jag
Trusted Contributor
Message 1 of 15
Viewed 3,512 times
| Hi,
I'm trying to use the 56800E Flash Programmer (v1.0) command line version.
I use this command:
fflash 56801x_flash.cfg pippo.S -remote=127.0.0.1:41475 -LPT1 -llog.txt
and the program reply with this:
56800E Flash Programmer v1.0
Program ran on: Mon Dec 10 16:54:07 2007
Connected to local CCS server at PORT 41475
Configured to use Parallel Command Converter at port LPT1
The device is not powered up, cannot continue, if the device
is powered up, attempt a hard reset on the device, and try this action again.
The fact is that the GUI version works well so I don't know exactly what to do (I tried all the possible flags of fflash)...
Any ideas?
Thanks Bye Jack |
