RGB LED Signal Tower With IO-Link Interface Reference Design
953|6
dirtwillfly|  楼主 | 2017-4-11 20:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Description
The objective of the TIDA-00980 reference design is to develop an embedded firmware to interface and control the functions of a multi-segment RGB signal tower used in factory floor and industrial process automation of greater complexity. This design helps to give more flexible usage along with a sequence of terminal commands. The stack light can be controlled either via IO-Link or USB and different patterns can be configured.
Features
  • Flexible and easy-to-control RGB LED tower light design
  • Different switchable modes: demo, temperature, humidity and IO-link
  • Controllable RGB color, brightness, row and blinking speed
  • One to five RGB LED segments with four individual channels each
  • Adjustable maximum LED current up to 60 mA per channel
dirtwillfly|  楼主 | 2017-4-11 20:23 | 只看该作者
RGB LED Signal Tower With IO-Link Interface Reference Design.pdf (4.23 MB)
dirtwillfly|  楼主 | 2017-4-11 20:31 | 只看该作者
TIDA-00339 Schematic.pdf (929.64 KB)
TIDA-00339 BOM.pdf (86.25 KB)
TIDA-00339 Assembly Drawing.pdf (117.68 KB)
TIDA-00339 PCB.pdf (1.09 MB)
TIDA-00339 CAD Files.zip (1.52 MB)
TIDA-00339 Gerber.zip (459.46 KB)
dirtwillfly|  楼主 | 2017-4-11 20:32 | 只看该作者
jkl21| | 2017-4-11 21:58 | 只看该作者
jkl21| | 2017-4-11 21:59 | 只看该作者
dirtwillfly|  楼主 | 2017-4-12 07:53 | 只看该作者
jkl21 发表于 2017-4-11 21:59
http://www.ti.com/tool/TIDA-00339?HQS=SYS-null-null-findchips-refdes-rd-null-wwe
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
