IAR EW8051 8.10出来了
5726|0
 楼主| CC2530 发表于 2011-5-30 21:14 | 显示全部楼层 |阅读模式
http://www.iar.com/website1/1.0.1.0/244/1/
IAR Embedded Workbench?for 8051 includes the following new features and improvements: Version 8.10 C99 compliance The IAR C/C++ Compiler for 8051 now supports the ISO/IEC 9899:1999 standard. Updated runtime libraries CLIB has been extended to better support constants and strings placed in CODE memory. Improved debugging The number of hardware breakpoints used by the runtime library can now be configured, making it possible to free up more breakpoints for use in the application code. You can now start the debugger with or without downloading code, using two new buttons on the toolbar and two new Project menu commands. There are also two new corresponding ways to restart the debugger during the debug session. A new Timeline window in the simulator allows for graphically correlated visualization of the call stack and the interrupt log, plotted against time. New C-SPY Debugging Guide This new user guide is intended to help you take advantage of all features in the IAR C-SPY Debugger. New and updated device support files Complete list here...
个人签名:该死的ST,还不赶快出STM8L小FLASH片子
