| 先上程序: module ht1621
 input        clk,
 input        rst_n,
 output reg         sdio,
 output reg         sclk,
 output reg         stb
 reg [15:0] olddata;
 reg [4:0] currentstate;
 parameter s1 = 5'b0_0001;
 parameter s2 = 5'b0_0010;//设置工作模式
 parameter s3 = 5'b0_0011;
 parameter s4 = 5'b0_0100;//固定地址写数据
 parameter s5 = 5'b0_0101;//
 parameter s6 = 5'b0_0110;//S6和S5状态设置扫描限值寄存器
 parameter s7 = 4'b0_0111;//
 parameter s8 = 5'b0_1000; //S7和S8状态 设置正常显示模式
 parameter s10 =5'b0_1010;//
 parameter s11 =5'b0_1011;//s10和是1状态 送入显示的数据
 parameter Init=5'b1_1110;
 parameter Init1=5'b1_1111;
 reg [5:0]counter;
 parameter
 seg1 = 16'h14ab,
 seg2 = 16'h14bc,
 seg3 = 16'h14cd,                                //1.
 seg4 = 16'h14de,                                //2
 seg5 = 16'h14ef,                                //3
 seg6 = 16'h14ff;                                //4
 reg [2:0]cnt;
 //产生时钟
 always @(posedge clk)
 begin
 if(!rst_n) begin
 counter<=6'd0;
 sclk <= 1'b1;
 end
 else begin
 if(counter==6'd32) begin
 sclk <= ~sclk;
 counter<=6'd0;
 end
 else counter<=counter+6'd1;
 end
 end
 reg [3:0] sclk_cnt;//同步时钟计数器,15
 always @(posedge sclk or negedge rst_n)
 begin
 if(!rst_n) sclk_cnt <= 1'b0;
 else
 case(currentstate)
 Init1,s2,s4,s6,s8,s11:
 if(4'd15  == sclk_cnt)
 sclk_cnt <= 1'b0;
 else         sclk_cnt <= sclk_cnt + 1'b1;
 default: sclk_cnt <= 1'b0;
 endcase
 end
 reg [15:0] data;
 //主状态机
 begin
 if(!rst_n) begin currentstate <=Init; cnt = 3'b0; end
 else
 case(currentstate)
 Init:currentstate <=Init1;
 Init1:begin
 if(4'd15 == sclk_cnt) //16个时钟周期将数据送出去
 currentstate <= s7;
 else
 currentstate <= Init1;
 end
 s1: currentstate <= s2;  //s1和S2状态设置译码寄存器
 s2:begin
 currentstate <= s3;
 else
 currentstate <= s2;
 end
 s3: currentstate <= s4;//S3和S4状态设置亮度寄存器
 s4: begin
 currentstate <= s5;
 else
 currentstate <= s4;
 end
 s5: currentstate <= s6;//        S6和S5状态设置扫描限值寄存器
 s6: begin
 currentstate <= s10;
 else
 currentstate <= s6;
 end
 s7: currentstate <= s8;//        S7和S8状态 设置正常显示模式
 s8: begin
 currentstate <= s1;
 else
 currentstate <= s8;
 end
 //初始化完成
 s10: if(olddata != data)
 currentstate <= s11;//        正常送数据显示
 else
 s11: begin
 begin
 cnt = cnt + 1'b1;
 end
 else
 end
 endcase
 end
 begin
 if(!rst_n)begin  data <= 16'h0000; olddata <= 16'h0000; end
 else case(currentstate)
 Init:data <= 16'h0852;                //0b1000 0101 0010 1/3duty 4com
 s7: data <= 16'h0830;   //0b1000 0011 0000 内部时钟
 s1: data <= 16'h080A;        //0b1000 0000 1010 禁止看门狗
 s3: data <= 16'h0802;        //0b1000 0000 0010 打开系统振荡器
 s5: data <= 16'h0806;   //0b1000 0000 0110 打开LCD偏压
 s10: begin
 case(cnt)
 3'd0: data <= seg1;
 3'd1: data <= seg2;
 3'd2: data <= seg3;
 3'd3: data <= seg4;
 3'd4: data <= seg5;
 3'd5: data <= seg6;
 endcase
 olddata <= data;
 end//{4'b0000,dd,4'b000,dd};olddata <=16'h0c01;end//{4'b0000,4'd4,8'd6};olddata <= {4'b0000,4'd4,8'd6};;;end//16'h080e;  //待显示的数据
 Init1,s2,s4,s6,s8,s11: begin data <= data << 1;        olddata <= olddata; end//循环移位 将高位送出
 default: begin data <= 16'h0000; olddata <= olddata; end
 endcase
 end
 //----------数据串行---------
 begin
 if(!rst_n) sdio <= 1'b0;
 Init1,s2,s4,s6,s8,s11: sdio <= data[15];
 default: sdio <= 1'b0;
 endcase
 end
 //----------串行数据写有效LOAD----------
 begin
 if(!rst_n) stb <= 1'b1;
 Init1,s2,s4,s6,s8,s11: stb <= 1'b0;  //送数的时候处于低
 default: stb <= 1'b1; //非送数时候,拉高 锁存数据
 endcase
 end
 endmodule
 可是下载到板子里,液晶一段也不亮。
 请高手看看,哪里有问题。谢谢!
