实习生
- 积分
- 3
- 在线时间
- 1 小时
- 精华
- 0
- 注册时间
- 2018-6-27
- 最后登录
- 2018-12-5
*** Using Compiler 'V5.06 update 5 (build 528)', folder: 'H:\MDK5\ARM\ARMCC\Bin'
Build target '多彩流水灯'
assembling startup_stm32f429_439xx.s...
startup_stm32f429_439xx.s: Error: A9511E: Unable to determine the current toolkit. Check that ARM_TOOL_VARIANT is set correctly.
startup_stm32f429_439xx.s: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at:
startup_stm32f429_439xx.s: http://www.keil.com/support/man/docs/license/license_management.htm
startup_stm32f429_439xx.s: If you need further help, provide this complete error report to your supplier or license.support@arm.com.
startup_stm32f429_439xx.s: - ARMLMD_LICENSE_FILE: unset
startup_stm32f429_439xx.s: - LM_LICENSE_FILE: unset
startup_stm32f429_439xx.s: - ARM_TOOL_VARIANT: unset
startup_stm32f429_439xx.s: - ARM_PRODUCT_PATH: unset
startup_stm32f429_439xx.s: - Product location: product not found
startup_stm32f429_439xx.s: - Toolchain location: H:\MDK5\ARM\ARMCC\Bin
startup_stm32f429_439xx.s: - Selected tool variant: mdk_cm_pro
startup_stm32f429_439xx.s: Product: unknown
startup_stm32f429_439xx.s: Component: ARM Compiler 5.06 update 5 (build 528)
startup_stm32f429_439xx.s: Tool: ArmAsm [4d35e1]
compiling system_stm32f4xx.c...
Error: C9511E: Unable to determine the current toolkit. Check that ARM_TOOL_VARIANT is set correctly.
Product: unknown
Tool: ArmCC [4d3621]
compiling misc.c...
Check that your license details are correct in the License Management dialog of MDK. Additional information is available at: |
