Verilog 保留字
1648|2
 楼主| 星星之火红 发表于 2012-11-8 00:11 | 显示全部楼层 |阅读模式
always         and           assign            begin           buf                bufif0            bufif1          case
casex          casez         cmos             deassign      default          defparam      disable       edge
else             end            endcase        endmodule  endfunction  endprimitive endspecify  endtable
endtask       event         for                  force            forever          fork                function     highz0
highz1         if               ifnone            initial            inout             input              integer
join             large         macrmodule  medium        module         nand              negedge     nmos
nor              not            notif0             notif1            or                  output            parameter   pmos
posedge     primitive    pull0              pull1              pullup          pulldown        rcmos         real
realtime      reg            release          repeat            rnmos          rpmos            rtran            rtranif0
rtranif1       scalared    small              specify           specparam  strong0           strong1       supply0
supply1      table          task               time                trantranif0    tranif1            tri               tri0
tri1             triand         trior               trireg              vectored       wait               wand          weak0
weak1        while         wire               wor                xnor               xor
lxAPP 发表于 2012-11-8 00:18 | 显示全部楼层
这个很好哦。
GoldSunMonkey 发表于 2012-11-8 00:30 | 显示全部楼层
:loveliness:
