IC名词
1891|0
 楼主| youer 发表于 2008-4-9 10:26 | 显示全部楼层 |阅读模式
ic, TI, AN, ST, IO
AC-drives&nbsp;交流变频器<br />AC-&nbsp;motors&nbsp;交流电机<br />asymmetrical&nbsp;非对称的<br />attenuation&nbsp;衰减<br />automation&nbsp;and&nbsp;drives&nbsp;自动化与驱动<br />back-to-back&nbsp;背靠背的,紧接的<br />backward-travelling&nbsp;waves&nbsp;向后传播的波<br />band&nbsp;width&nbsp;带宽<br />bridged&nbsp;impedance&nbsp;桥接阻抗<br />cable&nbsp;bridge&nbsp;电缆桥架<br />capacitance&nbsp;电容<br />capacitive&nbsp;电容性的<br />charge&nbsp;电荷<br />circuit&nbsp;schematic&nbsp;diagram&nbsp;电路原理图解<br />cladding&nbsp;覆层<br />clock&nbsp;cycle&nbsp;脉冲周期<br />coefficient&nbsp;系数<br />common-mode&nbsp;noise&nbsp;普通模式噪音<br />conductivity&nbsp;传导性<br />configuration&nbsp;构造<br />constant&nbsp;常量<br />constraint&nbsp;约束,强制<br />copper&nbsp;sheet&nbsp;铜片<br />core&nbsp;transistor&nbsp;logic&nbsp;磁心晶体管逻辑<br />coupling&nbsp;联结<br />current&nbsp;carrying&nbsp;capacity&nbsp;载流能力(最大允许电流)<br />damping&nbsp;阻尼<br />decentralized&nbsp;automation&nbsp;分布式自动化系统<br />decomposition&nbsp;分解<br />decouple&nbsp;分离<br />delay&nbsp;circuit&nbsp;延迟电路<br />dielectric&nbsp;sheets&nbsp;介电原片<br />differential&nbsp;pair&nbsp;微分对<br />diode&nbsp;clamping钳位<br />edge&nbsp;connector&nbsp;边缘连接器<br />electrical&nbsp;infrastructure&nbsp;电气基础设施<br />electrical&nbsp;installation&nbsp;电气安装技术<br />equations&nbsp;set&nbsp;方程组<br />evenly&nbsp;均匀地<br />flip-chip&nbsp;后滚翻&nbsp;forward-travelling&nbsp;waves&nbsp;向前传播的波<br />four-layer&nbsp;四层<br />global&nbsp;overview&nbsp;全球概览<br />granularity&nbsp;间隔尺寸<br />ground&nbsp;plane&nbsp;地平面,水平投影<br />hookup&nbsp;接线图<br />human&nbsp;machine&nbsp;interface&nbsp;人机界面<br />impedance&nbsp;阻抗<br />incidence&nbsp;入射<br />incident&nbsp;wave&nbsp;入射波<br />inconsequential&nbsp;不合逻辑的<br />incorporated&nbsp;合成一体的<br />inductance&nbsp;感应系数<br />industrial&nbsp;communication&nbsp;工业通讯<br />industrial&nbsp;controls&nbsp;工业控制<br />inherently&nbsp;固有地<br />in&nbsp;isolation&nbsp;绝缘<br />instantaneous&nbsp;瞬间的<br />interleaved&nbsp;交叉<br />intrinsic&nbsp;本征的<br />laminate&nbsp;碾压<br />lead&nbsp;导线<br />leakage&nbsp;current&nbsp;泄漏电流<br />load&nbsp;admittance&nbsp;负载导纳<br />loops&nbsp;线圈<br />lumped&nbsp;集中的<br />macroprocessor&nbsp;微处理器<br />manufacturing&nbsp;execution&nbsp;systems&nbsp;制造执行系统<br />matrix&nbsp;矩阵<br />medium-power&nbsp;distribution&nbsp;中压配电<br />modal&nbsp;模式的<br />modeling&nbsp;建模<br />motion&nbsp;control&nbsp;运动控制<br />motor&nbsp;and&nbsp;soft&nbsp;starters&nbsp;电机及软起动器<br />motor&nbsp;management&nbsp;systems&nbsp;电机管理系统<br />mounting&nbsp;pads&nbsp;安装垫片<br />multimedia&nbsp;show&nbsp;多媒体展示<br />negligible&nbsp;可以忽略的<br />noise&nbsp;margins&nbsp;噪音安全系数<br />numerical&nbsp;controls&nbsp;数控系统<br />off-diagonal&nbsp;terms&nbsp;分离对角线条件<br />optimal&nbsp;最佳的,最理想的&nbsp;<br />overload&nbsp;relays&nbsp;过载继电器<br />overly&nbsp;过度地<br />overshoot&nbsp;过冲<br />parastics&nbsp;寄生效应<br />passive&nbsp;component&nbsp;无<br />peak&nbsp;current&nbsp;峰值电流<br />power&nbsp;dissipation&nbsp;电力分散<br />prepreg&nbsp;预浸料呸<br />process&nbsp;automation&nbsp;过程自动化<br />process&nbsp;instrumentation&nbsp;and&nbsp;analytics&nbsp;过程仪表及分析仪器<br />proximity&nbsp;effect&nbsp;邻近效应<br />punched&nbsp;穿孔<br />radian&nbsp;弧度<br />reactance&nbsp;电抗<br />recharge&nbsp;再充<br />reflection&nbsp;coefficient&nbsp;反射系数<br />regulated&nbsp;power&nbsp;supply&nbsp;稳压电源<br />resistance&nbsp;阻抗<br />resistive&nbsp;有抵抗力的<br />resistor&nbsp;电阻器<br />resonate&nbsp;共振<br />routability&nbsp;路线<br />routing&nbsp;邮件路由<br />schematic&nbsp;示意图<br />segment&nbsp;一段<br />self-inductance&nbsp;自感应<br />series&nbsp;inductance&nbsp;串联感应<br />services&nbsp;&&nbsp;industry&nbsp;solutions&nbsp;服务和工业解决方案<br />simulation&nbsp;模拟<br />single-ended&nbsp;termination&nbsp;单一终端终止<br />stackup&nbsp;定高分层盘旋<br />stub&nbsp;断株<br />subdivide&nbsp;细分<br />susceptible&nbsp;易受影响的<br />switching&nbsp;配电;交流<br />terminator&nbsp;终结器<br />thermal&nbsp;cycle&nbsp;热循环<br />thickness&nbsp;厚度<br />totally&nbsp;integrated&nbsp;power&nbsp;全集成能源管理<br />transistor&nbsp;晶体管<br />undershoot&nbsp;负脉冲信号;下冲<br />Voice&nbsp;Interference&nbsp;Analysis&nbsp;System&nbsp;语音干扰分析系统<br />voltage&nbsp;regulator&nbsp;调压器<br />warpage&nbsp;热曲线<br />warping&nbsp;扭曲,变形<br />waveguide&nbsp;波导<br />wiring&nbsp;layout&nbsp;线路配置图<br />
