LPC1788 如何让程序运行在SDRAM中
1851|0
 楼主| qzroger 发表于 2014-7-16 13:54 | 显示全部楼层 |阅读模式
void board_mpu_init(void)
    /* - Region 0: 0x00000000 - 0x0007FFFF --- on-chip non-volatile memory
     *      + Size: 512kB
     *      + Acess permission: full access
    MPU->RNR  = 0;//indicate MPU region 0
    MPU->RBAR = 0x00000000; // update the base address for the region 0
    MPU->RASR = MPU_RASR_ACCESS_PERMISSION(MPU_FULL_ACCESS)     //full access
                |MPU_RASR_REGION_SIZE(MPU_REGION_SIZE_512KB)    //512Kb size
                |MPU_REGION_ENABLE;                             //region enable
    /* - Region 1: 0x10000000 - 0x1000FFFF --- on-chip SRAM
     *      + Size: 64kB
     *      + Access permission: full access
    MPU->RNR = 1;
    MPU->RBAR = 0x10000000; // update the base address for the region 1
                |MPU_RASR_REGION_SIZE(MPU_REGION_SIZE_64KB)
                |MPU_REGION_ENABLE;
     /* - Region 2: 0x40000000 - 0x400FFFFF --- APB peripheral
     *      + Size: 1MB
    MPU->RNR = 2;
    MPU->RBAR = 0x40000000; // update the base address for the region 2
                |MPU_RASR_REGION_SIZE(MPU_REGION_SIZE_1MB)
                |MPU_REGION_ENABLE;
     /* - Region 3: 0x20080000 - 0x200BFFFF --- AHB peripheral
     *      + Size: 256KB
     *      + AP=b011: full access
    MPU->RNR = 3;
    MPU->RBAR = 0x20080000; // update the base address for the region 3
                |MPU_RASR_REGION_SIZE(MPU_REGION_SIZE_256KB)
                |MPU_REGION_ENABLE;
     /* - Region 4: 0xE0000000 - 0xE00FFFFF --- System control
     *      + Size: 1MB
    MPU->RNR = 4;
    MPU->RBAR = 0xE0000000; // update the base address for the region 4
                |MPU_REGION_ENABLE;
     /* - Region 5:0x20000000 - 0x20007FFF --- on chip SRAM
     *      + Size: 32kB
    MPU->RNR = 5;
    MPU->RBAR = 0x20000000; // update the base address for the region 5
                |MPU_RASR_REGION_SIZE(MPU_REGION_SIZE_32KB)
                |MPU_REGION_ENABLE;
    /* - Region 6:0xA0000000 - 0xA1000000 --- NorFlash
    *      + Size: 16MB
   MPU->RNR = 6;
   MPU->RBAR = 0x90000000; // update the base address for the region 5
               |MPU_RASR_REGION_SIZE(MPU_REGION_SIZE_16MB)
               |MPU_REGION_ENABLE;
    /* - Region 6:0xA0000000 - 0xA1000000 --- Ext SRAM
    *      + Size: 16MB
   MPU->RNR = 7;
   MPU->RBAR = 0xA0000000; // update the base address for the region 5
               |MPU_RASR_REGION_SIZE(MPU_REGION_SIZE_32MB)
               |MPU_REGION_ENABLE;
   SCB->SHCSR |=(1<<16);   //Enable Memory management fault
   MPU->CTRL =(1<<0);      //Enable the MPU
////    _DBG_("Setup MPU: \n\r"
////          "This provide 6 regions: \n\r"
////          "Region 0 - Privileged code: 0x00000000 - 0x0007FFFF(512kB)\n\r"
////          "Region 1 - Privileged data: 0x10000000 - 0x1000FFFF(64kB)\n\r"
////          "Region 2 - APB Peripheral:  0x40000000 - 0x400FFFFF(1MB)\n\r"
////          "Region 3 - AHB peripheral:  0x20080000 - 0x200BFFFF(256KB)\n\r"
////          "Region 4 - System control:  0xE0000000 - 0xE00FFFFF(1MB)\n\r"
////          "Region 5 - On-chip SRAM:    0x20000000 - 0x20007FFF(32kB)\n\r"
////          "Region 6 - Ext SRAM         0xA0000000 - 0xA1000000(16MB)\n\r");
__asm void JUMP_TO_APP(unsigned long  address)
   // __ASM("LDR SP, [R0]     ;Load new stack pointer address");
   // __ASM("LDR PC, [R0, #4] ;Load new program counter address");
void board_jump_to_app(void)
    //Copy target firmware to SDRAM
   // memcpy((void *)SDRAM_BASE_ADDR,(void *)NOR_FLASH_BASE,NOR_FLASH_SIZE);
      memcpy((void *)SDRAM_BASE_ADDR,(void *)0x0,0x80000);
    __set_MSP(SDRAM_BASE_ADDR);
    JUMP_TO_APP(SDRAM_BASE_ADDR);
int main(void)
         SDRAMInit();//SDRAM驱动         board_mpu_init();
        board_jump_to_app();
我在main函数中调用 board_jump_to_app函数,但是程序就一直停在这里 不会往下走了,各位大神帮帮忙,让程序运行在SDRAM中要如何实现
