新人求助schematic 综合的一点问题
在综合后 technology schematic中 有数个LUT(如图所示)感觉没有意义属于资源浪费
EDA为ISE14.7
truetable为
input output
0 0
1 1
考虑了一下应该是VHDL编写上的问题,大学中虽然涉及了FPGA 也 在Tutorial 中 学了基本的VHDL编写,但对于此类问题还是感觉无从下手,现在自学并为Msc准备中,希望大牛能告知一下解决方法和原理
code为简单的双向交通灯(FSM based)
具体如下:- library IEEE;
- use IEEE.STD_LOGIC_1164.ALL;
- entity Traffic_light is
- port(clk:in std_logic;
- Test: in std_logic;
- Standby:in std_logic;
- R1,Y1,G1:out std_logic;
- R2,Y2,G2:out std_logic);
- end Traffic_light;
- architecture Behavioral of Traffic_light is
- constant time_max :integer := 2700;
- --The frequency of Clk is 60Hz--
- constant time_RG :integer := 1800;
- --time of light change from red & green(s)--
- constant time_RY :integer := 300;
- --time of light change from red & yellow(s)--
- constant time_GR :integer := 2700;
- --time of light change from green & red(s)--
- constant time_YR :integer := 300;
- --time of light change from yellow & red(s)--
- constant time_test :integer := 60;
- --time for test mode(s)--
- type state is (state_RY,state_GR,state_YR,state_RG,state_YY);
- signal Pr_state,Nx_state: state;
- signal time: integer range 0 to time_max;
- begin
- --lower section of state machine--
- process(clk,standby)
- variable count: integer range 0 to time_max;
- begin
- if (standby = '1') then
- Pr_state <= state_yy;
- elsif (clk'event and clk= '1') then
- count := count +1;
- if (count = time ) then
- Pr_state <= Nx_state;
- count := 0;
- end if;
- end if;
- end process;
- --upper section of state machine--
- process(pr_state,test)
- begin
- case pr_state is
- --state_RY--
- when state_RY =>
- R1 <= '1'; G1 <= '0'; Y1 <= '0';
- R2 <= '0'; G2 <= '0'; Y2 <= '1';
- Nx_state <= state_GR;
- if (test = '0') then time <= time_RY;
- else time <= time_test;
- end if;
- --state_GR--
- when state_GR =>
- R1 <= '0'; G1 <= '1'; Y1 <= '0';
- R2 <= '1'; G2 <= '0'; Y2 <= '0';
- Nx_state <= state_YR;
- if (test = '0') then time <= time_GR;
- end if;
- --state_YR--
- when state_YR =>
- R1 <= '0'; G1 <= '0'; Y1 <= '1';
- Nx_state <= state_RG;
- if (test = '0') then time <= time_YR;
- end if;
- --state_RG--
- when state_RG =>
- R2 <= '0'; G2 <= '1'; Y2 <= '0';
- Nx_state <= state_RY;
- if (test = '0') then time <= time_RG;
- end if;
- when others =>
- end case;
- end process;
- end Behavioral;
