CFI Data<br />Used to store the query data for CoreCFI. The data is stored in a reserved page location. This client does not take up any of the 2048 pages in the Flash Memory. <br /><br /><br /><br />Use the dialog box to specify the location of the memory file for CFI query data (as shown in the figure below). This memory file is provided to you when you obtain the CoreCFI IP. The memory file format is Actel Binary. You are not expected to modify this file. <br />周工,请问一下,这是一个什么样的MEMORY FILE文件呀,这文件是新建一个CORECONSOLE之后自动生成的,还是怎么回事呀<br /> <br /><br /> |
