[应用相关] STM32芯片时钟配置
1022|1
 楼主| vigous1 发表于 2015-3-26 23:59 | 显示全部楼层 |阅读模式
    对STM32进行软件开发时,最基本的就是对STM32芯片进行时钟和端口配置,然后是对项目所用到的片上资源进行配置并驱动,下面给出时钟和端口配置代码,该代码几乎涵盖了片上所有时钟和端口配置项目,可根据自己需要进行删除不必要的配置项:
* Function Name : RCC_Configuration     复位时钟控制配置
* Description     : Configures the different system clocks.
* Input           : None
* Output          : None
* Return          : None
void RCC_Configuration(void)
/* system clocks configuration -----------------系统时钟配置-------------------*/
/* RCC system reset(for debug purpose) */
RCC_DeInit();                                     //将外设RCC寄存器重设为缺省值
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);                    //开启外部高速晶振(HSE)
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();    //等待HSE起振
if(HSEStartUpStatus == SUCCESS)               //若成功起振,(下面为系统总线时钟设置)
    /* Enable  Prefetch Buffer */
     FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //使能FLASH预取指缓存
    /* Flash 2  wait state */
     FLASH_SetLatency(FLASH_Latency_2);    //设置FLASH存储器延时时钟周期数(根据不同的系统时钟选取不同的值)
     /* HCLK =  SYSCLK */
     RCC_HCLKConfig(RCC_SYSCLK_Div1);    //设置AHB时钟=72  MHz
    /* PCLK2 =  HCLK/2 */
     RCC_PCLK2Config(RCC_HCLK_Div2);    //设置APB1时钟=36  MHz(APB1时钟最大值)
    /* PCLK1 =  HCLK/2 */
     RCC_PCLK1Config(RCC_HCLK_Div1);    //设置APB2时钟=72  MHz
    /*  Configure ADCCLK such as ADCCLK = PCLK2/2 */
    RCC_ADCCLKConfig(RCC_PCLK2_Div2);  //RCC_PCLK2_Div2,4,6,8
    /* PLLCLK =  8MHz * 9 = 72 MHz */
     RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); //PLL必须在其激活前完成配置(设置PLL时钟源及倍频系数)
    /* Enable PLL  */
     RCC_PLLCmd(ENABLE);
    /* Wait till  PLL is ready */
     while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL  as system clock source */
     RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till  PLL is used as system clock source */
     while(RCC_GetSYSCLKSource() != 0x08)
/* Enable peripheral clocks -----------------外设时钟使能-------------------*/
/* Enable AHB peripheral clocks -----------------AHB外设时钟使能-------------------*/
/* Enable DMA clock */
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,  ENABLE);//使能DMA时钟
/* Enable SRAM clock */
// RCC_AHBPeriphClockCmd(RCC_AHBPeriph_SRAM, ENABLE);//使能SRAM时钟
/* Enable FLITF clock */
// RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FLITF, ENABLE);//使能FLITF时钟
/* Enable APB1 peripheral clocks -----------------APB1外设时钟使能-------------------*/
/* TIM2,3,4 clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,  ENABLE);//使能TIM2时钟    if (APB1 prescaler="1") x1
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,  ENABLE);//使能TIM3时钟   else x2
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,  ENABLE);//使能TIM4时钟
/* WWDG clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG,  ENABLE);//使能WWDG时钟
/* Enable SPI2 clocks */
// RCC_APB1PeriphClockCmd(RCC_APB2Periph_SPI2,  ENABLE);//使能SPI2时钟
/* USART2,3 clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,  ENABLE);//使能USART2时钟(对应万利开发板上的USART1)
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,  ENABLE);//使能USART3时钟(万利开发板上未接该串口)
/* I2C1,2 clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,  ENABLE);//使能I2C1时钟
//  RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);//使能I2C2时钟
/* USB clock enable / PLL clock divided by 1.5 used as  USB clock source */
   // RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);  //根据不同PLLCLK选择分频比,必须确保USBCLK始终是48MHz
   // RCC_APB1PeriphClockCmd(RCC_APB1Periph_USB,  ENABLE);//使能USB时钟
/* CAN clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN,  ENABLE);//使能CAN时钟
/* BKP clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_BKP,  ENABLE);//使能BKP时钟
/* PWR clock enable */
//  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);//使能PWR时钟
/* APB1Periph_ALL clock enable */
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_ALL,  ENABLE);/使能APB1Periph_ALL时钟
/* Enable APB2 peripheral clocks -----------------APB2外设时钟使能-------------------*/
/* Enable GPIOA,B,C,D,E clocks */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,  ENABLE);//使能GPIOA时钟
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,  ENABLE);//使能GPIOB时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,  ENABLE);//使能GPIOC时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD,  ENABLE);//使能GPIOD时钟
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE,  ENABLE);//使能GPIOE时钟
/* AFIO clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,  ENABLE);////使能AFIO时钟
/* Enable ADC1,2clocks */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,  ENABLE);//使能ADC1时钟
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2,  ENABLE);//使能ADC2时钟
/* TIM1 clock enable */
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,  ENABLE);//使能TIM1时钟
/* Enable SPI1 clocks */
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,  ENABLE);//使能SPI1时钟
/* USART1 clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,  ENABLE);//使能USART1时钟(对应万利开发板上的USART0)
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_ALL,  ENABLE);//使能APB2Periph_ALL时钟
/* Enable no peripheral clocks -----------------非总线上外设时钟配置-------------------*/
/* Enable Internal High Speed oscillator */
     //RCC_HSICmd(ENABLE);
   /* Enable the  Internal Low Speed oscillator */
    //RCC_LSICmd(ENABLE); //给IWDG提供时钟信号(如果IWDG运行的话,LSI不能被失能)
    /* Configure  RTCCLK such as ADCCLK = PCLK2/2 */
   // RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);///*  Select the LSE as RTC clock source */
   // RCC_RTCCLKCmd(ENABLE);///* Enable  the RTC clock */
   /* Enable the  Clock Security System */
   //RCC_ClockSecuritySystemCmd(ENABLE);
   /* Output PLL  clock divided by 2 on MCO pin */
   //RCC_MCOConfig(RCC_MCO_PLLCLK_Div2);//  警告:当选中系统时钟作为MCO管脚的输出时,注意它的时钟频率不超过50MHz(最大I/O速率)。
energy1 发表于 2015-3-27 00:05 | 显示全部楼层
