| 楼主你好,默认的是使用RGMII (AR8031 1000M bit Ethernet phy) ,你提到的 #if defined(CONFIG_MX6Q) || defined(CONFIG_MX6DL)
 mx6_rgmii_rework(dev->name, info->phy_addr);
 是在u-boot-2009.08/board/freescale/mx6q_sabresd/mx6q_sabresd.c有定义,如下所示:
 int mx6_rgmii_rework(char *devname, int phy_addr) ----------------------------主要是从 AR8031 输出一个125MHz的CLK给i.mx6使用
 unsigned short val;
 /* To enable AR8031 ouput a 125MHz clk from CLK_25M */
 phy_write(devname, phy_addr, 0xd, 0x7);
 phy_write(devname, phy_addr, 0xe, 0x8016);
 phy_write(devname, phy_addr, 0xd, 0x4007);
 phy_read(devname, phy_addr, 0xe, &val);
 val &= 0xffe3;
 val |= 0x18;
 phy_write(devname, phy_addr, 0xe, val);
 /* introduce tx clock delay */
 phy_write(devname, phy_addr, 0x1d, 0x5);
 phy_read(devname, phy_addr, 0x1e, &val);
 val |= 0x0100;
 phy_write(devname, phy_addr, 0x1e, val);
 return 0;
