将mcc30升级到3.0,问题?
3599|0
 楼主| soso 发表于 2007-5-25 10:18 | 显示全部楼层 |阅读模式
os, pi, pic, ic, ucos
&nbsp;&nbsp;以前都有2.x的版本,早上脑袋发热,将mcc30升级后,一个以前编译无任何警告的工程发生如下警告:<br />Executing:&nbsp;&quot;D:pic30_toolsinpic30-gcc.exe&quot;&nbsp;-c&nbsp;&quot;os_cpu_a.s&quot;&nbsp;-o&quot;os_cpu_a.o&quot;&nbsp;-Wa,-p=30F6014A,--relax,-g,-ahl=&quot;D:ucOS_30FOutos_cpu_a.lst&quot;<br />Resource&nbsp;version&nbsp;(3.00)&nbsp;does&nbsp;not&nbsp;match!<br />Executing:&nbsp;&quot;D:pic30_toolsinpic30-gcc.exe&quot;&nbsp;-mcpu=30F6014A&nbsp;-c&nbsp;-x&nbsp;c&nbsp;&nbsp;-I&quot;D:pic30_toolssupporthperipheral_30F_24H_33F&quot;&nbsp;-I&quot;D:ucOS_30FApp&quot;&nbsp;-I&quot;D:ucOS_30FH&quot;&nbsp;-I&quot;D:pic30_toolssupportinc&quot;&nbsp;-I&quot;d:pic30_toolssupporth&quot;&nbsp;-I&quot;d:ucps_30fsource&quot;&nbsp;-I&quot;d:ucos_30fospart&quot;&nbsp;-I&quot;d:ucos_30f        ask&quot;&nbsp;-I&quot;d:ucos_30fh&quot;&nbsp;&quot;os_cpu_c.c&quot;&nbsp;-o&quot;os_cpu_c.o&quot;&nbsp;-g&nbsp;-Wall&nbsp;-O2<br />pic30-coff-cc1.exe:&nbsp;warning:&nbsp;Resource&nbsp;version&nbsp;(3.00)&nbsp;does&nbsp;not&nbsp;match&nbsp;compiler!<br />Resource&nbsp;version&nbsp;(3.00)&nbsp;does&nbsp;not&nbsp;match!<br />Executing:&nbsp;&quot;D:pic30_toolsinpic30-gcc.exe&quot;&nbsp;-mcpu=30F6014A&nbsp;-c&nbsp;-x&nbsp;c&nbsp;&nbsp;-I&quot;D:pic30_toolssupporthperipheral_30F_24H_33F&quot;&nbsp;-I&quot;D:ucOS_30FApp&quot;&nbsp;-I&quot;D:ucOS_30FH&quot;&nbsp;-I&quot;D:pic30_toolssupportinc&quot;&nbsp;-I&quot;d:pic30_toolssupporth&quot;&nbsp;-I&quot;d:ucps_30fsource&quot;&nbsp;-I&quot;d:ucos_30fospart&quot;&nbsp;-I&quot;d:ucos_30f        ask&quot;&nbsp;-I&quot;d:ucos_30fh&quot;&nbsp;&quot;os_dbg.c&quot;&nbsp;-o&quot;os_dbg.o&quot;&nbsp;-g&nbsp;-Wall&nbsp;-O2<br />pic30-coff-cc1.exe:&nbsp;warning:&nbsp;Resource&nbsp;version&nbsp;(3.00)&nbsp;does&nbsp;not&nbsp;match&nbsp;compiler!<br />Resource&nbsp;version&nbsp;(3.00)&nbsp;does&nbsp;not&nbsp;match!<br />Executing:&nbsp;&quot;D:pic30_toolsinpic30-gcc.exe&quot;&nbsp;-mcpu=30F6014A&nbsp;-c&nbsp;-x&nbsp;c&nbsp;&nbsp;-I&quot;D:pic30_toolssupporthperipheral_30F_24H_33F&quot;&nbsp;-I&quot;D:ucOS_30FApp&quot;&nbsp;-I&quot;D:ucOS_30FH&quot;&nbsp;-I&quot;D:pic30_toolssupportinc&quot;&nbsp;-I&quot;d:pic30_toolssupporth&quot;&nbsp;-I&quot;d:ucps_30fsource&quot;&nbsp;-I&quot;d:ucos_30fospart&quot;&nbsp;-I&quot;d:ucos_30f        ask&quot;&nbsp;-I&quot;d:ucos_30fh&quot;&nbsp;&quot;os_core.c&quot;&nbsp;-o&quot;os_core.o&quot;&nbsp;-g&nbsp;-Wall&nbsp;-O2<br />pic30-coff-cc1.exe:&nbsp;warning:&nbsp;Resource&nbsp;version&nbsp;(3.00)&nbsp;does&nbsp;not&nbsp;match&nbsp;compiler!<br />Resource&nbsp;version&nbsp;(3.00)&nbsp;does&nbsp;not&nbsp;match!<br /><br />......................<br />虽然编译通过,心里不踏实,什么问题?我做程序任何一个警告我都不会放过,心里怕怕的。
