[MCU]
TM4C123GH6PZ用JFLASH烧写HEX文件时报错
351|0
laocuo1142|  楼主 | 2020-11-6 11:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Auto programming target (262144 bytes, 1 range) ...
- Checking if selected data fits into selected flash sectors.
- Start of preparing flash programming
- End of preparing flash programming
- Start of determining dirty areas in flash cache
- End of determining dirty areas
- CPU is running at 15839 kHz.
- Start of erasing sectors
- Blank checking 0x00000000 - 0x0001FFFF
- Blank checking 0x00020000 - 0x0003FFFF
- End of erasing sectors
- Start of flash programming
- Programming range 0x00000000 - 0x00007FFF (032 Sectors, 32 KB)
- ERROR: Programming failed @ address 0x00000240 (block verification error)
- End of flash programming
- ERROR: Program failed
- ERROR: Failed to auto program target
Disconnecting ...
- Disconnected
现在又有新的情况,连接成功,擦除成功,烧写时报错了。
