alexant的笔记 https://bbs.21ic.com/?72205 [收藏] [复制] [RSS] 这里记录的是我上网时发现的一些比较好的文章和比较值得记录的知识,希望对大家有点帮助。
日志
原创:我在项目中的FreeRTOS源码-lpc214x.h
已有 1839 次阅读2007-3-21 20:18 |系统分类:ARM
/*  This file is part of the uVision/ARM development tools             */
/*  Copyright KEIL ELEKTRONIK GmbH 2002-2005                           */
/*  LPC214X.H:  Header file for Philips LPC2141/42/44/46/48            */
#ifndef __LPC214x_H
#define __LPC214x_H
/* Vectored Interrupt Controller (VIC) */
#define VICIRQStatus    (*((volatile unsigned long *) 0xFFFFF000))
#define VICFIQStatus    (*((volatile unsigned long *) 0xFFFFF004))
#define VICRawIntr      (*((volatile unsigned long *) 0xFFFFF008))
#define VICIntSelect    (*((volatile unsigned long *) 0xFFFFF00C))
#define VICIntEnable    (*((volatile unsigned long *) 0xFFFFF010))
#define VICIntEnClr     (*((volatile unsigned long *) 0xFFFFF014))
#define VICSoftInt      (*((volatile unsigned long *) 0xFFFFF018))
#define VICSoftIntClr   (*((volatile unsigned long *) 0xFFFFF01C))
#define VICProtection   (*((volatile unsigned long *) 0xFFFFF020))
#define VICVectAddr     (*((volatile unsigned long *) 0xFFFFF030))
#define VICDefVectAddr  (*((volatile unsigned long *) 0xFFFFF034))
#define VICVectAddr0    (*((volatile unsigned long *) 0xFFFFF100))
#define VICVectAddr1    (*((volatile unsigned long *) 0xFFFFF104))
#define VICVectAddr2    (*((volatile unsigned long *) 0xFFFFF108))
#define VICVectAddr3    (*((volatile unsigned long *) 0xFFFFF10C))
#define VICVectAddr4    (*((volatile unsigned long *) 0xFFFFF110))
#define VICVectAddr5    (*((volatile unsigned long *) 0xFFFFF114))
#define VICVectAddr6    (*((volatile unsigned long *) 0xFFFFF118))
#define VICVectAddr7    (*((volatile unsigned long *) 0xFFFFF11C))
#define VICVectAddr8    (*((volatile unsigned long *) 0xFFFFF120))
#define VICVectAddr9    (*((volatile unsigned long *) 0xFFFFF124))
#define VICVectAddr10   (*((volatile unsigned long *) 0xFFFFF128))
#define VICVectAddr11   (*((volatile unsigned long *) 0xFFFFF12C))
#define VICVectAddr12   (*((volatile unsigned long *) 0xFFFFF130))
#define VICVectAddr13   (*((volatile unsigned long *) 0xFFFFF134))
#define VICVectAddr14   (*((volatile unsigned long *) 0xFFFFF138))
#define VICVectAddr15   (*((volatile unsigned long *) 0xFFFFF13C))
#define VICVectCntl0    (*((volatile unsigned long *) 0xFFFFF200))
#define VICVectCntl1    (*((volatile unsigned long *) 0xFFFFF204))
#define VICVectCntl2    (*((volatile unsigned long *) 0xFFFFF208))
#define VICVectCntl3    (*((volatile unsigned long *) 0xFFFFF20C))
#define VICVectCntl4    (*((volatile unsigned long *) 0xFFFFF210))
#define VICVectCntl5    (*((volatile unsigned long *) 0xFFFFF214))
#define VICVectCntl6    (*((volatile unsigned long *) 0xFFFFF218))
#define VICVectCntl7    (*((volatile unsigned long *) 0xFFFFF21C))
#define VICVectCntl8    (*((volatile unsigned long *) 0xFFFFF220))
#define VICVectCntl9    (*((volatile unsigned long *) 0xFFFFF224))
#define VICVectCntl10   (*((volatile unsigned long *) 0xFFFFF228))
#define VICVectCntl11   (*((volatile unsigned long *) 0xFFFFF22C))
#define VICVectCntl12   (*((volatile unsigned long *) 0xFFFFF230))
#define VICVectCntl13   (*((volatile unsigned long *) 0xFFFFF234))
#define VICVectCntl14   (*((volatile unsigned long *) 0xFFFFF238))
#define VICVectCntl15   (*((volatile unsigned long *) 0xFFFFF23C))
/* Pin Connect Block */
#define PINSEL0         (*((volatile unsigned long *) 0xE002C000))
#define PINSEL1         (*((volatile unsigned long *) 0xE002C004))
#define PINSEL2         (*((volatile unsigned long *) 0xE002C014))
/* General Purpose Input/Output (GPIO) */
#define IOPIN0          (*((volatile unsigned long *) 0xE0028000))
#define IOSET0          (*((volatile unsigned long *) 0xE0028004))
#define IODIR0          (*((volatile unsigned long *) 0xE0028008))
#define IOCLR0          (*((volatile unsigned long *) 0xE002800C))
#define IOPIN1          (*((volatile unsigned long *) 0xE0028010))
#define IOSET1          (*((volatile unsigned long *) 0xE0028014))
#define IODIR1          (*((volatile unsigned long *) 0xE0028018))
#define IOCLR1          (*((volatile unsigned long *) 0xE002801C))
#define IO0PIN          (*((volatile unsigned long *) 0xE0028000))
#define IO0SET          (*((volatile unsigned long *) 0xE0028004))
#define IO0DIR          (*((volatile unsigned long *) 0xE0028008))
#define IO0CLR          (*((volatile unsigned long *) 0xE002800C))
#define IO1PIN          (*((volatile unsigned long *) 0xE0028010))
#define IO1SET          (*((volatile unsigned long *) 0xE0028014))
#define IO1DIR          (*((volatile unsigned long *) 0xE0028018))
#define IO1CLR          (*((volatile unsigned long *) 0xE002801C))
#define FIO0DIR         (*((volatile unsigned long *) 0x3FFFC000))
#define FIO0MASK        (*((volatile unsigned long *) 0x3FFFC010))
#define FIO0PIN         (*((volatile unsigned long *) 0x3FFFC014))
#define FIO0SET         (*((volatile unsigned long *) 0x3FFFC018))
#define FIO0CLR         (*((volatile unsigned long *) 0x3FFFC01C))
#define FIO1DIR         (*((volatile unsigned long *) 0x3FFFC020))
#define FIO1DIR2        (*((volatile unsigned long *) 0x3FFFC022))
#define FIO1DIR3        (*((volatile unsigned long *) 0x3FFFC023))
#define FIO1MASK        (*((volatile unsigned long *) 0x3FFFC030))
#define FIO1MASK2       (*((volatile unsigned long *) 0x3FFFC032))
#define FIO1MASK3       (*((volatile unsigned long *) 0x3FFFC033))
#define FIO1PIN         (*((volatile unsigned long *) 0x3FFFC034))
#define FIO1PIN2        (*((volatile unsigned long *) 0x3FFFC036))
#define FIO1PIN3        (*((volatile unsigned long *) 0x3FFFC037))
#define FIO1SET         (*((volatile unsigned long *) 0x3FFFC038))
#define FIO1SET2        (*((volatile unsigned long *) 0x3FFFC03A))
#define FIO1SET3        (*((volatile unsigned long *) 0x3FFFC03B))
#define FIO1CLR         (*((volatile unsigned long *) 0x3FFFC03C))
#define FIO1CLR2        (*((volatile unsigned long *) 0x3FFFC03E))
#define FIO1CLR3        (*((volatile unsigned long *) 0x3FFFC03F))
/* Memory Accelerator Module (MAM) */
#define MAMCR           (*((volatile unsigned char *) 0xE01FC000))
#define MAMTIM          (*((volatile unsigned char *) 0xE01FC004))
#define MEMMAP          (*((volatile unsigned char *) 0xE01FC040))
/* Phase Locked Loop 0 (PLL0) */
#define PLL0CON         (*((volatile unsigned char *) 0xE01FC080))
#define PLL0CFG         (*((volatile unsigned char *) 0xE01FC084))
#define PLL0STAT        (*((volatile unsigned short*) 0xE01FC088))
#define PLL0FEED        (*((volatile unsigned char *) 0xE01FC08C))
/* Phase Locked Loop 1 (PLL1) */
#define PLL1CON         (*((volatile unsigned char *) 0xE01FC0A0))
#define PLL1CFG         (*((volatile unsigned char *) 0xE01FC0A4))
#define PLL1STAT        (*((volatile unsigned short*) 0xE01FC0A8))
#define PLL1FEED        (*((volatile unsigned char *) 0xE01FC0AC))
/* VPB Divider */
#define VPBDIV          (*((volatile unsigned char *) 0xE01FC100))
/* Power Control */
#define PCON            (*((volatile unsigned char *) 0xE01FC0C0))
#define PCONP           (*((volatile unsigned long *) 0xE01FC0C4))
/* External Interrupts */
#define EXTINT          (*((volatile unsigned char *) 0xE01FC140))
#define INTWAKE         (*((volatile unsigned short*) 0xE01FC144))
#define EXTMODE         (*((volatile unsigned char *) 0xE01FC148))
#define EXTPOLAR        (*((volatile unsigned char *) 0xE01FC14C))
/* Reset */
#define RSID            (*((volatile unsigned char *) 0xE01FC180))
/* Code Security / Debugging */
#define CSPR            (*((volatile unsigned char *) 0xE01FC184))
/* System Control Miscellaneous */
#define SCS             (*((volatile unsigned long *) 0xE01FC1A0))
/* Timer 0 */
#define T0IR            (*((volatile unsigned long *) 0xE0004000))
#define T0TCR           (*((volatile unsigned long *) 0xE0004004))
#define T0TC            (*((volatile unsigned long *) 0xE0004008))
#define T0PR            (*((volatile unsigned long *) 0xE000400C))
#define T0PC            (*((volatile unsigned long *) 0xE0004010))
#define T0MCR           (*((volatile unsigned long *) 0xE0004014))
#define T0MR0           (*((volatile unsigned long *) 0xE0004018))
#define T0MR1           (*((volatile unsigned long *) 0xE000401C))
#define T0MR2           (*((volatile unsigned long *) 0xE0004020))
#define T0MR3           (*((volatile unsigned long *) 0xE0004024))
#define T0CCR           (*((volatile unsigned long *) 0xE0004028))
#define T0CR0           (*((volatile unsigned long *) 0xE000402C))
#define T0CR1           (*((volatile unsigned long *) 0xE0004030))
#define T0CR2           (*((volatile unsigned long *) 0xE0004034))
#define T0CR3           (*((volatile unsigned long *) 0xE0004038))
#define T0EMR           (*((volatile unsigned long *) 0xE000403C))
#define T0CTCR          (*((volatile unsigned long *) 0xE0004070))
/* Timer 1 */
#define T1IR            (*((volatile unsigned long *) 0xE0008000))
#define T1TCR           (*((volatile unsigned long *) 0xE0008004))
#define T1TC            (*((volatile unsigned long *) 0xE0008008))
#define T1PR            (*((volatile unsigned long *) 0xE000800C))
#define T1PC            (*((volatile unsigned long *) 0xE0008010))
#define T1MCR           (*((volatile unsigned long *) 0xE0008014))
#define T1MR0           (*((volatile unsigned long *) 0xE0008018))
#define T1MR1           (*((volatile unsigned long *) 0xE000801C))
#define T1MR2           (*((volatile unsigned long *) 0xE0008020))
#define T1MR3           (*((volatile unsigned long *) 0xE0008024))
#define T1CCR           (*((volatile unsigned long *) 0xE0008028))
#define T1CR0           (*((volatile unsigned long *) 0xE000802C))
#define T1CR1           (*((volatile unsigned long *) 0xE0008030))
#define T1CR2           (*((volatile unsigned long *) 0xE0008034))
#define T1CR3           (*((volatile unsigned long *) 0xE0008038))
#define T1EMR           (*((volatile unsigned long *) 0xE000803C))
#define T1CTCR          (*((volatile unsigned long *) 0xE0008070))
/* Pulse Width Modulator (PWM) */
#define PWMIR           (*((volatile unsigned long *) 0xE0014000))
#define PWMTCR          (*((volatile unsigned long *) 0xE0014004))
#define PWMTC           (*((volatile unsigned long *) 0xE0014008))
#define PWMPR           (*((volatile unsigned long *) 0xE001400C))
#define PWMPC           (*((volatile unsigned long *) 0xE0014010))
#define PWMMCR          (*((volatile unsigned long *) 0xE0014014))
#define PWMMR0          (*((volatile unsigned long *) 0xE0014018))
#define PWMMR1          (*((volatile unsigned long *) 0xE001401C))
#define PWMMR2          (*((volatile unsigned long *) 0xE0014020))
#define PWMMR3          (*((volatile unsigned long *) 0xE0014024))
#define PWMMR4          (*((volatile unsigned long *) 0xE0014040))
#define PWMMR5          (*((volatile unsigned long *) 0xE0014044))
#define PWMMR6          (*((volatile unsigned long *) 0xE0014048))
#define PWMPCR          (*((volatile unsigned long *) 0xE001404C))
#define PWMLER          (*((volatile unsigned long *) 0xE0014050))
/* Universal Asynchronous Receiver Transmitter 0 (UART0) */
#define U0RBR           (*((volatile unsigned char *) 0xE000C000))
#define U0THR           (*((volatile unsigned char *) 0xE000C000))
#define U0IER           (*((volatile unsigned long *) 0xE000C004))
#define U0IIR           (*((volatile unsigned long *) 0xE000C008))
#define U0FCR           (*((volatile unsigned char *) 0xE000C008))
#define U0LCR           (*((volatile unsigned char *) 0xE000C00C))
#define U0MCR           (*((volatile unsigned char *) 0xE000C010))
#define U0LSR           (*((volatile unsigned char *) 0xE000C014))
#define U0MSR           (*((volatile unsigned char *) 0xE000C018))
#define U0SCR           (*((volatile unsigned char *) 0xE000C01C))
#define U0DLL           (*((volatile unsigned char *) 0xE000C000))
#define U0DLM           (*((volatile unsigned char *) 0xE000C004))
#define U0ACR           (*((volatile unsigned long *) 0xE000C020))
#define U0FDR           (*((volatile unsigned long *) 0xE000C028))
#define U0TER           (*((volatile unsigned char *) 0xE000C030))
/* Universal Asynchronous Receiver Transmitter 1 (UART1) */
#define U1RBR           (*((volatile unsigned char *) 0xE0010000))
#define U1THR           (*((volatile unsigned char *) 0xE0010000))
#define U1IER           (*((volatile unsigned long *) 0xE0010004))
#define U1IIR           (*((volatile unsigned long *) 0xE0010008))
#define U1FCR           (*((volatile unsigned char *) 0xE0010008))
#define U1LCR           (*((volatile unsigned char *) 0xE001000C))
#define U1MCR           (*((volatile unsigned char *) 0xE0010010))
#define U1LSR           (*((volatile unsigned char *) 0xE0010014))
#define U1MSR           (*((volatile unsigned char *) 0xE0010018))
#define U1SCR           (*((volatile unsigned char *) 0xE001001C))
#define U1DLL           (*((volatile unsigned char *) 0xE0010000))
#define U1DLM           (*((volatile unsigned char *) 0xE0010004))
#define U1ACR           (*((volatile unsigned long *) 0xE0010020))
#define U1FDR           (*((volatile unsigned long *) 0xE0010028))
#define U1TER           (*((volatile unsigned char *) 0xE0010030))
/* I2C Interface 0 */
#define I2C0CONSET      (*((volatile unsigned char *) 0xE001C000))
#define I2C0STAT        (*((volatile unsigned char *) 0xE001C004))
#define I2C0DAT         (*((volatile unsigned char *) 0xE001C008))
#define I2C0ADR         (*((volatile unsigned char *) 0xE001C00C))
#define I2C0SCLH        (*((volatile unsigned short*) 0xE001C010))
#define I2C0SCLL        (*((volatile unsigned short*) 0xE001C014))
#define I2C0CONCLR      (*((volatile unsigned char *) 0xE001C018))
/* I2C Interface 1 */
#define I2C1CONSET      (*((volatile unsigned char *) 0xE005C000))
#define I2C1STAT        (*((volatile unsigned char *) 0xE005C004))
#define I2C1DAT         (*((volatile unsigned char *) 0xE005C008))
#define I2C1ADR         (*((volatile unsigned char *) 0xE005C00C))
#define I2C1SCLH        (*((volatile unsigned short*) 0xE005C010))
#define I2C1SCLL        (*((volatile unsigned short*) 0xE005C014))
#define I2C1CONCLR      (*((volatile unsigned char *) 0xE005C018))
/* SPI0 (Serial Peripheral Interface 0) */
#define S0SPCR          (*((volatile unsigned short*) 0xE0020000))
#define S0SPSR          (*((volatile unsigned char *) 0xE0020004))
#define S0SPDR          (*((volatile unsigned short*) 0xE0020008))
#define S0SPCCR         (*((volatile unsigned char *) 0xE002000C))
#define S0SPINT         (*((volatile unsigned char *) 0xE002001C))
/* SSP Controller (SPI1) */
#define SSPCR0          (*((volatile unsigned short*) 0xE0068000))
#define SSPCR1          (*((volatile unsigned char *) 0xE0068004))
#define SSPDR           (*((volatile unsigned short*) 0xE0068008))
#define SSPSR           (*((volatile unsigned char *) 0xE006800C))
#define SSPCPSR         (*((volatile unsigned char *) 0xE0068010))
#define SSPIMSC         (*((volatile unsigned char *) 0xE0068014))
#define SSPRIS          (*((volatile unsigned char *) 0xE0068018))
#define SSPMIS          (*((volatile unsigned char *) 0xE006801C))
#define SSPICR          (*((volatile unsigned char *) 0xE0068020))
/* Real Time Clock */
#define ILR             (*((volatile unsigned char *) 0xE0024000))
#define CTC             (*((volatile unsigned short*) 0xE0024004))
#define CCR             (*((volatile unsigned char *) 0xE0024008))
#define CIIR            (*((volatile unsigned char *) 0xE002400C))
#define AMR             (*((volatile unsigned char *) 0xE0024010))
#define CTIME0          (*((volatile unsigned long *) 0xE0024014))
#define CTIME1          (*((volatile unsigned long *) 0xE0024018))
#define CTIME2          (*((volatile unsigned long *) 0xE002401C))
#define SEC             (*((volatile unsigned char *) 0xE0024020))
#define MIN             (*((volatile unsigned char *) 0xE0024024))
#define HOUR            (*((volatile unsigned char *) 0xE0024028))
#define DOM             (*((volatile unsigned char *) 0xE002402C))
#define DOW             (*((volatile unsigned char *) 0xE0024030))
#define DOY             (*((volatile unsigned short*) 0xE0024034))
#define MONTH           (*((volatile unsigned char *) 0xE0024038))
#define YEAR            (*((volatile unsigned short*) 0xE002403C))
#define ALSEC           (*((volatile unsigned char *) 0xE0024060))
#define ALMIN           (*((volatile unsigned char *) 0xE0024064))
#define ALHOUR          (*((volatile unsigned char *) 0xE0024068))
#define ALDOM           (*((volatile unsigned char *) 0xE002406C))
#define ALDOW           (*((volatile unsigned char *) 0xE0024070))
#define ALDOY           (*((volatile unsigned short*) 0xE0024074))
#define ALMON           (*((volatile unsigned char *) 0xE0024078))
#define ALYEAR          (*((volatile unsigned short*) 0xE002407C))
#define PREINT          (*((volatile unsigned short*) 0xE0024080))
#define PREFRAC         (*((volatile unsigned short*) 0xE0024084))
/* A/D Converter 0 (AD0) */
#define AD0CR           (*((volatile unsigned long *) 0xE0034000))
#define AD0GDR          (*((volatile unsigned long *) 0xE0034004))
#define AD0STAT         (*((volatile unsigned long *) 0xE0034030))
#define AD0INTEN        (*((volatile unsigned long *) 0xE003400C))
#define AD0DR0          (*((volatile unsigned long *) 0xE0034010))
#define AD0DR1          (*((volatile unsigned long *) 0xE0034014))
#define AD0DR2          (*((volatile unsigned long *) 0xE0034018))
#define AD0DR3          (*((volatile unsigned long *) 0xE003401C))
#define AD0DR4          (*((volatile unsigned long *) 0xE0034020))
#define AD0DR5          (*((volatile unsigned long *) 0xE0034024))
#define AD0DR6          (*((volatile unsigned long *) 0xE0034028))
#define AD0DR7          (*((volatile unsigned long *) 0xE003402C))
/* A/D Converter 1 (AD1) */
#define AD1CR           (*((volatile unsigned long *) 0xE0060000))
#define AD1GDR          (*((volatile unsigned long *) 0xE0060004))
#define AD1STAT         (*((volatile unsigned long *) 0xE0060030))
#define AD1INTEN        (*((volatile unsigned long *) 0xE006000C))
#define AD1DR0          (*((volatile unsigned long *) 0xE0060010))
#define AD1DR1          (*((volatile unsigned long *) 0xE0060014))
#define AD1DR2          (*((volatile unsigned long *) 0xE0060018))
#define AD1DR3          (*((volatile unsigned long *) 0xE006001C))
#define AD1DR4          (*((volatile unsigned long *) 0xE0060020))
#define AD1DR5          (*((volatile unsigned long *) 0xE0060024))
#define AD1DR6          (*((volatile unsigned long *) 0xE0060028))
#define AD1DR7          (*((volatile unsigned long *) 0xE006002C))
/* A/D Converter Global */
#define ADGSR           (*((volatile unsigned long *) 0xE0034008))
/* D/A Converter */
#define DACR            (*((volatile unsigned long *) 0xE006C000))
/* Watchdog */
#define WDMOD           (*((volatile unsigned char *) 0xE0000000))
#define WDTC            (*((volatile unsigned long *) 0xE0000004))
#define WDFEED          (*((volatile unsigned char *) 0xE0000008))
#define WDTV            (*((volatile unsigned long *) 0xE000000C))
/* USB Controller */
#define USBIntSt        (*((volatile unsigned long *) 0xE01FC1C0))
#define USBDevIntSt     (*((volatile unsigned long *) 0xE0090000))
#define USBDevIntEn     (*((volatile unsigned long *) 0xE0090004))
#define USBDevIntClr    (*((volatile unsigned long *) 0xE0090008))
#define USBDevIntSet    (*((volatile unsigned long *) 0xE009000C))
#define USBDevIntPri    (*((volatile unsigned char *) 0xE009002C))
#define USBEpIntSt      (*((volatile unsigned long *) 0xE0090030))
#define USBEpIntEn      (*((volatile unsigned long *) 0xE0090034))
#define USBEpIntClr     (*((volatile unsigned long *) 0xE0090038))
#define USBEpIntSet     (*((volatile unsigned long *) 0xE009003C))
#define USBEpIntPri     (*((volatile unsigned long *) 0xE0090040))
#define USBReEp         (*((volatile unsigned long *) 0xE0090044))
#define USBEpInd        (*((volatile unsigned long *) 0xE0090048))
#define USBMaxPSize     (*((volatile unsigned long *) 0xE009004C))
#define USBRxData       (*((volatile unsigned long *) 0xE0090018))
#define USBRxPLen       (*((volatile unsigned long *) 0xE0090020))
#define USBTxData       (*((volatile unsigned long *) 0xE009001C))
#define USBTxPLen       (*((volatile unsigned long *) 0xE0090024))
#define USBCtrl         (*((volatile unsigned long *) 0xE0090028))
#define USBCmdCode      (*((volatile unsigned long *) 0xE0090010))
#define USBCmdData      (*((volatile unsigned long *) 0xE0090014))
#define USBDMARSt       (*((volatile unsigned long *) 0xE0090050))
#define USBDMARClr      (*((volatile unsigned long *) 0xE0090054))
#define USBDMARSet      (*((volatile unsigned long *) 0xE0090058))
#define USBUDCAH        (*((volatile unsigned long *) 0xE0090080))
#define USBEpDMASt      (*((volatile unsigned long *) 0xE0090084))
#define USBEpDMAEn      (*((volatile unsigned long *) 0xE0090088))
#define USBEpDMADis     (*((volatile unsigned long *) 0xE009008C))
#define USBDMAIntSt     (*((volatile unsigned long *) 0xE0090090))
#define USBDMAIntEn     (*((volatile unsigned long *) 0xE0090094))
#define USBEoTIntSt     (*((volatile unsigned long *) 0xE00900A0))
#define USBEoTIntClr    (*((volatile unsigned long *) 0xE00900A4))
#define USBEoTIntSet    (*((volatile unsigned long *) 0xE00900A8))
#define USBNDDRIntSt    (*((volatile unsigned long *) 0xE00900AC))
#define USBNDDRIntClr   (*((volatile unsigned long *) 0xE00900B0))
#define USBNDDRIntSet   (*((volatile unsigned long *) 0xE00900B4))
#define USBSysErrIntSt  (*((volatile unsigned long *) 0xE00900B8))
#define USBSysErrIntClr (*((volatile unsigned long *) 0xE00900BC))
#define USBSysErrIntSet (*((volatile unsigned long *) 0xE00900C0))
/////////////////////////GPIO OPERATION DEFINITION//////////////////////////////
typedef struct _bit_struct
    unsigned bit0  : 1 ;
    unsigned bit1  : 1 ;
    unsigned bit2  : 1 ;
    unsigned bit3  : 1 ;
    unsigned bit4  : 1 ;
    unsigned bit5  : 1 ;
    unsigned bit6  : 1 ;
    unsigned bit7  : 1 ;
    unsigned bit8  : 1 ;
    unsigned bit9  : 1 ;
    unsigned bit10 : 1 ;
    unsigned bit11 : 1 ;
    unsigned bit12 : 1 ;
    unsigned bit13 : 1 ;
    unsigned bit14 : 1 ;
    unsigned bit15 : 1 ;
    unsigned bit16 : 1 ;
    unsigned bit17 : 1 ;
    unsigned bit18 : 1 ;
    unsigned bit19 : 1 ;
    unsigned bit20 : 1 ;
    unsigned bit21 : 1 ;
    unsigned bit22 : 1 ;
    unsigned bit23 : 1 ;
    unsigned bit24 : 1 ;
    unsigned bit25 : 1 ;
    unsigned bit26 : 1 ;
    unsigned bit27 : 1 ;
    unsigned bit28 : 1 ;
    unsigned bit29 : 1 ;
    unsigned bit30 : 1 ;
    unsigned bit31 : 1 ;
}bit_field;
#define GET_BITFIELD(addr) (*((volatile  bit_field *)(addr)))
#define GETBIT(address,b) GET_BITFIELD(&address).bit##b
#define SET_PIN0(b,n) {if(n==0)IO0CLR = (1 << (b));else if(n==1) IO0SET=(1 << (b)); else IO0PIN^=(1 << (b));}
#define GET_PIN0(b)     GETBIT(IO0PIN,b)
#define SET_PIN1(b,n) {if(n==0)IO1CLR = (1 << (b));else if(n==1) IO1SET=(1 << (b)); else IO1PIN^=(1 << (b));}
#define GET_PIN1(n)     GETBIT(IO1PIN,n)
#endif  // __LPC214x_H
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
