急!急!急!心急如焚,请各位帮忙指点
2621|0
 楼主| yjg957104 发表于 2008-3-16 11:59 | 显示全部楼层 |阅读模式
library ieee
USE IEEE_STD_LOGIC_1164.ALL;
USE IEEE_STD_LOGIC_ARITH.ALL;
USE IEEE_STD_LOGIC_UNSIGNED.ALL;entity myjkff is
port(j,k,clr:in std_logic;
     clk:in std_logic;
     q,qn:buffer std_logic);
end myjkff;
architecture one of myjkff is
begin
process(j,k,clr,clk)
variable jk:std_logic_vector(1 downto 0);
begin
jk:=(j & k);
       if clr='0'then
          q<='0';
          qn<='1';
  elsif clk'event and clk='0' then
      case jk is
           when "00"=>   q<=q;    qn <=qn;
           when "01"=>   q<='0';    qn <='1';
           when "10"=>   q<='1';    qn <='0';
           when "11"=>   q<='1';    qn <='1';
           when others=>   null;
      end case;
    end if;
  end process;
end one;
 我是新手,上面是我编写的JK触发器的VHDL语言设计,但是编译是出现了16个错误,我怎么也不知道如何改正,请各位老师帮我分析改正,谢谢
1、Error (10170): Verilog HDL syntax error at jk.v(2) near text "IEEE_STD_LOGIC_1164";  expecting ";", or ",", or "-"
2、Error (10170): Verilog HDL syntax error at jk.v(3) near text ".";  expecting ";", or ","
3、Error (10839): Verilog HDL error at jk.v(3): declaring global objects is a SystemVerilog feature
4、Error (10170): Verilog HDL syntax error at jk.v(4) near text ".";  expecting ";", or ","
5、Error (10839): Verilog HDL error at jk.v(4): declaring global objects is a SystemVerilog feature
6、Error (10170): Verilog HDL syntax error at jk.v(4) near text "is";  expecting ";", or ","
7、Error (10170): Verilog HDL syntax error at jk.v(5) near text ":";  expecting ";", or ","
8、Error (10839): Verilog HDL error at jk.v(6): declaring global objects is a SystemVerilog feature
9、Error (10839): Verilog HDL error at jk.v(7): declaring global objects is a SystemVerilog feature
10、Error (10170): Verilog HDL syntax error at jk.v(8) near text "end"; "end" without "begin"
11、Error (10839): Verilog HDL error at jk.v(8): declaring global objects is a SystemVerilog feature
12、Error (10170): Verilog HDL syntax error at jk.v(9) near text "of";  expecting ";", or ","
13、Error (10149): Verilog HDL Declaration error at jk.v(11): identifier "k" is already declared in the present scope
14、Error (10149): Verilog HDL Declaration error at jk.v(11): identifier "clr" is already declared in the present scope
15、Error (10170): Verilog HDL syntax error at jk.v(11) near text ")";  expecting ";", or ","
16、Error: Quartus II Analysis & Synthesis was unsuccessful. 16 errors, 0 warnings
请各位老师帮我分析改正
