[中文设计文档]
TMS320F28027中SCI-FIFO求助
265|0
一刀一级|  楼主 | 2020-11-3 14:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一直没有理解SCI中FIFO堆栈,例程中的红色字体的数据流是怎样发送与接收的呢?开始发送的是00么?接收到的数据是存在FIFO中还是RXBUFER中呢?例程中rdataA=SciaRegs.SCIRXBUF.all;         // Read data  初学DSP太多有不明白的,跪求大神,虚心受教
// TI File $Revision: /main/3 $
// Checkin $Date: December 17, 2009   14:36:39 $
// FILE:   Example_2802xSci_FFDLB_int.c
// TITLE:  DSP2802x Device SCI Digital Loop Back porgram.
// ASSUMPTIONS:
//    This program requires the DSP2802x header files.
//    This program uses the internal loop back test mode of the peripheral.
//    Other then boot mode pin configuration, no other hardware configuration
//    is required.
//    As supplied, this project is configured for "boot to SARAM"
//    operation.  The 2802x Boot Mode table is shown below.
//    For information on configuring the boot mode of an eZdsp,
//    please refer to the documentation included with the eZdsp,
//    $Boot_Table
//    While an emulator is connected to y**ice, the TRSTn pin = 1,
//    which sets the device into EMU_BOOT boot mode. In this mode, the
//    peripheral boot modes are as follows:
//      Boot Mode:   EMU_KEY        EMU_BMODE
//                   (0xD00)             (0xD01)
//      Wait                 !=0x55AA        X
//      I/O                     0x55AA                 0x0000
//      SCI                     0x55AA                 0x0001
//      Wait              0x55AA                 0x0002
//      Get_Mode         0x55AA                 0x0003
//      SPI                     0x55AA                 0x0004
//      I2C                     0x55AA                 0x0005
//      OTP                     0x55AA                 0x0006
//      Wait                 0x55AA                 0x0007
//      Wait                 0x55AA                 0x0008
//      SARAM                 0x55AA                 0x000A          <-- "Boot to SARAM"
//      Flash                 0x55AA                 0x000B
//            Wait                 0x55AA          Other
//   Write EMU_KEY to 0xD00 and EMU_BMODE to 0xD01 via the debugger
//   according to the Boot Mode Table above. Build/Load project,
//   Reset the device, and Run example
//   $End_Boot_Table
//   Assumes the device has both SCI-A and SCI-B peripherals.
// DESCRIPTION:
//    This program is a SCI example that uses the internal loopback of
//    the peripheral.  Both interrupts and the SCI FIFOs are used.
//    A stream of data is sent and then compared to the recieved stream.
//    The SCI-A sent data looks like this:
//    00 01
//    01 02
//    02 03
//    FE FF
//    FF 00
//    etc..
//    The pattern is repeated forever.
//    Watch Variables:
//       sdataA             Data being sent
//       rdataA             Data received
//       rdata_pointA       Keep track of where we are in the datastream
//                         This is used to check the incoming data
// Original Source by S.D.
// $TI Release: 2802x Header Files V1.27 $
// $Release Date: June 28, 2010 $
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
#define CPU_FREQ         6E6        // Default = 40 MHz. Change to 60E6 for 60 MHz devices
#define LSPCLK_FREQ CPU_FREQ/4
#define SCI_FREQ         100E3
#define SCI_PRD         (LSPCLK_FREQ/(SCI_FREQ*8))-1
// Prototype statements for functions found within this file.
interrupt void sciaTxFifoIsr(void);
interrupt void sciaRxFifoIsr(void);
interrupt void scibTxFifoIsr(void);
interrupt void scibRxFifoIsr(void);
void scia_fifo_init(void);
void scib_fifo_init(void);
void error(void);
// Global variables
Uint16 sdataA[2];    // Send data for SCI-A
Uint16 rdataA[2];    // Received data for SCI-A
Uint16 rdata_pointA; // Used for checking the received data
void main(void)
   Uint16 i;
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2802x_SysCtrl.c file.
   InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP2802x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio();
// Setup only the GP I/O only for SCI-A and SCI-B functionality
// This function is found in DSP2802x_Sci.c
   InitSciGpio();
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
   DINT;
// Initialize PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2802x_PieCtrl.c file.
   InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example.  This is useful for debug purposes.
// The shell ISR routines are found in DSP2802x_DefaultIsr.c.
// This function is found in DSP2802x_PieVect.c.
   InitPieVectTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
   EALLOW;        // This is needed to write to EALLOW protected registers
   PieVectTable.SCIRXINTA = &sciaRxFifoIsr;
   PieVectTable.SCITXINTA = &sciaTxFifoIsr;
   EDIS;   // This is needed to disable write to EALLOW protected registers
// Step 4. Initialize all the Device Peripherals:
// This function is found in DSP2802x_InitPeripherals.c
// InitPeripherals(); // Not required for this example
   scia_fifo_init();  // Init SCI-A
// Step 5. User specific code, enable interrupts:
// Init send data.  After each transmission this data
// will be updated for the next transmission
   for(i = 0; i<2; i++)
      sdataA = i;
   rdata_pointA = sdataA[0];
// Enable interrupts required for this example
   PieCtrlRegs.PIECTRL.bit.ENPIE = 1;   // Enable the PIE block
   PieCtrlRegs.PIEIER9.bit.INTx1=1;     // PIE Group 9, INT1
   PieCtrlRegs.PIEIER9.bit.INTx2=1;     // PIE Group 9, INT2
   IER = 0x100;        // Enable CPU INT
   EINT;
// Step 6. IDLE loop. Just sit and loop forever (optional):
        for(;;);
void error(void)
    asm("     ESTOP0"); // Test failed!! Stop!
    for (;;);
    Uint16 i;
    for(i=0; i< 2; i++)
           SciaRegs.SCITXBUF=sdataA;     // Send data
    for(i=0; i< 2; i++)                 //Increment send data for next cycle
           sdataA = (sdataA+1) & 0x00FF;
        SciaRegs.SCIFFTX.bit.TXFFINTCLR=1;        // Clear SCI Interrupt flag
        PieCtrlRegs.PIEACK.all|=0x100;      // Issue PIE ACK
    Uint16 i;
        for(i=0;i<2;i++)
        for(i=0;i<2;i++)                     // Check received data
           if(rdataA != ( (rdata_pointA+i) & 0x00FF) ) error();
        rdata_pointA = (rdata_pointA+1) & 0x00FF;
        SciaRegs.SCIFFRX.bit.RXFFOVRCLR=1;   // Clear Overflow flag
        SciaRegs.SCIFFRX.bit.RXFFINTCLR=1;   // Clear Interrupt flag
        PieCtrlRegs.PIEACK.all|=0x100;       // Issue PIE ack
void scia_fifo_init()
   SciaRegs.SCICCR.all =0x0007;   // 1 stop bit,  No loopback
                                  // No parity,8 char bits,
                                  // async mode, idle-line protocol
   SciaRegs.SCICTL1.all =0x0003;  // enable TX, RX, internal SCICLK,
                                  // Disable RX ERR, SLEEP, TXWAKE
   SciaRegs.SCICTL2.bit.TXINTENA =1;
   SciaRegs.SCICTL2.bit.RXBKINTENA =1;
   SciaRegs.SCIHBAUD = 0x0000;
   SciaRegs.SCILBAUD = SCI_PRD;
   SciaRegs.SCICCR.bit.LOOPBKENA =1; // Enable loop back
   SciaRegs.SCIFFTX.all=0xC022;
   SciaRegs.SCIFFRX.all=0x0022;
   SciaRegs.SCIFFCT.all=0x00;
   SciaRegs.SCICTL1.all =0x0023;     // Relinquish SCI from Reset
   SciaRegs.SCIFFTX.bit.TXFIFOXRESET=1;
   SciaRegs.SCIFFRX.bit.RXFIFORESET=1;
// No more.
