packages gnuradio
 楼主| gaochy1126 发表于 2019-5-31 10:23 | 显示全部楼层 |阅读模式
  1. Versions of packages gnuradio depends on:
  2. ii  libasound2                        1.1.3-5
  3. ii  libboost-atomic1.62.0             1.62.0+dfsg-5
  4. ii  libboost-chrono1.62.0             1.62.0+dfsg-5
  5. ii  libboost-date-time1.62.0          1.62.0+dfsg-5
  6. ii  libboost-filesystem1.62.0         1.62.0+dfsg-5
  7. ii  libboost-program-options1.62.0    1.62.0+dfsg-5
  8. ii  libboost-regex1.62.0              1.62.0+dfsg-5
  9. ii  libboost-system1.62.0             1.62.0+dfsg-5
  10. ii  libboost-thread1.62.0             1.62.0+dfsg-5
  11. ii  libc6                             2.27-3
  12. ii  libcodec2-0.7                     0.7-1
  13. ii  libcomedi0                        0.10.2-4+b5
  14. ii  libfftw3-single3                  3.3.7-1
  15. ii  libgcc1                           1:8-20180402-1
  16. ii  libgnuradio-analog3.7.11          3.7.11-8
  17. ii  libgnuradio-atsc3.7.11            3.7.11-8
  18. ii  libgnuradio-audio3.7.11           3.7.11-8
  19. ii  libgnuradio-blocks3.7.11          3.7.11-8
  20. ii  libgnuradio-channels3.7.11        3.7.11-8
  21. ii  libgnuradio-comedi3.7.11          3.7.11-8
  22. ii  libgnuradio-digital3.7.11         3.7.11-8
  23. ii  libgnuradio-dtv3.7.11             3.7.11-8
  24. ii  libgnuradio-fcd3.7.11             3.7.11-8
  25. ii  libgnuradio-fec3.7.11             3.7.11-8
  26. ii  libgnuradio-fft3.7.11             3.7.11-8
  27. ii  libgnuradio-filter3.7.11          3.7.11-8
  28. ii  libgnuradio-noaa3.7.11            3.7.11-8
  29. ii  libgnuradio-pager3.7.11           3.7.11-8
  30. ii  libgnuradio-pmt3.7.11             3.7.11-8
  31. ii  libgnuradio-qtgui3.7.11           3.7.11-8
  32. ii  libgnuradio-runtime3.7.11         3.7.11-8
  33. ii  libgnuradio-trellis3.7.11         3.7.11-8
  34. ii  libgnuradio-uhd3.7.11             3.7.11-8
  35. ii  libgnuradio-video-sdl3.7.11       3.7.11-8
  36. ii  libgnuradio-vocoder3.7.11         3.7.11-8
  37. ii  libgnuradio-wavelet3.7.11         3.7.11-8
  38. ii  libgnuradio-wxgui3.7.11           3.7.11-8
  39. ii  libgnuradio-zeromq3.7.11          3.7.11-8
  40. ii  libgsl23                          2.4+dfsg-6
  41. ii  libgslcblas0                      2.4+dfsg-6
  42. ii  libgsm1                           1.0.13-4+b2
  43. ii  libjack-jackd2-0 [libjack-0.125]  1.9.12~dfsg-2
  44. ii  liblog4cpp5v5                     1.1.1-3
  45. ii  libportaudio2                     19.6.0-1
  46. ii  libpython2.7                      2.7.14-8
  47. ii  libqt5core5a                      5.9.2+dfsg-12
  48. ii  libqt5gui5                        5.9.2+dfsg-12
  49. ii  libqt5widgets5                    5.9.2+dfsg-12
  50. ii  libqwt-qt5-6                      6.1.3-1
  51. ii  libsdl1.2debian                   1.2.15+dfsg2-0.1
  52. ii  libstdc++6                        8-20180402-1
  53. ii  libuhd003.010.003                 3.10.3.0-2
  54. ii  libusb-1.0-0                      2:1.0.21-2
  55. ii  libvolk1-bin                      1.3.1-1
  56. ii  libvolk1.3                        1.3.1-1
  57. ii  libzmq5                           4.2.5-1
  58. ii  python                            2.7.14-4
  59. ii  python-cheetah                    2.4.4-4
  60. ii  python-gtk2                       2.24.0-5.1+b1
  61. ii  python-lxml                       4.2.1-1
  62. ii  python-numpy                      1:1.13.3-2
  63. ii  python-opengl                     3.1.0+dfsg-1
  64. ii  python-sip                        4.19.8+dfsg-1
  65. ii  python-wxgtk3.0                   3.0.2.0+dfsg-6
  66. ii  python-zmq                        17.0.0-1
  67. Versions of packages gnuradio recommends:
  68. ii  gnuradio-dev       3.7.11-8
  69. ii  python-matplotlib  2.1.1-2
  70. ii  python-networkx    1.11-2
  71. ii  python-pyqt5       5.9.2+dfsg-1
  72. pn  python-qwt-qt5     <none>
  73. ii  python-scipy       0.19.1-2
  74. ii  python-tk          2.7.14-3
  75. ii  rtl-sdr            0.5.3-13
  76. ii  uhd-host           3.11.0.1-1
  77. Versions of packages gnuradio suggests:
  78. pn  gr-fosphor  <none>
  79. ii  gr-osmosdr  0.1.4-14+b2
复制代码
Kernel: Linux 3.10.0-693.11.6.el7.x86_64 (SMP w/4 CPU cores)Locale: LANG=C, LC_CTYPE=C (charmap=ANSI_X3.4-1968), LANGUAGE=C (charmap=ANSI_X3.4-1968)Shell: /bin/sh linked to /usr/bin/dash
dnhdfndfnd 发表于 2019-6-18 07:28 | 显示全部楼层
我怎么说那?~!
个人签名:这个社会混好的两种人:一是有权有势,二是没脸没皮的。
1148
