赛普拉斯的新型EZ-USB HX3的USB3.0集线控制器实现了USB-IF认证
3383|15
 楼主| kk5290122 发表于 2014-3-20 22:11 | 显示全部楼层 |阅读模式
Highly-Interoperable, Configurable Hub Controller with Advanced Charging Capabilities Is
Industry’s First to Offer Eight Downstream Ports for Enhanced Connectivity and Flexible Design
SAN JOSE, Calif., March 13, 2014 – Cypress Semiconductor Corp.(NASDAQ:CY) today announced a new USB 3.0 hub controller certified by the USB Implementers Forum (USB-IF) for the SuperSpeed USB 5 Gbps standard.The EZ-USB® HX3 USB 3.0 hub controller offers a best-in-class feature set, with robust interoperability, extensive charging support and full configurability, making it ideal for docking stations, monitors, Ultrabook™ devices, digital TVs, set-top boxes, printers and servers.
The versatile HX3 USB 3.0 hub controller offers a Ghost Charging™ feature for charging of devices without a host, and it also supports the USB-IF Battery Charging v1.2 specification and charging of Apple devices.HX3 is the first SuperSpeed USB (USB 3.0) hub controller to offer an Accessory Charger Adaptor Dock (ACA-Dock) feature, which enables upstream charging for portable devices with a USB On-The-Go (OTG) host.HX3 includes a Shared Link™ feature that enables up to eight downstream ports, allowing products such as docking stations and desktop monitors to connect with more USB peripherals using a single four port hub.HX3 offers full configurability via I2C EEPROM, I2C Slave and GPIO options, allowing designers to configure PHY drive strength, the number or downstream ports, power switch polarity, LED indicators and more.HX3 consumes only 735 mW with all ports in operation at SuperSpeed data rates—50% less than competing solutions.
“Cypress’s certified HX3 hub enables flexible design in almost any device,” said Jeff Ravencraft, USB-IF President and COO.“There is a ‘plug and play’ expectation for USB technology and the only way to ensure a seamless computing experience is to successfully complete USB-IF certification.Investing in untested products puts companies at risk of developing sub-par technology.However, companies that diligently adhere to the USB-IF certification program can offer their customers an advantage.”
“HX3 adds a USB 3.0 hub with differentiating features to our industry-leading SuperSpeed portfolio,” said Mark Fu, Senior Marketing Director of the USB 3.0 Business Unit at Cypress.“HX3 demonstrates Cypress’s ability to develop innovative features, such as enabling up to eight downstream ports with Shared Link, driving long PCB traces with configurable USB PHYs, and charging portable electronics with Ghost Charging—providing our customers with more design flexibility and top performance.”
Product Availability
The HX3 USB3.0 hub controller is now in production.The CYUSB3328 4-port hub with Shared Link and the CYUSB3314 4-port hub with individual port power control are available in 88-pin QFN packages.The CYUSB3304 basic 4-port hub is available in a smaller footprint 68-pin QFN package.More information on HX3 is available at www.cypress.com/hx3.
About Cypress EZ-USB SuperSpeed USB (USB 3.0) Portfolio
Cypress’s SuperSpeed USB (USB 3.0) portfolio began with EZ-USB FX3™, the industry’s only programmable SuperSpeed USB (USB 3.0) peripheral controller.The portfolio now includes the EZ-USB CX3™ camera controller, the EZ-USB FX3S™ RAID-on-Chip controller, the EZ-USB SD3 storage controller, and the EZ-USB HX3 hub controller.
EZ-USB FX3 provides SuperSpeed USB (USB 3.0) connectivity in virtually any system.It is equipped with a highly configurable General Programmable Interface (GPIF™ II), which can be programmed in 8-, 16- and 32-bit configurations with data rates as high as 400 megabytes per second.GPIF II enables FX3 to interface directly to nearly any processor, ASIC or FPGA.The on-chip ARM9 CPU core with 512 KB RAM delivers 200 MIPS of computational power and is available for applications that require local data processing.
The EZ-USB CX3 programmable camera controller enables developers to add SuperSpeed USB (USB 3.0) connectivity to any image sensors supporting the Mobile Industry Processor Interface (MIPI) Camera Serial Interface Type 2 (CSI-2) standard.The EZ-USB FX3S storage controller supports dual Secure Digital (SD) or embedded MultiMedia Card (eMMC) interfaces.Based on Cypress’s proprietary West Bridge® architecture, FX3S enables simultaneous links among storage media, application processor and SuperSpeed USB (USB 3.0), allowing unrestricted three-way data flow for maximizing data transfer rate.EZ-USB FX3 CSP provides the industry-leading FX3 USB 3.0 peripheral controller in a Wafer-Level Chip Scale Package (WLCSP) that measures only 4.7 mm x 5.1 mm, more than a 75% footprint reduction from the FX3 controller’s Ball-Grid-Array package.For more information on Cypress EZ-USB SuperSpeed USB (USB 3.0) solutions, please contact Cypress at usb3@cypress.com.
heibaiyinjiag 发表于 2014-3-23 10:31 | 显示全部楼层
楼主看懂这篇**了吗  = =
taihezhibanh 发表于 2014-3-23 10:35 | 显示全部楼层
累觉不爱
beiwaroad 发表于 2014-3-23 10:40 | 显示全部楼层
楼主没有尝试一下把这篇**翻译过来吗?
justbybing 发表于 2014-3-23 16:51 | 显示全部楼层
每当看到这种帖子就会捶胸顿足当初为什么没有好好学英语
 楼主| kk5290122 发表于 2014-3-23 22:09 | 显示全部楼层
楼主看懂这篇**了吗  = =
看懂大体…………
累觉不爱
呵呵……感觉不会再爱了么??;P
 楼主| kk5290122 发表于 2014-3-23 22:10 | 显示全部楼层
楼主没有尝试一下把这篇**翻译过来吗?
用google翻译了一下,不是太准确,没有网上传。
哈哈,现在好好学还不晚!
waitingf 发表于 2014-3-23 23:02 | 显示全部楼层
楼主还是把这篇**翻译一下传到网上来吧 感觉楼主在这方面很强的
u880 发表于 2014-3-23 23:08 | 显示全部楼层
谷歌有时候翻译会气死人的
 楼主| kk5290122 发表于 2014-3-24 21:41 | 显示全部楼层
:Lls太看得起我了。
谷歌有时候翻译会气死人的
我感觉谷歌应该比有道好。
szjlj168 发表于 2014-3-27 17:10 | 显示全部楼层
CY7C68013A微控制器,原装现货,欢迎订购!
vv123456 发表于 2021-2-20 10:32 | 显示全部楼层
多少钱
szjlj168 发表于 2021-2-20 14:46 | 显示全部楼层
具体哪款芯片,可以加我微信 13692110307
