用的c8051f340,读ds18b20,然后用串口发送数据在串口调试软件上显示,显示的数字一直就是10,各位帮忙看看程序哪里有问题啊?系统时钟是内部晶振,48M系统时钟。- #include <c8051F340.h>
- #include <stdio.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define SYSCLK 48000000 // SYSCLK frequency in Hz
- #define BAUDRATE0 9600 // Baud rate of UART0 in bps
- #define BAUDRATE1 9600 // Baud rate of UART1 in bps
- sfr16 SBRL1 = 0xB4;
- sbit ds=P2^2;
- uchar flag ;
- uint temp;
- float wendu;
- bit UART = 0;
- void SYSCLK_Init (void)
- unsigned int iTmp;
- OSCICN |= 0x83;
- //Enable internal 4X MULL
- if( !( CLKMUL & ( 1<<5 ) ) )
- CLKMUL = 0;
- CLKMUL = 0x00;
- CLKMUL |= ( 1<<7 );
- for( iTmp = 0; iTmp < 200; iTmp ++ );
- CLKMUL |= ( 1<<6 ) | ( 1<<7 );
- for( iTmp = 0; iTmp < 2000; iTmp ++ );
- while( !( CLKMUL & ( 1<<5 ) ) );
- //USB clock: 48MHz, system clock : 48MHz
- CLKSEL = 0x03;
- void delayus(int a)
- int y ;
- for(;a>0;a--)
- for(y=0;y<5;y++);
- void delayms(int a)
- int y ;
- for(;a>0;a--)
- for(y=0;y<4800;y++);
- void UART0_Init (void)
- SCON0 = 0x10; // SCON0: 8-bit variable bit rate
- // level of STOP bit is ignored
- // RX enabled
- // ninth bits are zeros
- // clear RI0 and TI0 bits
- if (SYSCLK/BAUDRATE0/2/256 < 1) {
- TH1 = -(SYSCLK/BAUDRATE0/2);
- CKCON &= ~0x0B; // T1M = 1; SCA1:0 = xx
- CKCON |= 0x08;
- } else if (SYSCLK/BAUDRATE0/2/256 < 4) {
- TH1 = -(SYSCLK/BAUDRATE0/2/4);
- CKCON &= ~0x0B; // T1M = 0; SCA1:0 = 01
- CKCON |= 0x09;
- } else if (SYSCLK/BAUDRATE0/2/256 < 12) {
- TH1 = -(SYSCLK/BAUDRATE0/2/12);
- CKCON &= ~0x0B; // T1M = 0; SCA1:0 = 00
- } else {
- TH1 = -(SYSCLK/BAUDRATE0/2/48);
- CKCON &= ~0x0B; // T1M = 0; SCA1:0 = 10
- CKCON |= 0x02;
- TL1 = TH1; // init Timer1
- TMOD &= ~0xf0; // TMOD: timer 1 in 8-bit autoreload
- TMOD |= 0x20;
- TR1 = 1; // START Timer1
- TI0 = 1; // Indicate TX0 ready
- void ds_rst() //初始化DS18B20
- ds=1; // 数据线置1
- delayus(1); //延时1us
- ds=0; //数据线置0
- delayus(700); //延时700us
- ds=1; //数据线置1
- delayus(44); // 延时44us
- if(ds==0) //判断DS18B20的返回的低电平
- flag=1;
- else
- flag=0;
- delayus(140);
- ds=1;
- bit ds_read_bit(void)//读一位
- bit dat;
- ds=0;//单片机(微处理器)将总线拉低
- delayus(1);//读时隙起始于微处理器将总线拉低至少1us
- ds=1;//拉低总线后接着释放总线,让从机18b20能够接管总线,输出有效数据
- delayus(2);//小延时一下,读取18b20上的数据 ,因为从ds18b20上输出的数据
- //在读"时间隙"下降沿出现15us内有效
- dat=ds;//主机读从机18b20输出的数据,这些数据在读时隙的下降沿出现//15us内有效
- delayus(77);//所有读"时间隙"必须60~120us,这里77us
- return(dat);//返回有效数据
- uchar ds_read_byte(void ) //读一字节
- uchar value,i,j;
- value=0;//一定别忘了给初值
- for(i=0;i<8;i++)
- j=ds_read_bit();
- value=(j<<7)|(value>>1);//这一步的说明在一个word文档里面
- return(value);//返回一个字节的数据
- void ds_write_byte(uchar dat) //写一个字节
- uchar i;
- bit onebit;//一定不要忘了,onebit是一位
- for(i=1;i<=8;i++)
- onebit=dat&0x01;
- dat=dat>>1;
- if(onebit)//写 1
- ds=0;
- delayus(1);
- delayus(1);//看时序图,至少延时1us,才产生写"时间隙"
- ds=1;//写时间隙开始后的15μs内允许数据线拉到高电平
- delayus(60);//所有写时间隙必须最少持续60us
- else//写 0
- ds=0;
- delayus(63);//主机要生成一个写0 时间隙,必须把数据线拉到低电平并保持至少60μs,这里64us
- ds=1;
- _nop_();
- _nop_();
- void tem_change()
- ds_rst();
- delayms(2);//约2ms
- ds_write_byte(0xcc);
- ds_write_byte(0x44);
- delayms(750);
- uint get_temperature()
- uchar a,b;
- ds_rst();
- delayms(2);//约2ms
- ds_write_byte(0xbe);
- a=ds_read_byte();
- b=ds_read_byte();
- temp=b;
- temp<<=8;
- temp=temp|a;
- wendu=temp*0.0625;
- temp=wendu*10+0.5;
- wendu=wendu+0.5;
- return temp;
- void main()
- char input_char;
- PCA0MD &= ~0x40;
- SYSCLK_Init ();
- XBR0 = 0x01;
- XBR1 = 0x40;
- P0MDOUT |= 0x11;
- P2MDOUT |= 0x04;
- UART0_Init ();
- while(1)
- tem_change();//12位转换时间最大为750ms
- get_temperature();
- input_char = getchar();
- switch (input_char) {
- case '1':
- printf ("%x\n",&wendu);
- break;
- default:
- break;
- char putchar (char c) {
- if (UART == 0) {
- if (c == '\n') { // check for newline character
- while (!TI0); // wait until UART0 is ready to transmit
- TI0 = 0; // clear interrupt flag
- SBUF0 = 0x0d; // output carriage return command
- return (SBUF0 = c); // output <c> using UART 0
- else if (UART == 1) {
- while (!(SCON1 & 0x02)); // wait until UART1 is ready to transmit
- SCON1 &= ~0x02; // clear TI1 interrupt flag
- SBUF1 = 0x0d; // output carriage return
- return (SBUF1 = c); // output <c> using UART 1
- // _getkey
- // Return Value : byte received from UART0/1
- // Parameters : none
- // This is an overloaded fuction found in the stdio library. When the
- // function _getkey is called, either by user code or through calls to stdio
- // routines such as scanf, the following routine will be executed instead
- // of the function located in the stdio library.
- // The function checks the UART global variable to determine which UART to
- // use to receive a character.
- // The routine waits for RI0/RI1 to be set, indicating that a byte has
- // been received across the UART0/UART1 RX line. The routine saves the
- // received character into a local variable, clears the RI0/RI1 interrupt
- // flag, and returns the received character value.
- char _getkey () {
- char c;
- if (UART == 0) {
- while (!RI0); // wait until UART0 receives a character
- c = SBUF0; // save character to local variable
- RI0 = 0; // clear UART0 receive interrupt flag
- return (c); // return value received through UART0
- while (!(SCON1 & 0x01)); // wait until UART1 receives a character
- c = SBUF1; // save character to local variable
- SCON1 &= ~0x01; // clear UART1 receive interrupt flag
- return (c); // return value received through UART1
