谁知道FR-4PCB板顶层和底层间的耐压强度是多少?
6842|1
 楼主| foxcom 发表于 2007-8-22 21:04 | 显示全部楼层 |阅读模式
四层板,FR-4层厚大约5.6MIL,之间加-90V电压不知行不行
syzdq 发表于 2007-8-23 17:24 | 显示全部楼层
PCB Design Tutorial by David L. Jones Page 9 of 25
For&nbsp;non-mains&nbsp;voltages,&nbsp;the&nbsp;IPC&nbsp;standard&nbsp;has&nbsp;a&nbsp;set&nbsp;of&nbsp;tables&nbsp;that&nbsp;define&nbsp;the&nbsp;clearance&nbsp;required&nbsp;for&nbsp;various<br />voltages.&nbsp;A&nbsp;simplified&nbsp;table&nbsp;is&nbsp;shown&nbsp;here.&nbsp;The&nbsp;clearance&nbsp;will&nbsp;vary&nbsp;depending&nbsp;on&nbsp;whether&nbsp;the&nbsp;tracks&nbsp;are&nbsp;on&nbsp;an<br />internal&nbsp;layers&nbsp;or&nbsp;the&nbsp;external&nbsp;surface.&nbsp;They&nbsp;also&nbsp;vary&nbsp;with&nbsp;the&nbsp;operational&nbsp;height&nbsp;of&nbsp;the&nbsp;board&nbsp;above&nbsp;sea&nbsp;level,<br />due&nbsp;to&nbsp;the&nbsp;thinning&nbsp;of&nbsp;the&nbsp;atmosphere&nbsp;at&nbsp;high&nbsp;altitudes.&nbsp;Conformal&nbsp;coating&nbsp;also&nbsp;improves&nbsp;these&nbsp;figures&nbsp;for&nbsp;a&nbsp;given<br />clearance,&nbsp;and&nbsp;this&nbsp;is&nbsp;often&nbsp;used&nbsp;on&nbsp;military&nbsp;spec&nbsp;PCBs.<br /><br />Clearances&nbsp;for&nbsp;Electrical&nbsp;Conductors<br />Voltage&nbsp;(DC&nbsp;or&nbsp;Peak&nbsp;AC)&nbsp;Internal&nbsp;External&nbsp;(&lt3050m)&nbsp;External&nbsp;(&gt3050m)<br />0-15V&nbsp;0.05mm&nbsp;0.1mm&nbsp;0.1mm<br />16-30V&nbsp;0.05mm&nbsp;0.1mm&nbsp;0.1mm<br />31-50V&nbsp;0.1mm&nbsp;0.6mm&nbsp;0.6mm<br />51-100V&nbsp;0.1mm&nbsp;0.6mm&nbsp;1.5mm<br />101-150V&nbsp;0.2mm&nbsp;0.6mm&nbsp;3.2mm<br />151-170V&nbsp;0.2mm&nbsp;1.25mm&nbsp;3.2mm<br />171-250V&nbsp;0.2mm&nbsp;1.25mm&nbsp;6.4mm<br />251-300V&nbsp;0.2mm&nbsp;1.25mm&nbsp;12.5mm<br />301-500V&nbsp;0.25mm&nbsp;2.5mm&nbsp;12.5mm
