gdb+gdbserver求指教
4294|4
 楼主| aoyun2008 发表于 2011-3-18 17:09 | 显示全部楼层 |阅读模式
介绍一下我开发中遇到的问题:
arm-uclibc-linux-gcc 编译器
主机    IP : 192.168.1.224
目标机 IP : 192.168.1.223
通过nfs把host下的temp目录mount到target目标板子上mount下,可执行文件hello放在主机目录temp下.
->在目标机上使用gdbserver 192.168.1.224:2345 /mount/hello
提示:
Process test created; pid = 476
Listening on port 2345
->在主机上使用arm-uclibc-linux-gdb /temp/hello
GNU gdb 6.3.50.20050627-cvsCopyright 2004 Free Software Foundation, Inc.GDB is free software, covered by the GNU General Public License, and you are welcome to change it and/or distribute copies of it under certain conditions.Type "show copying" to see the conditions.There is absolutely no warranty for GDB.  Type "show warranty" for details.This GDB was configured as "--host=i686-pc-linux-gnu --target=arm-uclibc-linux"...
(gdb) target remote 192.168.1.223:2345
Remote debugging using 192.168.1.223:2345
[New thread 476]
Malformed packet(b) (missing colon): re:0;//数据包畸形
Packet: 'T050b:00000000;0d:509ef9be;0f:c0090040;thread:1dc;core:0;'
在目标机上面提示:
Remote debugging from host 192.168.1.224
readchar: Got EOF
Remote side has terminated connection.  GDBserver will reopen the connection.
readchar: Got EOF
求教问题出在哪里,是TCP参数需要重新设置一下吗?
 楼主| aoyun2008 发表于 2011-3-21 15:20 | 显示全部楼层
[root@GX3200 /]# gdbserver --debug --remote-debug :3456 /mount/hello
my_waitpid (474, 0x0)
my_waitpid (474, 0x0): status(137f), 474
my_waitpid (474, 0x0): status(1057f), 474
my_waitpid (475, 0x0)
my_waitpid (475, 0x0): status(137f), 475
my_waitpid (475, 0x0): status(9), 475
my_waitpid (474, 0x0): status(117f), 474
my_waitpid (474, 0x0): status(9), 474
new_argv[0] = "/mount/hello"
Process /mount/hello created; pid = 476
sigchld_handler
linux_wait: [Process 476]
linux_wait_for_lwp: <all threads>
my_waitpid (-1, 0x40000000)
my_waitpid (-1, 0x1): status(57f), 476
Got an event from 476 (57f)
stop pc is 400009c0
pc is 0x400009c0
stop pc is 0x400009c0
stop pc is 400009c0
linux_wait_for_lwp: pc is 0x400009c0
Hit a non-gdbserver trap event.
wait_for_sigstop: LWP 476 already stopped
Checking whether LWP 476 needs to move out of the jump pad...no
linux_wait ret = LWP 476.476, 1, 5
Listening on port 3456
handling possible accept event
linux_async (0), previous=0
handling possible serial event
[getpkt: discarding char '+']
getpkt ("Hc-1");  [sending ack]
[sent ack]
putpkt ("$E01#a6"); [looking for ack]
[received '+' (0x2b)]
getpkt ("qC");  [sending ack]
[sent ack]
putpkt ("$QC1dc#8c"); [looking for ack]
getpkt ("qOffsets");  [sending ack]
[sent ack]
putpkt ("$#00"); [looking for ack]
getpkt ("?");  [sending ack]
[sent ack]
Writing resume reply for LWP 476.476:1
putpkt ("$T050b:0*"00;0d:403ea0be;0f:c0090040;thread:1dc;core:0;#f7"); [looking for ack]
readchar: Got EOF
[getpkt: discarding char 'ÿ']
[gx@GxLinux mount]$ arm-uclibc-linux-gdb /home/share/mount/hello
(gdb) set debug remote 1
(gdb) set remote X-packet auto
(gdb) set remote P-packet auto
(gdb) set remote Z-packet auto
(gdb) target remote 192.168.1.223:3456
Remote debugging using 192.168.1.223:3456
Sending packet: $Hc-1#09...Ack
Packet received: E01
Sending packet: $qC#b4...Ack
Packet received: QC1dc
Sending packet: $qOffsets#4b...Ack
Packet received:
Sending packet: $?#3f...Ack
Packet received: T050b:00000000;0d:403ea0be;0f:c0090040;thread:1dc;core:0;
[New thread 476]
Packet: 'T050b:00000000;0d:403ea0be;0f:c0090040;thread:1dc;core:0;'
(gdb)
 楼主| aoyun2008 发表于 2011-3-21 15:23 | 显示全部楼层
gdbserver发送数据包
gdb接收数据包
$T050b:00000000;0d:403ea0be;0f:c0090040;thread:1dc;core:0;#f7
由于数据包0b后面的几位出错,导致checksum的时候提示错误的数据包,估计是这个原因导致
zhangkef0904 发表于 2011-5-26 11:04 | 显示全部楼层
主机这边没有指定调试的程序吧?你试着在target remote之前先执行
file /temp/hello
