &= ~(1<<TX_EN)        //RS485 disable
#endif
//UART Buffer Defines
#define UART_RX_BUFFER_SIZE     UART_buffer_size
#define UART_RX_BUFFER_MASK     ( UART_RX_BUFFER_SIZE - 1 )
#define UART_TX_BUFFER_SIZE     UART_buffer_size
#define UART_TX_BUFFER_MASK     ( UART_TX_BUFFER_SIZE - 1 )
#if ( UART_RX_BUFFER_SIZE & UART_RX_BUFFER_MASK )
#error RX buffer size is not a power of 2
#endif
#if ( UART_TX_BUFFER_SIZE & UART_TX_BUFFER_MASK )
#error TX buffer size is not a power of 2
#endif
//unsigned char ReceiveByte( void )
//Parameters:  none
//Function:  Read a byte from uart
//Notice:    None
//Created:  2005-3-1 , By zsmbj
unsigned char ReceiveByte( void );
//void TransmitByte( unsigned char data )
//Parameters:
//Function:  write a byte to uart
//Notice:    None
void TransmitByte( unsigned char data );
//unsigned char DataInReceiveBuffer( void )
//Parameters:
//Function:  if have a uart data then return 1
//Notice:    None
unsigned char DataInReceiveBuffer( void );
#endif
以下uart.c:
#include "uart.h"
#include "avr/interrupt.h"
/* These are the global variables                                     */
//UART related buffers and variables
            unsigned char UART_RxBuf[UART_RX_BUFFER_SIZE];
volatile    unsigned char UART_RxHead;
volatile    unsigned char UART_RxTail;
            unsigned char UART_TxBuf[UART_TX_BUFFER_SIZE];
volatile    unsigned char UART_TxHead;
volatile    unsigned char UART_TxTail;
/* UART subroutine. */
/* initialize UART */
void init_UART( void )
    UBRRL = BAUDRATE;                                        //set the baud rate
    UBRRH = 0;
    //enable UART receiver and transmitter, and    receive interrupt
    UCSRA = 0;
    UCSRB = ( (1<<RXCIE) | (1<<RXEN) | (1<<TXEN) );
    UCSRC = ( (1<<URSEL) | (1<<UCSZ1) | (1<<UCSZ0) );
    UART_RxTail = 0;                                        //flush receive buffer
    UART_RxHead = 0;
    UART_TxTail = 0;
    UART_TxHead = 0;
    RS_485_port_init();
    RS_485_receive();
    #endif
//SIGNAL (SIG_UART_RECV)
//Parameters:  none
//Function:  uart rxd interrupt
//Notice:    None
    unsigned char data;
    unsigned char tmphead;
    data = UDR;                                             //read the received data
    tmphead = ( UART_RxHead + 1 ) & UART_RX_BUFFER_MASK;    //calculate buffer index
    UART_RxHead = tmphead;                                     //store new index
    if ( tmphead == UART_RxTail )                            //ERROR! Receive buffer overflow
    UART_RxBuf[tmphead] = data;                             //store received data in buffer
//SIGNAL (SIG_UART_DATA)
//Parameters:  none
//Function:  uart udre interrupt
//Notice:    None
    unsigned char tmptail;
    if ( UART_TxHead != UART_TxTail )                        //check if all data is transmitted
        tmptail = ( UART_TxTail + 1 ) & UART_TX_BUFFER_MASK;//calculate buffer index
        UART_TxTail = tmptail;                                 //store new index
        UDR = UART_TxBuf[tmptail];                             //start transmition
    else
        UCSRB &= ~(1<<UDRIE);                                 //disable UDRE interrupt
        UCSRB |= (1<<TXCIE);                                 //enable TXCIE interrupt
        #endif
//SIGNAL (SIG_UART_TRANS)
//Parameters:  none
//Function:  uart txd interrupt
//Notice:    None
    RS_485_receive();                                        //close rs485 send data.
    UCSRB &= ~(1<<TXCIE);                                     //disable TXCIE interrupt
#endif
//Parameters:  none
//Notice:    None
    while ( UART_RxHead == UART_RxTail )                    //wait for incomming data
    tmptail = ( UART_RxTail + 1 ) & UART_RX_BUFFER_MASK;    //calculate buffer index
    UART_RxTail = tmptail;                                     //store new index
    return UART_RxBuf[tmptail];                             //return data
//Parameters:
//Notice:    None
    tmphead = ( UART_TxHead + 1 ) & UART_TX_BUFFER_MASK;     //calculate buffer index
    while ( tmphead == UART_TxTail )                        //wait for free space in buffer
    UART_TxBuf[tmphead] = data;                             //store data in buffer
    UART_TxHead = tmphead;                                     //store new index
    RS_485_send();                                            //open rs485 send data mode if send data ok then close
    #endif
    UCSRB |= (1<<UDRIE);                                     //enable UDRE interrupt
//Parameters:
//Notice:    None
    return ( UART_RxHead != UART_RxTail );                     //return 0 (FALSE) if the receive buffer is empty
//end of program
以下main.c:测试用
#include "uart.h"
int main(void)
    init_UART();
    //if received a uart byte then send it
    if( DataInReceiveBuffer() )
        TransmitByte( ReceiveByte() );
以上程序在winavr20060421下编译通过,单片机atmega8515。
dcp 发表于 2007-9-10 00:20 | 显示全部楼层
dcp 发表于 2009-11-13 14:10 | 显示全部楼层
这一句好象不太好吧
wangwo 发表于 2009-11-13 22:29 | 显示全部楼层
支持楼主
laslison 发表于 2009-11-15 22:00 | 显示全部楼层
不错:)
lovelyegle 发表于 2009-11-16 23:06 | 显示全部楼层
收下了,谢啦
hotpower 发表于 2010-7-27 19:32 | 显示全部楼层
行使些职权~~~
xuyiyi 发表于 2010-7-28 12:09 | 显示全部楼层
哈!
HOT大叔滥用职权, 挖墓~~~
