alexant的笔记 https://bbs.21ic.com/?72205 [收藏] [复制] [RSS] 这里记录的是我上网时发现的一些比较好的文章和比较值得记录的知识,希望对大家有点帮助。
日志
原创:我在项目中的FreeRTOS源码-FreeRTOSConfig.h
已有 1263 次阅读2007-3-21 20:17 |系统分类:ARM
 FreeRTOS.org V4.0.2 - Copyright (C) 2003-2006 Richard Barry.
 This file is part of the FreeRTOS.org distribution.
 FreeRTOS.org is free software; you can redistribute it and/or modify
 it under the terms of the GNU General Public License as published by
 the Free Software Foundation; either version 2 of the License, or
 (at your option) any later version.
 FreeRTOS.org is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 GNU General Public License for more details.
 You should have received a copy of the GNU General Public License
 along with FreeRTOS.org; if not, write to the Free Software
 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
 A special exception to the GPL can be applied should you wish to distribute
 a combined work that includes FreeRTOS.org, without being obliged to provide
 the source code for any proprietary components.  See the licensing section
 of http://www.FreeRTOS.org for full details of how and when the exception
 can be applied.
 See http://www.FreeRTOS.org for documentation, latest information, license
 and contact details.  Please ensure to read the configuration and relevant
 port sections of the online documentation.
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
#include "lpc214x.h"
 * Application specific definitions.
 * These definitions should be adjusted for your particular hardware and
 * application requirements.
 * THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
 * FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
#define configUSE_PREEMPTION  1
#define configUSE_IDLE_HOOK   1
#define configUSE_TICK_HOOK   0
#define configCPU_CLOCK_HZ   ( FRQ_XTL*PLL_MUL )
#define configTICK_RATE_HZ   ( ( portTickType ) 1000 )
#define configMAX_PRIORITIES  ( ( unsigned portBASE_TYPE ) 5 )
#define configMINIMAL_STACK_SIZE ( ( unsigned portSHORT ) 128 )
#define configTOTAL_HEAP_SIZE  ( ( size_t ) ( 4 * 1024 ) )
#define configMAX_TASK_NAME_LEN  ( 16 )
#define configUSE_TRACE_FACILITY 0
#define configUSE_16_BIT_TICKS  0
#define configIDLE_SHOULD_YIELD  1
/* Co-routine definitions. */
#define configUSE_CO_ROUTINES   0
#define configMAX_CO_ROUTINE_PRIORITIES ( 0 )
/* Set the following definitions to 1 to include the API function, or zero
to exclude the API function. */
#define INCLUDE_vTaskPrioritySet  0
#define INCLUDE_uxTaskPriorityGet  0
#define INCLUDE_vTaskDelete    0
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskSuspend   1
#define INCLUDE_vTaskDelayUntil   1
#define INCLUDE_vTaskDelay    1
#endif /* FREERTOS_CONFIG_H */
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
