[i.MX] VFS: Unable to mount root fs on unknown-block(179,1)
4196|4
 楼主| duzouliunian 发表于 2016-10-13 13:21 | 显示全部楼层 |阅读模式
如题,板子是参照mx6q-sabresd设计的,内核启动时卡住了,部分log如下。上网查了一下似乎说是SD卡写保护,求问应该怎么修改?
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.1.17 (root@ali-ubuntu) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 6
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Freescale i.MX6 Quad SABRE Smart Device Board
[    0.000000] cma: Reserved 16 MiB at 0x4f000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 12 pages/cpu @be790000 s16896 r8192 d24064 u49152
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
[    0.000000] Kernel command line: noinitrd console=ttymxc0,115200 root=/dev/mmcblk0p1 rw init=/linuxrc
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1003240K/1048576K available (7751K kernel code, 391K rwdata, 2588K rodata, 384K init, 8347K bss, 28952K reserved, 16384K cma-res)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xc0800000 - 0xff000000   (1000 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
[    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
[    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
[    0.000000]       .text : 0x80008000 - 0x80a2103c   (10341 kB)
[    0.000000]       .init : 0x80a22000 - 0x80a82000   ( 384 kB)
[    0.000000]       .data : 0x80a82000 - 0x80ae3e60   ( 392 kB)
[    0.000000]        .bss : 0x80ae3e60 - 0x8130addc   (8348 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Running RCU self tests
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU lockdep checking is enabled.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] ------------[ cut here ]------------
[    0.000000] WARNING: CPU: 0 PID: 0 at arch/arm/mach-imx/gpc.c:286 imx_gpc_check_dt+0x54/0x90()
[    0.000000] Modules linked in:
[    0.000000] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.1.17 #1
[    0.000000] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[    0.000000] Backtrace:
[    0.000000] [<80012c4c>] (dump_backtrace) from [<80012dec>] (show_stack+0x18/0x1c)
[    0.000000]  r6:80943534 r5:00000000 r4:00000000 r3:00000000
[    0.000000] [<80012dd4>] (show_stack) from [<80790004>] (dump_stack+0x80/0x9c)
[    0.000000] [<8078ff84>] (dump_stack) from [<8002e9c8>] (warn_slowpath_common+0x7c/0xb4)
[    0.000000]  r5:0000011e r4:00000000
[    0.000000] [<8002e94c>] (warn_slowpath_common) from [<8002ea24>] (warn_slowpath_null+0x24/0x2c)
[    0.000000]  r8:80a6f9e0 r7:ffffffff r6:80ae3e80 r5:00000000 r4:be7cdf58
[    0.000000] [<8002ea00>] (warn_slowpath_null) from [<80a34bb8>] (imx_gpc_check_dt+0x54/0x90)
[    0.000000] [<80a34b64>] (imx_gpc_check_dt) from [<80a38aa4>] (imx6q_init_irq+0x10/0x24)
[    0.000000]  r5:00000001 r4:80a6f9d0
[    0.000000] [<80a38a94>] (imx6q_init_irq) from [<80a255f0>] (init_IRQ+0x30/0x88)
[    0.000000] [<80a255c0>] (init_IRQ) from [<80a22b5c>] (start_kernel+0x238/0x3d4)
[    0.000000]  r4:00000000 r3:812e2ad0
[    0.000000] [<80a22924>] (start_kernel) from [<1000807c>] (0x1000807c)
[    0.000000]  r10:00000000 r8:1000406a r7:80a898ac r6:80a6f9dc r5:80a8496c r4:80ae4114
[    0.000000] ---[ end trace cb88537fdc8fa200 ]---
[    0.000000] Outdated DT detected, suspend/resume will NOT work
[    0.000000] L2C-310 erratum 769419 enabled
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 1024 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76470001
[    0.000000] Switching to timer-based delay loop, resolution 15ns
[    0.000007] sched_clock: 32 bits at 66MHz, resolution 15ns, wraps every 32537631224ns
[    0.000035] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 28958491609 ns
[    0.001222] Console: colour dummy device 80x30
[    0.001253] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[    0.001263] ... MAX_LOCKDEP_SUBCLASSES:  8
[    0.001270] ... MAX_LOCK_DEPTH:          48
[    0.001278] ... MAX_LOCKDEP_KEYS:        8191
[    0.001285] ... CLASSHASH_SIZE:          4096
[    0.001293] ... MAX_LOCKDEP_ENTRIES:     32768
[    0.001300] ... MAX_LOCKDEP_CHAINS:      65536
[    0.001307] ... CHAINHASH_SIZE:          32768
[    0.001314]  memory used by lock dependency info: 5167 kB
[    0.001323]  per task-struct memory footprint: 1152 bytes
[    0.001349] Calibrating delay loop (skipped), value calculated using timer frequency.. 132.00 BogoMIPS (lpj=660000)
[    0.001368] pid_max: default: 32768 minimum: 301
[    0.001679] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001696] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003439] CPU: Testing write buffer coherency: ok
[    0.004327] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004428] Setting up static identity map for 0x10008280 - 0x100082f0
[    0.009313] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.011200] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.012535] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.012756] Brought up 4 CPUs
[    0.012775] SMP: Total of 4 processors activated (528.00 BogoMIPS).
[    0.012785] CPU: All CPU(s) started in SVC mode.
[    0.014854] devtmpfs: initialized
[    0.048796] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.049760] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.051500] pinctrl core: initialized pinctrl subsystem
[    0.054901] NET: Registered protocol family 16
[    0.059041] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.061245] CPU identified as i.MX6Q, silicon rev 1.5
[    0.121408] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.121423] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.125548] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.187243] mxs-dma 110000.dma-apbh: initialized
[    0.194800] vgaarb: loaded
[    0.195756] SCSI subsystem initialized
[    0.196913] usbcore: registered new interface driver usbfs
[    0.197088] usbcore: registered new interface driver hub
[    0.197320] usbcore: registered new device driver usb
[    0.197770] 2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
[    0.198217] 2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
[    0.201514] i2c i2c-0: IMX I2C adapter registered
[    0.201541] i2c i2c-0: can't use DMA
[    0.203787] i2c i2c-1: IMX I2C adapter registered
[    0.203813] i2c i2c-1: can't use DMA
[    0.205777] i2c i2c-2: IMX I2C adapter registered
[    0.205803] i2c i2c-2: can't use DMA
[    0.206131] Linux video capture interface: v2.00
[    0.206400] pps_core: LinuxPPS API ver. 1 registered
[    0.206412] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.206469] PTP clock support registered
[    0.207296] Advanced Linux Sound Architecture Driver Initialized.
[    0.210851] Bluetooth: Core ver 2.20
[    0.210946] NET: Registered protocol family 31
[    0.210958] Bluetooth: HCI device and connection manager initialized
[    0.211034] Bluetooth: HCI socket layer initialized
[    0.211064] Bluetooth: L2CAP socket layer initialized
[    0.211203] Bluetooth: SCO socket layer initialized
[    0.212699] cfg80211: Calling CRDA to update world regulatory domain
[    0.214232] Switched to clocksource mxc_timer1
[    0.244301] NET: Registered protocol family 2
[    0.246042] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.246288] TCP bind hash table entries: 8192 (order: 6, 294912 bytes)
[    0.249196] TCP: Hash tables configured (established 8192 bind 8192)
[    0.249399] UDP hash table entries: 512 (order: 3, 40960 bytes)
[    0.249801] UDP-Lite hash table entries: 512 (order: 3, 40960 bytes)
[    0.250970] NET: Registered protocol family 1
[    0.252156] RPC: Registered named UNIX socket transport module.
[    0.252173] RPC: Registered udp transport module.
[    0.252184] RPC: Registered tcp transport module.
[    0.252195] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.253405] CPU PMU: Failed to parse /soc/pmu/interrupt-affinity[0]
[    0.253494] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    0.255557] imx6_busfreq soc:busfreq: DDR medium rate not supported.
[    0.257077] Bus freq driver module loaded
[    0.259857] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.278129] VFS: Disk quotas dquot_6.6.0
[    0.278572] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.285741] NFS: Registering the id_resolver key type
[    0.285976] Key type id_resolver registered
[    0.285991] Key type id_legacy registered
[    0.286198] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.288038] fuse init (API version 7.23)
[    0.293874] io scheduler noop registered
[    0.293899] io scheduler deadline registered
[    0.293993] io scheduler cfq registered (default)
[    0.295226] imx-weim 21b8000.weim: Driver registered.
[    0.299855] imx6q-pcie 1ffc000.pcie: pcie_phy clock source missing or invalid
[    0.299927] imx6q-pcie: probe of 1ffc000.pcie failed with error -2
[    0.302213] backlight supply power not found, using dummy regulator
[    0.306871] imx-sdma 20ec000.sdma: Direct firmware load for imx/sdma/sdma-imx6q.bin failed with error -2
[    0.306899] imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
[    0.314502] imx-sdma 20ec000.sdma: initialized
[    0.317271] pfuze100-regulator 1-0008: Full layer: 1, Metal layer: 1
[    0.317990] pfuze100-regulator 1-0008: FAB: 0, FIN: 0
[    0.318007] pfuze100-regulator 1-0008: pfuze100 found.
[    0.341037] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 24, base_baud = 5000000) is a IMX
[    1.291667] console [ttymxc0] enabled
[    1.299528] [drm] Initialized drm 1.1.0 20060810
[    1.310607] imx-ipuv3-crtc imx-ipuv3-crtc.0: missing port@2 node in /soc/ipu@02400000
[    1.318949] imx-ipuv3-crtc imx-ipuv3-crtc.1: missing port@3 node in /soc/ipu@02400000
[    1.327477] imx-ipuv3 2400000.ipu: IPUv3H probed
[    1.333333] imx-ipuv3-crtc imx-ipuv3-crtc.4: missing port@2 node in /soc/ipu@02800000
[    1.341627] imx-ipuv3-crtc imx-ipuv3-crtc.5: missing port@3 node in /soc/ipu@02800000
[    1.350142] imx-ipuv3 2800000.ipu: IPUv3H probed
[    1.377841] brd: module loaded
[    1.396422] loop: module loaded
[    1.401755] ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
[    1.409739] ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
[    1.417800] ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
[    1.426030] ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
[    1.437000] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
[    1.444011] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    1.452856] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
[    1.465558] scsi host0: ahci-imx
[    1.470016] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 312
[    1.486701] m25p80 spi32766.0: m25p32 (4096 Kbytes)
[    1.496299] spi_imx 2008000.ecspi: probed
[    1.501428] CAN device driver interface
[    1.507687] 2188000.ethernet supply phy not found, using dummy regulator
[    1.516172] pps pps0: new PPS source ptp0
[    1.520547] fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[    1.530538] fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 56:ef:12:e3:ad:67
[    1.550476] libphy: fec_enet_mii_bus: probed
[    1.556635] fec 2188000.ethernet eth0: registered PHC device 0
[    1.564370] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.570927] ehci-pci: EHCI PCI platform driver
[    1.575557] ehci-mxc: Freescale On-Chip EHCI Host driver
[    1.581327] usbcore: registered new interface driver usb-storage
[    1.603875] ci_hdrc ci_hdrc.1: doesn't support gadget
[    1.609013] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    1.614134] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    1.634294] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    1.644387] hub 1-0:1.0: USB hub found
[    1.648500] hub 1-0:1.0: 1 port detected
(接上面)
[    1.656813] mousedev: PS/2 mouse device common for all mice
[    1.664537] egalax_ts 1-0004: Failed to read firmware version
[    1.670355] egalax_ts: probe of 1-0004 failed with error -5
[    1.676459] egalax_ts 2-0004: Failed to read firmware version
[    1.682262] egalax_ts: probe of 2-0004 failed with error -5
[    1.691595] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
[    1.700279] i2c /dev entries driver
[    1.707108] IR NEC protocol handler initialized
[    1.711674] IR RC5(x/sz) protocol handler initialized
[    1.716788] IR RC6 protocol handler initialized
[    1.721344] IR JVC protocol handler initialized
[    1.725916] IR Sony protocol handler initialized
[    1.730558] IR SANYO protocol handler initialized
[    1.735307] IR Sharp protocol handler initialized
[    1.740035] IR MCE Keyboard/mouse protocol handler initialized
[    1.745910] IR XMP protocol handler initialized
[    1.761680] imx2-wdt 20c0000.wdog: timeout 60 sec (nowayout=0)
[    1.768012] Bluetooth: HCI UART driver ver 2.3
[    1.772478] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.779445] sdhci: Secure Digital Host Controller Interface driver
[    1.785691] sdhci: Copyright(c) Pierre Ossman
[    1.790128] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.797504] /soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
[    1.804778] sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
[    1.809957] sdhci-esdhc-imx 2194000.usdhc: Got WP GPIO
[    1.815551] sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
[    1.821753] sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
[    1.824281] ata1: SATA link down (SStatus 0 SControl 300)
[    1.824347] ahci-imx 2200000.sata: no device found, disabling link.
[    1.824354] ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
[    1.884610] mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[    1.892867] /soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
[    1.900086] sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
[    1.905292] sdhci-esdhc-imx 2198000.usdhc: Got WP GPIO
[    1.911767] sdhci-esdhc-imx 2198000.usdhc: No vmmc regulator found
[    1.917997] sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
[    1.939201] mmc0: new high speed SDHC card at address 1234
[    1.946569] mmcblk0: mmc0:1234 SA08G 7.21 GiB (ro)
[    1.955711]  mmcblk0: p1
[    1.964961] mmc1: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[    1.973717] /soc/aips-bus@02100000/usdhc@0219c000: voltage-ranges unspecified
[    1.982208] sdhci-esdhc-imx 219c000.usdhc: No vmmc regulator found
[    1.988450] sdhci-esdhc-imx 219c000.usdhc: No vqmmc regulator found
[    2.034271] mmc2: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
[    2.043653] usbcore: registered new interface driver usbhid
[    2.049279] usbhid: USB HID core driver
[    2.061437] wm8962 0-001a: Failed to read ID register
[    2.068859] wm8962: probe of 0-001a failed with error -5
[    2.079900] imx-wm8962 sound: phandle missing or invalid
[    2.085302] imx-wm8962: probe of sound failed with error -22
[    2.094047] NET: Registered protocol family 10
[    2.102365] sit: IPv6 over IPv4 tunneling driver
[    2.109160] NET: Registered protocol family 17
[    2.113662] can: controller area network core (rev 20120528 abi 9)
[    2.120053] NET: Registered protocol family 29
[    2.124572] can: raw protocol (rev 20120528)
[    2.128977] can: broadcast manager protocol (rev 20120528 t)
[    2.134717] can: netlink gateway (rev 20130117) max_hops=1
[    2.140945] Key type dns_resolver registered
[    2.152719] Registering SWP/SWPB emulation handler
[    2.172645] input: gpio-keys as /devices/soc0/gpio-keys/input/input2
[    2.182091] snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
[    2.231424] VGEN3: disabling
[    2.237940] VGEN2: disabling
[    2.241968] VGEN1: disabling
[    2.246138] SWBST: disabling
[    2.251746] SW4: disabling
[    2.258618] sensor-supply: disabling
[    2.264529] mipi_dsi_pwr_on: disabling
[    2.268300] wm8962-supply: disabling
[    2.271894] usb_otg_vbus: disabling
[    2.275455] vddpu: disabling
[    2.278956] ALSA device list:
[    2.281937]   No soundcards found.
[    2.287455] VFS: Cannot open root device "mmcblk0p1" or unknown-block(179,1): error -30
[    2.295502] Please append a correct "root=" boot option; here are the available partitions:
[    2.303982] 0100           65536 ram0  (driver?)
[    2.308671] 0101           65536 ram1  (driver?)
[    2.313325] 0102           65536 ram2  (driver?)
[    2.318003] 0103           65536 ram3  (driver?)
[    2.322658] 0104           65536 ram4  (driver?)
[    2.327332] 0105           65536 ram5  (driver?)
[    2.331988] 0106           65536 ram6  (driver?)
[    2.336663] 0107           65536 ram7  (driver?)
[    2.341318] 0108           65536 ram8  (driver?)
[    2.345998] 0109           65536 ram9  (driver?)
[    2.350652] 010a           65536 ram10  (driver?)
[    2.355431] 010b           65536 ram11  (driver?)
[    2.360172] 010c           65536 ram12  (driver?)
[    2.364938] 010d           65536 ram13  (driver?)
[    2.369678] 010e           65536 ram14  (driver?)
[    2.374443] 010f           65536 ram15  (driver?)
[    2.379197] 1f00            4096 mtdblock0  (driver?)
[    2.384304] b300         7563264 mmcblk0  driver: mmcblk
[    2.389654]   b301         7542362 mmcblk0p1 00000000-01
[    2.395137] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1)
[    2.403690] CPU0: stopping
[    2.406418] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G        W       4.1.17 #1
[    2.413562] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[    2.420097] Backtrace:
[    2.422600] [<80012c4c>] (dump_backtrace) from [<80012dec>] (show_stack+0x18/0x1c)
[    2.430179]  r6:00000000 r5:00000000 r4:00000000 r3:00000000
[    2.435947] [<80012dd4>] (show_stack) from [<80790004>] (dump_stack+0x80/0x9c)
[    2.443191] [<8078ff84>] (dump_stack) from [<80015f70>] (handle_IPI+0x154/0x180)
[    2.450595]  r5:80a7ee24 r4:80a84ae0
[    2.454224] [<80015e1c>] (handle_IPI) from [<80009570>] (gic_handle_irq+0x60/0x68)
[    2.461800]  r7:80a84c58 r6:fffffff5 r5:80a83f20 r4:f400010c
[    2.467552] [<80009510>] (gic_handle_irq) from [<80013924>] (__irq_svc+0x44/0x5c)
[    2.475046] Exception stack(0x80a83f20 to 0x80a83f68)
[    2.480111] 3f20: 00000001 00000001 00000000 80022140 80a849c8 00000000 00000001 80a8497c
[    2.488303] 3f40: 80a7d3c4 80ae360d 8079bb74 80a83f74 80a83f38 80a83f68 8006e610 800104a4
[    2.496488] 3f60: 20000113 ffffffff
[    2.499984]  r8:80a7d3c4 r7:80a83f54 r6:ffffffff r5:20000113 r4:800104a4 r3:80a88138
[    2.507856] [<80010464>] (arch_cpu_idle) from [<80067198>] (cpu_startup_entry+0x168/0x218)
[    2.516139] [<80067030>] (cpu_startup_entry) from [<8078a344>] (rest_init+0x130/0x16c)
[    2.524062]  r7:ffffffff r3:00000000
[    2.527698] [<8078a214>] (rest_init) from [<80a22c8c>] (start_kernel+0x368/0x3d4)
[    2.535187]  r5:00000001 r4:80ae3ed0
[    2.538816] [<80a22924>] (start_kernel) from [<1000807c>] (0x1000807c)
[    2.545351]  r10:00000000 r8:1000406a r7:80a898ac r6:80a6f9dc r5:80a8496c r4:80ae4114
[    2.553292] CPU3: stopping
[    2.556020] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G        W       4.1.17 #1
[    2.563163] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[    2.569697] Backtrace:
[    2.572185] [<80012c4c>] (dump_backtrace) from [<80012dec>] (show_stack+0x18/0x1c)
[    2.579761]  r6:00000000 r5:00000000 r4:00000000 r3:00000000
[    2.585516] [<80012dd4>] (show_stack) from [<80790004>] (dump_stack+0x80/0x9c)
[    2.592754] [<8078ff84>] (dump_stack) from [<80015f70>] (handle_IPI+0x154/0x180)
[    2.600155]  r5:80a7ee24 r4:80a84ae0
[    2.603781] [<80015e1c>] (handle_IPI) from [<80009570>] (gic_handle_irq+0x60/0x68)
[    2.611357]  r7:80a84c58 r6:fffffff5 r5:be0a3f70 r4:f400010c
[    2.617104] [<80009510>] (gic_handle_irq) from [<80013924>] (__irq_svc+0x44/0x5c)
[    2.624595] Exception stack(0xbe0a3f70 to 0xbe0a3fb8)
[    2.629658] 3f60:                                     00000001 00000001 00000000 80022140
[    2.637848] 3f80: 80a849c8 00000000 00000001 80a8497c 80a7d3c4 80ae360d 8079bb74 be0a3fc4
[    2.646035] 3fa0: be0a3f88 be0a3fb8 8006e610 800104a4 20000113 ffffffff
[    2.652655]  r8:80a7d3c4 r7:be0a3fa4 r6:ffffffff r5:20000113 r4:800104a4 r3:be076e00
[    2.660513] [<80010464>] (arch_cpu_idle) from [<80067198>] (cpu_startup_entry+0x168/0x218)
[    2.668792] [<80067030>] (cpu_startup_entry) from [<80015bac>] (secondary_start_kernel+0x120/0x13c)
[    2.677842]  r7:80ae41e0 r3:be076e00
[    2.681468] [<80015a8c>] (secondary_start_kernel) from [<1000960c>] (0x1000960c)
[    2.688869]  r5:00000015 r4:4e08406a
[    2.692490] CPU1: stopping
[    2.695216] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G        W       4.1.17 #1
[    2.702360] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[    2.708892] Backtrace:
[    2.711378] [<80012c4c>] (dump_backtrace) from [<80012dec>] (show_stack+0x18/0x1c)
[    2.718953]  r6:00000000 r5:00000000 r4:00000000 r3:00000000
[    2.724703] [<80012dd4>] (show_stack) from [<80790004>] (dump_stack+0x80/0x9c)
[    2.731939] [<8078ff84>] (dump_stack) from [<80015f70>] (handle_IPI+0x154/0x180)
[    2.739339]  r5:80a7ee24 r4:80a84ae0
[    2.742962] [<80015e1c>] (handle_IPI) from [<80009570>] (gic_handle_irq+0x60/0x68)
[    2.750537]  r7:80a84c58 r6:fffffff5 r5:be09ff70 r4:f400010c
[    2.756280] [<80009510>] (gic_handle_irq) from [<80013924>] (__irq_svc+0x44/0x5c)
[    2.763770] Exception stack(0xbe09ff70 to 0xbe09ffb8)
[    2.768831] ff60:                                     00000001 00000001 00000000 80022140
[    2.777019] ff80: 80a849c8 00000000 00000001 80a8497c 80a7d3c4 80ae360d 8079bb74 be09ffc4
[    2.785206] ffa0: be09ff88 be09ffb8 8006e610 800104a4 20000113 ffffffff
[    2.791825]  r8:80a7d3c4 r7:be09ffa4 r6:ffffffff r5:20000113 r4:800104a4 r3:be075a00
[    2.799676] [<80010464>] (arch_cpu_idle) from [<80067198>] (cpu_startup_entry+0x168/0x218)
[    2.807954] [<80067030>] (cpu_startup_entry) from [<80015bac>] (secondary_start_kernel+0x120/0x13c)
[    2.817004]  r7:80ae41e0 r3:be075a00
[    2.820628] [<80015a8c>] (secondary_start_kernel) from [<1000960c>] (0x1000960c)
[    2.828029]  r5:00000015 r4:4e08406a
[    2.831678] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1)
 楼主| duzouliunian 发表于 2016-10-13 16:50 | 显示全部楼层
另外还有个问题,DDR_stress_test通过是否可以说明DDR所有读写都正常?
 楼主| duzouliunian 发表于 2016-10-14 14:43 | 显示全部楼层
QAQ有木有大神可以帮忙看看
 楼主| duzouliunian 发表于 2016-11-30 16:19 | 显示全部楼层
已解决
