3.顶层
- module uart_top(
- input CLK,
- input RSTn,
- input rs232_rx,
- output rs232_tx
- //***************Main Code*************//
- wire [7:0] rx_data;
- wire tx_trig;
- //reg rs232_tx_t;
- uart_rx uart_rx_inst(.CLK (CLK ),
- .RSTn (RSTn ),
- .rs232_rx (rs232_rx ),
- .rx_data (rx_data ),
- .po_flag (tx_trig ));
- uart_tx uart_tx_inst(.CLK (CLK ),
- .RSTn (RSTn ),
- .tx_data (rx_data ),
- .tx_trig (tx_trig ),
- .rs232_tx (rs232_tx ));
- endmodule
testbench:
- module uart_tb;
- reg CLK;
- reg RSTn;
- reg rs232_rx;
- wire rs232_tx;
- reg [7:0] mem [4:0];
- initial $readmemh ("D:/Project/verilog_pro/project_module/sdram_controller/src/tx_data.txt",mem);
- initial
- begin
- RSTn = 0;
- //rs232_tx = 1;
- #100
- RSTn = 1;
- #100
- tx_byte();
- end
- initial
- begin
- CLK = 0;
- forever #5 CLK = ~CLK;
- end
- task tx_byte();
- integer i;
- for (i = 0; i < 5;i=i+1 )
- begin
- tx_bit(mem[i]);
- end
- endtask
- task tx_bit(
- input [7:0] data
- integer i;
- for (i = 0; i < 10;i=i+1 )
- begin
- case(i)
- 0: rs232_rx <= 1'b0;
- 1: rs232_rx <= data [0];
- 2: rs232_rx <= data [1];
- 3: rs232_rx <= data [2];
- 4: rs232_rx <= data [3];
- 5: rs232_rx <= data [4];
- 6: rs232_rx <= data [5];
- 7: rs232_rx <= data [6];
- 8: rs232_rx <= data [7];
- 9: rs232_rx <= 1'b1;
- endcase
- #560;
- end
- endtask
- uart_top uart_inst(.CLK (CLK),
- .RSTn (RSTn),
- .rs232_rx (rs232_rx),
- .rs232_tx (rs232_tx));
- endmodule
