[应用相关] 有没有人提供一个I2C中断程序。等着用呢。
1116|17
 楼主| zhanghqi 发表于 2019-1-16 16:30 | 显示全部楼层 |阅读模式
dengdc 发表于 2019-1-16 16:33 | 显示全部楼层
楼主详细说说怎么回事啊,这么说太笼统了
 楼主| zhanghqi 发表于 2019-1-16 16:36 | 显示全部楼层
硬件查询的方法,硬件I2C老是怪掉,奇了怪了。
jiahy 发表于 2019-1-16 16:40 | 显示全部楼层
ST 的函数库里的例子还是比较丰富的, 去哪里找找呢
lizye 发表于 2019-1-16 16:45 | 显示全部楼层
  * @brief  This function handles I2C1 Event interrupt request, tx, rx
  *         buffer and number of bytes will be changed.
  * @param  None
  * @retval None
void I2C1_EV_IRQHandler(void)
#ifdef ARC_I2C_IRQ
    uint32_t i2cEvent;
    I2C_param_struct __IO *pI2C_param;
    pI2C_param = ARC_get_I2C_param();
    i2cEvent = I2C_GetLastEvent(I2C1);
    switch (i2cEvent)
        case I2C_EVENT_MASTER_MODE_SELECT:/* EV5 */
            if(pI2C_param->I2C_DIRECTION == ARC_I2C_DIRECTION_TX)
                I2C_Send7bitAddress(I2C1, pI2C_param->DeviceAddr, I2C_Direction_Transmitter);
            else
                I2C_Send7bitAddress(I2C1, pI2C_param->DeviceAddr, I2C_Direction_Receiver);
            break;
        /* Master Transmitter -------------------------------------------------------*/
        case I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED:
            I2C_SendData(I2C1, pI2C_param->SubAddr);
            if(pI2C_param->TxNumOfBytes == 0)
                I2C_ITConfig(I2C1, I2C_IT_BUF, DISABLE);
            break;
        case I2C_EVENT_MASTER_BYTE_TRANSMITTING:  /* Without BTF, EV8 */
            if(pI2C_param->TX_I2C_Index < pI2C_param->TxNumOfBytes)
                I2C_SendData(I2C1, pI2C_param->TxData[pI2C_param->TX_I2C_Index++]);
            else
            break;
        case I2C_EVENT_MASTER_BYTE_TRANSMITTED: /* With BTF EV8-2 */
           if(pI2C_param->TX_Generate_stop == 1)
             I2C_GenerateSTOP(I2C1, ENABLE);
             I2C_ITConfig(I2C1, I2C_IT_EVT, DISABLE);
           else
             pI2C_param->I2C_DIRECTION = ARC_I2C_DIRECTION_RX;
             I2C_ITConfig(I2C1, I2C_IT_BUF, ENABLE);
             I2C_GenerateSTART(I2C1, ENABLE);
           break;
        /* Master Receiver -------------------------------------------------------*/
        case I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED:
            if(pI2C_param->RX_I2C_Index == (pI2C_param->RxNumOfBytes - 1))
                I2C_AcknowledgeConfig(I2C1, DISABLE);
            break;
        case I2C_EVENT_MASTER_BYTE_RECEIVED:
            pI2C_param->RxData[pI2C_param->RX_I2C_Index++] = I2C_ReceiveData (I2C1);
            break;
        default:
            break;
#endif
shimx 发表于 2019-1-16 16:48 | 显示全部楼层
我在调TEL6621的时候的一个I2C 程序。用的是中断
注意: TEL6621 的I2C read 是如下这样的
start  ADDR  D0 D1 D2 D3 STOP
I2C.C
shimx 发表于 2019-1-16 16:51 | 显示全部楼层
#include "main.h"
I2C_StruDef I2C1;
void Bsp_I2CInit(void)
CLK_PCKENR1 |= 0x01;
I2C_CR1    = 0x00;       //禁用I2C外设
//如果需产生100k的时钟,假始输入时钟为8MHz,则Tck = 125ns.
//因为100k时钟半个周期为5us(5000ns), CCR = 5000/125 = 40(28h)
I2C_FREQR  = 16;         //输入外设时钟频率为16MHz (如果设置为8M, 实际输入是16M时,I2C时钟以16M为准)
I2C_CCRH   = 0x00;       //标准模式
I2C_CCRL   = 0x50;
//标准模式下,最大允许上升时间为1000ns, 因为Tck = 125ns,
//则TRISER = (1000 / 125 + 1) = 9
I2C_TRISER = 0x09;       //设置上升时间
I2C_CR1    = 0x01;       //开启I2C外设
void Bsp_I2CWrite(uint8_t Dev_Addr, uint8_t Sub_Addr, uint8_t* pdata, uint16_t num)
if(0x02 == (I2C_SR3 & 0x02))
  else
  I2C1.State      = I2C_WRITEMODE;
  I2C1.DeviceAddr = Dev_Addr;
  I2C1.SubAddr    = Sub_Addr;
  I2C1.Tx_I2C_Buf = pdata;
  I2C1.Tx_Cnt     = num;
  I2C1.Rx_Cnt     = 0;
  I2C1.Cnt        = 0;
  I2C_ITR = 0x07; //使能事件和出错中断, 缓冲中断
  I2C_CR2 = 0x01; //产生开始位
void Bsp_I2CRead(uint8_t Dev_Addr, uint8_t Sub_Addr, uint8_t* pdata, uint16_t num)
else
  I2C1.State      = I2C_READMODE;
  I2C1.Rx_I2C_Buf = pdata;
  I2C1.Rx_Cnt     = num;
  I2C1.Tx_Cnt     = 0;
  I2C1.Cnt        = 0;
TIM2DlyHMSM(0, 0, 0, 10);
void I2C_Interrupt_Handler(void)
uint8_t temp;
if(0x01 == (I2C_SR1 & 0x01)) //EV5, 开始位已发送
  temp = I2C_SR1;
  if(I2C_WRITEMODE == I2C1.State)
   I2C_DR = I2C1.DeviceAddr & 0xfe;
  else if(I2C_READMODE == I2C1.State)
   I2C_DR = I2C1.DeviceAddr | 0x01;
  else;
else if(0x02 == (I2C_SR1 & 0x02)) //EV6, 器件地址已发送
  temp = I2C_SR1;
  temp = I2C_SR3;
   I2C_DR = I2C1.SubAddr;
   if(I2C1.Rx_Cnt > 1)        I2C_CR2 = 0x04;
      else if(I2C1.Rx_Cnt == 1)  I2C_CR2 = 0x00;
   else                       I2C_CR2 = 0x02;  //产生STOP位
  else;
else if(0x40 == (I2C_SR1 & 0x40)) //EV7
  if(I2C1.Cnt < (I2C1.Rx_Cnt - 1))
   I2C1.Rx_I2C_Buf[I2C1.Cnt] = I2C_DR;
   I2C1.Cnt++;
   if(I2C1.Cnt == (I2C1.Rx_Cnt - 1))
    I2C_CR2 = 0x02;  //产生STOP位, no ack
  else if(I2C1.Cnt == (I2C1.Rx_Cnt - 1))
  else;
else if(0x80 == (I2C_SR1 & 0x80)) //EV8
  temp = I2C_SR1;
  if(I2C1.Cnt < I2C1.Tx_Cnt)
   I2C_DR = I2C1.Tx_I2C_Buf[I2C1.Cnt];
   I2C1.Cnt++;
  else
else
  printf("\r\n I2C_SR1 = %x", (uint16_t)I2C_SR1);
  temp = I2C_SR1;
if(I2C_SR2)
  printf("\r\n I2C_SR2 = %x", (uint16_t)I2C_SR2);
  I2C_SR2 = 0;
spark周 发表于 2019-1-16 16:55 | 显示全部楼层
I2C.H
#ifndef _BSP_I2C_H_
#define _BSP_I2C_H_
#define I2C_WRITEMODE      0
#define I2C_READMODE       1
typedef struct
  uint8_t  State;
  uint16_t Cnt;
  uint16_t Rx_Cnt, Tx_Cnt;
  uint8_t  DeviceAddr;
  uint8_t  SubAddr;
  uint8_t  *Rx_I2C_Buf;
uint8_t  *Tx_I2C_Buf;
}I2C_StruDef;
extern I2C_StruDef I2C1;
void Bsp_I2CInit(void);
void Bsp_I2CWrite(uint8_t Dev_Addr, uint8_t Sub_Addr, uint8_t* pdata, uint16_t num);
void Bsp_I2CRead(uint8_t Dev_Addr, uint8_t Sub_Addr, uint8_t* pdata, uint16_t num);
void I2C_Interrupt_Handler(void);
#endif
午夜粪车 发表于 2019-1-16 16:58 | 显示全部楼层
ST提供I2C和CPAL两种I2C通信例程库
LZ都可以下载了参考
 楼主| zhanghqi 发表于 2019-1-16 17:01 | 显示全部楼层
非常感谢大家。按照大家的方法,我的I2C中断法已经成功了。
mmuuss586 发表于 2019-1-16 21:04 | 显示全部楼层
官方例程里不是有吗?
guanjiaer 发表于 2019-2-11 12:09 | 显示全部楼层
亲 用cube生成一个就行
heimaojingzhang 发表于 2019-2-11 12:10 | 显示全部楼层
去官网下载一个好了
renzheshengui 发表于 2019-2-11 12:52 | 显示全部楼层
网上有的是  再不行就官网搜搜
wakayi 发表于 2019-2-11 12:55 | 显示全部楼层
iic怎么中断?
wowu 发表于 2019-2-11 12:57 | 显示全部楼层
楼主知道到合适的程序了吗
xiaoqizi 发表于 2019-2-11 13:04 | 显示全部楼层
别人提供的 自己需要进行移植吧
木木guainv 发表于 2019-2-11 15:09 | 显示全部楼层
外挂器件不同 是不是时序也不太一样呢
