[i.MX]
IMX6D从SD3启动失败
1561|0
我司参考公板自行设计了IMX6D核心板
        使用IC如下:
        CPU:MCIMX6D6AVT10AD
        DDR3:IS46TR16128B(双通道/4片)
        PMIC:MMPF0100NPAZES(NP)
        目前在调试过程中发现问题如下:
        1.使用MFGTools通过OTG下程序,在jumping OS image会卡住很长世间,随后出现附件图片错误
           Boot body="BootStrap" error, file="C:\Users\Administrator\Desktop\mfgtools\mfgtools\Profiles\Linux\OS Firmware\firmware\u-boot-imx6qsabresd_sd.imx"
           MFGTools Log信息如下:
           DLL version: 2.6.2Monday, December 11, 2017 16:40:30   Start new logging
ModuleID[2] LevelID[10]: CMyExceptionHandler thread is running
ModuleID[2] LevelID[1]: new MxHidDeviceClass
ModuleID[2] LevelID[10]: new MxHidDevice[04EAFC88]
ModuleID[2] LevelID[10]: new MxHidDevice[04F1B8B0]
ModuleID[2] LevelID[10]: new MxHidDevice[04F1EB68]
ModuleID[2] LevelID[10]: new MxHidDevice[04F63F10]
ModuleID[2] LevelID[10]: new MxHidDevice[04F63B08]
ModuleID[2] LevelID[10]: new MxHidDevice[04F6EF40]
ModuleID[2] LevelID[10]: Device Manager thread is running
ModuleID[2] LevelID[1]: Can't set m_hStopEvent before it initialized or it already stop
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 0
ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is C:\Users\Administrator\Desktop\mfgtools\mfgtools\Profiles\Linux\OS Firmware\firmware\u-boot-imx6qsabresd_sd.imx
ModuleID[2] LevelID[10]: CmdOperation[0], skip current command, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\Administrator\Desktop\mfgtools\mfgtools\Profiles\Linux\OS Firmware\firmware\zImage, address is 0x12000000
ModuleID[2] LevelID[10]: PortMgrDlg(0)--Command Load excute successfully, retry count: 0
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\Administrator\Desktop\mfgtools\mfgtools\Profiles\Linux\OS Firmware\firmware\fsl-image-mfgtool-initramfs-imx_mfgtools.cpio.gz.u-boot, address is 0x12C00000
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\Administrator\Desktop\mfgtools\mfgtools\Profiles\Linux\OS Firmware\firmware\zImage-imx6q-sabresd.dtb, address is 0x18000000
ModuleID[2] LevelID[10]: ExecuteCommand--Jump[WndIndex:0]
ModuleID[2] LevelID[10]: *********MxHidDevice[04F6EF40] Jump to Ramkernel successfully!**********
ModuleID[2] LevelID[10]: CmdOperation[0], current state command has been finished and the last command is successful, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[1]: MxHidDevice::Write() Error writing to device 0x79.
ModuleID[2] LevelID[1]: Failed to initialize memory!
ModuleID[2] LevelID[1]: PortMgrDlg(0)--MxHidDevice--Command Boot excute failed
ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: CCmdOpreation[0] thread is Closed
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - EVENT_KILL
ModuleID[2] LevelID[10]: CMyExceptionHandler::OnMsgExceptionEvent() - KillExceptionHandlerThread
ModuleID[2] LevelID[10]: Exception Handler thread is closed
ModuleID[2] LevelID[1]: delete MxHidDeviceClass
ModuleID[2] LevelID[10]: delete MxHidDevice[04F6EF40]
ModuleID[2] LevelID[10]: Device Manager thread is closed
           针对此问题是否需要更改MFGTools的firmware中的DDR配置文件?因为我司使用的DDR与公板不一样?
         2.尝试使用SD3卡启动(我司设计使用的SD3),BOOT MODES:10 Boot from board settings,拨码开关选择01000010选择从SD3启动,上电瞬间抓SD卡时钟波形失败,反复上电也未能抓到波形,SD启动一直失败,针对SD启动,是否需要配置SD卡中的程序?从未下载过程序的新板是否可
            以从SD启动?
         我司想从SD3启动,请帮忙看看还有什么方式方法可以使用,多谢。
