[Verilog HDL] 用verilog描述ROM遇到问题,请各位帮忙纠错
2414|3
 楼主| vol2088 发表于 2013-10-14 08:37 | 显示全部楼层 |阅读模式
源码如下:
module BIOS_ROM(addr[7:0],data[7:0]);
input [7:0]addr;
output[7:0]data;
reg [7:0]rom_data[255:0];
initial $readmemb("test.mif", rom_data);
assign data = rom_data[addr];
endmodule
module CPU_1(led[3:0],clk);
input clk;
output [3:0]led;
wire [7:0]data1;
wire [7:0]addr1;
parameter times = 23'd 5_000_000;
reg [31:0]T,timer;
reg [7:0]addr2;
BIOS_ROM ROM1(addr1[7:0],data1[7:0]);
assign led = data1 >> 4;
assign addr1 = addr2;
always@(posedge clk)
begin
        if(T == times)
                begin
                        T <= 32'd0;
                        timer <= ~timer;
                end
        else
                T <= T + 32'd1;
end
always@(posedge timer)
begin
        addr2 <= addr2 + 1'b1;
end
endmodule
Error (10170): Verilog HDL syntax error at test.mif(1) near text -
Error: Can't elaborate user hierarchy "BIOS_ROM:ROM1"
nxszbjyxoxo 发表于 2013-10-14 08:51 | 显示全部楼层
gaochy1126 发表于 2013-10-31 23:43 | 显示全部楼层
直接使用ip核的。
自己描述有些麻烦的。
