[MCU] 宏定义
888|23
 楼主| spark周 发表于 2019-9-24 21:35 | 显示全部楼层 |阅读模式
AD, ADC, CD, dc, TE
汇编手册的宏定义很简单,而且后面的参数 P1 P2 啊这些都有用到,
add3 .macro P1, P2, P3, ADDRP
MOV ACC, P1
ADD ACC, P2
ADD ACC, P3
ADD ACC, ADDRP
.endm
为什么下面的宏定义里面就没有任何关于m,n这些参数的应用。
ADCDRV_8ch_INIT    .macro m,n,p,q,r,s,t,u
_ADCDRV_8ch_RltPtrA    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 1
_ADCDRV_8ch_RltPtrB    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 2
_ADCDRV_8ch_RltPtrC    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 3
_ADCDRV_8ch_RltPtrD    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 4
_ADCDRV_8ch_RltPtrE    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 5
_ADCDRV_8ch_RltPtrF    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 6
_ADCDRV_8ch_RltPtrG    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 7
_ADCDRV_8ch_RltPtrH    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 8
; publish Terminal Pointers for access from the C environment
        .def     _ADCDRV_8ch_RltPtrA
        .def    _ADCDRV_8ch_RltPtrB
        .def    _ADCDRV_8ch_RltPtrC
        .def    _ADCDRV_8ch_RltPtrD
        .def     _ADCDRV_8ch_RltPtrE
        .def    _ADCDRV_8ch_RltPtrF
        .def    _ADCDRV_8ch_RltPtrG
        .def    _ADCDRV_8ch_RltPtrH
        MOVL    XAR2, #ZeroNet                        ; "ZeroNet" is address to a location initialised to 0
        MOVW    DP, #_ADCDRV_8ch_RltPtrA
        MOVL    @_ADCDRV_8ch_RltPtrA, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrB, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrC, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrD, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrE, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrF, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrG, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrH, XAR2            ; zero output terminal pointer
        .endm
jiaxw 发表于 2019-9-24 21:39 | 显示全部楼层
_ADCDRV_8ch_RltPtrA,这些是定义地址的,它可以在CMD文件中找到,或者用#pragma 转向
上面是定义指令的,
liliang9554 发表于 2019-9-24 21:42 | 显示全部楼层
有没有可能这些变量在其它地方使用过,又或者这个程序经过许多人改过,原来使用了,现在没有这些变量。
 楼主| spark周 发表于 2019-9-24 21:48 | 显示全部楼层
呵呵,想法很多啊大家
kkzz 发表于 2019-10-2 16:00 | 显示全部楼层
使用简单宏定义可用宏代替一个在程序中经常使用的常量
hudi008 发表于 2019-10-2 16:01 | 显示全部楼层
宏定义是高级语言编译器提供的常用语法
lzmm 发表于 2019-10-2 16:01 | 显示全部楼层
主要目的是为程序员在编程时提供一定的方便
minzisc 发表于 2019-10-2 16:01 | 显示全部楼层
宏定义是比较常用的预处理指令
selongli 发表于 2019-10-2 16:02 | 显示全部楼层
#define 是预处理期处理的单元实体
fentianyou 发表于 2019-10-2 16:02 | 显示全部楼层
宏定义是利用#define命令,用一个指定的标识代替一个字符串。
xiaoyaodz 发表于 2019-10-2 16:02 | 显示全部楼层
宏定义在函数内部和定义在函数外部的效果是一样的。
febgxu 发表于 2019-10-2 16:03 | 显示全部楼层
宏定义在编译期间即会使用并替换
sdlls 发表于 2019-10-2 16:03 | 显示全部楼层
宏定义的只是一段字符
pixhw 发表于 2019-10-2 16:04 | 显示全部楼层
在运行中是没有宏定义的概念的。
febgxu 发表于 2019-10-2 16:04 | 显示全部楼层
全局变量要到运行时才可以。
kkzz 发表于 2019-10-2 16:04 | 显示全部楼层
在将该常量改变时,不用对整个程序进行修改,只修改宏定义的字符串即可
xiaoyaodz 发表于 2019-10-2 16:04 | 显示全部楼层
在C中,常用预处理语句#define来代替一个函数定义。
hudi008 发表于 2019-10-2 16:04 | 显示全部楼层
#define是C语言中提供的宏定义命令
fentianyou 发表于 2019-10-2 16:04 | 显示全部楼层
宏定义是在预编译时是就决定的,在程序运行时是不能改的
lzmm 发表于 2019-10-2 16:04 | 显示全部楼层
能在一定程度上提高程序的运行效率
