always and assign begin buf bufif0 bufif1 case
casex casez cmos deassign default defparam disable edge
else end endcase endmodule endfunction endprimitive endspecify endtable
endtask event for force forever fork function highz0
highz1 if ifnone initial inout input integer
join large macrmodule medium module nand negedge nmos
nor not notif0 notif1 or output parameter pmos
posedge primitive pull0 pull1 pullup pulldown rcmos real
realtime reg release repeat rnmos rpmos rtran rtranif0
rtranif1 scalared small specify specparam strong0 strong1 supply0
supply1 table task time trantranif0 tranif1 tri tri0
tri1 triand trior trireg vectored wait wand weak0
weak1 while wire wor xnor xor
