各位大神,救急啊usb hid
2757|9
 楼主| gurong60 发表于 2013-4-25 11:44 | 显示全部楼层 |阅读模式
在这个函数里面发送数据时可以,但把发送程序写在主函数里就没用,
* Function Name  : EP1_OUT_Callback.
* Description    : EP1 OUT Callback Routine.
* Input          : None.
* Output         : None.
* Return         : None.
void EP1_OUT_Callback(void)
  BitAction Led_State;
  PrevXferComplete = 1;
  /* Read received data (2 bytes) */
  USB_SIL_Read(EP1_OUT, Receive_Buffer);
  /* write received data (2 bytes) */
  send_Buffer[0] = 0X07;
  Write the descriptor through the endpoint */
  USB_SIL_Write(EP1_IN, (uint8_t*) send_Buffer, 2);
  SetEPTxValid(ENDP1);
报告描述符为
const uint8_t CustomHID_ReportDescriptor[CUSTOMHID_SIZ_REPORT_DESC] =
        0x06, 0xFF, 0x00,      /* USAGE_PAGE (Vendor Page: 0xFF00) */
    0x09, 0x01,            /* USAGE (Demo Kit)               */
    0xa1, 0x01,            /* COLLECTION (Application)       */
    /* 6 */
    /* Led 1 */
    0x85, 0x01,            /*     REPORT_ID (1)                     */
    0x09, 0x01,            /*     USAGE (LED 1)                     */
    0x15, 0x00,            /*     LOGICAL_MINIMUM (0)        */
    0x25, 0x01,            /*     LOGICAL_MAXIMUM (1)        */
    0x75, 0x08,            /*     REPORT_SIZE (8)            */
    0x95, 0x01,            /*     REPORT_COUNT (1)           */
    0xB1, 0x82,             /*    FEATURE (Data,Var,Abs,Vol) */
    0x91, 0x82,            /*     OUTPUT (Data,Var,Abs,Vol)  */
    /* 26 */
    /* Led 2 */
    0x85, 0x02,            /*     REPORT_ID 2                     */
    0x09, 0x02,            /*     USAGE (LED 2)                     */
    0x85, 0x02,            /*     REPORT_ID (2)              */
    /* 46 */
    /* Led 3 */
    0x85, 0x03,            /*     REPORT_ID (3)                     */
    0x09, 0x03,            /*     USAGE (LED 3)                     */
    /* 66 */
    /* Led 4 */
    0x85, 0x04,            /*     REPORT_ID 4)                     */
    0x09, 0x04,            /*     USAGE (LED 4)                     */
    0x85, 0x04,            /*     REPORT_ID (4)              */
    /* 86 */
    /* key Push Button */
    0x85, 0x05,            /*     REPORT_ID (5)              */
    0x09, 0x05,            /*     USAGE (Push Button)        */
    0x75, 0x01,            /*     REPORT_SIZE (1)            */
    0x81, 0x82,            /*     INPUT (Data,Var,Abs,Vol)   */
    0xb1, 0x82,            /*     FEATURE (Data,Var,Abs,Vol) */
    0x75, 0x07,            /*     REPORT_SIZE (7)            */
    0x81, 0x83,            /*     INPUT (Cnst,Var,Abs,Vol)   */
    0x85, 0x05,            /*     REPORT_ID (2)              */
    0xb1, 0x83,            /*     FEATURE (Cnst,Var,Abs,Vol) */
    /* 114 */
    /* Tamper Push Button */
    0x85, 0x06,            /*     REPORT_ID (6)              */
    0x09, 0x06,            /*     USAGE (Tamper Push Button) */
    /* 142 */
    /* ADC IN */
    0x85, 0x07,            /*     REPORT_ID (7)              */
    0x09, 0x07,            /*     USAGE (ADC IN)             */
    0x26, 0xff, 0x00,      /*     LOGICAL_MAXIMUM (255)      */
    0x09, 0x07,            /*     USAGE (ADC in)             */
    /* 161 */
    0xc0                   /*     END_COLLECTION                     */
  }; /* CustomHID_ReportDescriptor */
请教
IJK 发表于 2013-4-25 12:26 | 显示全部楼层
在这个EP1_OUT_Callback函数里面发送数据时可以,但把发送程序写在主函数里就没用。
这是正常的。因为有EP1_OUT数据后,USB库会自动调用EP1_OUT_Callback函数。而把发送程序写在主函数里,就不会被自动调用啦
 楼主| gurong60 发表于 2013-4-25 12:34 | 显示全部楼层
这是正常的。因为有EP ...
EP1_OUT_Callback这个函数原来是接收usb接口端点数据,而我现在是要发送数据到usb接口,为什么不能写在主函数里面呢,而且如果那样的话就是必须有数据来才可以发送,请指教
IJK 发表于 2013-4-25 13:48 | 显示全部楼层
要发送数据到usb接口,应该用EP1_IN_Callback这个函数
 楼主| gurong60 发表于 2013-4-25 14:02 | 显示全部楼层
额,我想主动发送数据,
IJK 发表于 2013-4-25 18:00 | 显示全部楼层
看来LS不懂USB,USB只能由PC来要数据,USB device不能主动发数据。
当然,对于USB HID device,PC会定期来要数据的。
hawksabre 发表于 2013-4-25 19:19 | 显示全部楼层
不是很懂USB协议   帮你顶一个   希望有真正的高手能解决这个问题
 楼主| gurong60 发表于 2013-4-25 22:03 | 显示全部楼层
当然,对于USB HID device,PC会定期来 ...
谢谢你,不够深入看书
6楼正解,
e_007 发表于 2015-11-27 22:05 | 显示全部楼层
放main要被中断呢?~n~
个人签名:对手,队友
179
