[嵌入式linux] 嵌入式LINUX驱动问题(file_operations)
3115|3
 楼主| wuyunzdh 发表于 2008-10-23 12:39 | 显示全部楼层 |阅读模式
请问一下,我的开发板完整的AD驱动程序为什么没有file_operations结构。
能不能帮忙解释一下,
驱动一般都有file_operations结构来定义接口函数的呀!
如:
struct file_operations scull_fops = { .owner =  THIS_MODULE,
.llseek =  scull_llseek,
.read =  scull_read,
.write =  scull_write,
.ioctl =  scull_ioctl,
.open =  scull_open,
.release =  scull_release,};
我把源码贴给大家看看:
* s3c2410-adc.c
* S3C2410 ADC
*  exclusive with s3c2410-ts.c
* Author: SeonKon Choi <bushi@mizi.com>
* Date  : $Date: 2003/01/20 14:24:49 $
* $Revision: 1.1.2.6 $
   Fri Dec 03 2002 SeonKon Choi <bushi@mizi.com>
   - initial
* This file is subject to the terms and conditions of the GNU General Public
* License.  See the file COPYING in the main directory of this archive
* for more details.
#include <linux/config.h>
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
#include <linux/sched.h>
#include <linux/irq.h>
#include <linux/delay.h>
#include <asm/hardware.h>
#include <asm/semaphore.h>
#undef DEBUG
#ifdef DEBUG
#define DPRINTK(x...) {printk(__FUNCTION__"(%d): ",__LINE__);printk(##x);}
#else
#define DPRINTK(x...) (void)(0)
#endif
#define START_ADC_AIN(x)
  ADCCON = PRESCALE_EN | PRSCVL(255) | ADC_INPUT((x)) ;
  ADCCON |= ADC_START;
static struct semaphore adc_lock;
static wait_queue_head_t *adc_wait;
static void adcdone_int_handler(int irq, void *dev_id, struct pt_regs *reg)
wake_up(adc_wait);
int s3c2410_adc_read(int ain, wait_queue_head_t *wait)
int ret = 0;
if (down_interruptible(&adc_lock))
  return -ERESTARTSYS;
adc_wait = wait;
START_ADC_AIN(ain);
sleep_on_timeout(adc_wait, HZ/100); /* 10ms */
#if 0
if (signal_pending(current)) {
  up(&adc_lock);
#endif
ret = ADCDAT0 ;
up(&adc_lock);
adc_wait = NULL;
DPRINTK("AIN[%d] = 0x%04x, %d ", ain, ret, ADCCON & 0x80 ? 1:0);
return (ret & 0x3ff);
int __init s3c2410_adc_init(void)
init_MUTEX(&adc_lock);
/* normal ADC */
ADCTSC = 0; //XP_PST(NOP_MODE);
if (request_irq(IRQ_ADC_DONE, adcdone_int_handler, SA_INTERRUPT,
   "ADC", NULL) < 0)
  goto irq_err;
return 0;
irq_err:
return 1;
module_init(s3c2410_adc_init);
#ifdef MODULE
void __exit s3c2410_adc_exit(void)
free_irq(IRQ_ADC_DONE, NULL);
module_exit(s3c2410_adc_exit);
MODULE_LICENSE("GPL");
#endif
 楼主| wuyunzdh 发表于 2008-10-27 10:43 | 显示全部楼层
用为什么没有提供接口函数呀?
用户程序怎么通过调用read函数来找到驱动程序中的s3c2410_adc_read函数
为什么没有提供接口函数呀?
realrots 发表于 2008-10-29 11:10 | 显示全部楼层
应该有定义,你没有找到吧
圆圈 发表于 2008-11-5 11:26 | 显示全部楼层
一般都是有的
一般都是有的,除非,你用的文件系统(VFS)比较特殊。
linux驱动建立在VFS文件系统基础之上~~
