#include "SC95F861x_C.H" #include "intrins.H" volatile unsigned int TimeTick; //========================================================== //======================================================= void Uart0_Init(unsigned long baud) { //Uart0初始化 P20=RX,P21=TX SCON = 0X50; //异步10bit通信,允许接收 //Timer1波特率 baud=sysclk(32MHz)/(TH1:TL1) TMOD = 0X11; TCON = 0X00; TMCON = 0X00; TL1 = 32*1000000/baud; //波特率低位控制 TH1 = (32*1000000/baud)>>8; //波特率高位控制 TR1 = 0; EUART = 0; //串口中断使能off } void Uart0Send(unsigned char ch) { SBUF = ch; while(TI == 0); TI = 0; } void Uart0SendStr(unsigned char *s) { while(*s != 0) { Uart0Send(*s++); } } void Uart0SendStrlen(unsigned char *s,unsigned int len) { while(len != 0) { Uart0Send(*s++); len--; } } //================================================================= // //================================================================= volatile unsigned int Time_1ms; void Delay_ms(unsigned int ms) { Time_1ms = ms; while(Time_1ms); } //============================================================= void Timer0_Init(void) { //Timer0 TMOD = 0X11; //16位定时器 TCON = 0X00; TMCON = 0X00; //12分频 TL0 = (65536-(32000000)/(12*1000)); //定时1ms TH0 = (65536-(32000000)/(12*1000))>>8; // TR0 = 1; ET0 = 1; //中断 } int main(void) { P0CON = 0x00; //设置P0为输入带上拉模式 P0PH = 0xFF; P1CON = 0x00; //设置P1为高阻输入模式 P1PH = 0x00; P2CON = 0xFC; //设置P20,P21为输入带上拉模式,其他推挽输出 P2PH = 0xFF; P3CON = 0xFF; //设置P3为强推挽模式 P3PH = 0x00; P4CON = 0xFF; //设置P4为强推挽模式 P4PH = 0x01; P5CON = 0xFF; //设置P5为强推挽模式 P5PH = 0x00; TimeTick = 0; Uart0_Init(115200); Timer0_Init(); EA = 1; Delay_ms(1000); while(1) { Delay_ms(1000); P52 =~P52; P53 =~P53; Uart0SendStr("SinOne SC95F8617 Test. By WoodData.\n"); } return 0; } //=============================================== //中断 void Timer0_ISR() interrupt 1 { TL0 = (65536-(32000000)/(12*1000)); //定时1ms TH0 = (65536-(32000000)/(12*1000))>>8; // if(Time_1ms) Time_1ms--; TimeTick++; } void Uart0_ISR() interrupt 4 { if(TI) { TI = 0; } if(RI) { RI = 0; } } 效果如图:
收藏0 举报
#include "SC95F861x_C.H" #include "intrins.H" volatile unsigned int TimeTick; unsigned int Pwm_duty; unsigned char Pwm_flag; unsigned int xdata PWMRD_40 _at_ 0x1040; unsigned int xdata PWMRD_41 _at_ 0x1042; unsigned int xdata PWMRD_42 _at_ 0x1044; unsigned int xdata PWMRD_43 _at_ 0x1046; unsigned int xdata PWMRD_50 _at_ 0x1048; unsigned int xdata PWMRD_51 _at_ 0x104A; unsigned int xdata PWMRD_52 _at_ 0x104C; unsigned int xdata PWMRD_53 _at_ 0x104E; //========================================================== //======================================================= void Uart0_Init(unsigned long baud) { //Uart0初始化 P20=RX,P21=TX SCON = 0X50; //异步10bit通信,允许接收 //Timer1波特率 baud=sysclk(32MHz)/(TH1:TL1) TMOD = 0X11; TCON = 0X00; TMCON = 0X00; TL1 = 32*1000000/baud; //波特率低位控制 TH1 = (32*1000000/baud)>>8; //波特率高位控制 TR1 = 0; EUART = 0; //串口中断使能off } void Uart0Send(unsigned char ch) { SBUF = ch; while(TI == 0); TI = 0; } void Uart0SendStr(unsigned char *s) { while(*s != 0) { Uart0Send(*s++); } } void Uart0SendStrlen(unsigned char *s,unsigned int len) { while(len != 0) { Uart0Send(*s++); len--; } } //================================================================= // //================================================================= volatile unsigned int Time_1ms; void Delay_ms(unsigned int ms) { Time_1ms = ms; while(Time_1ms); } //============================================================= void Timer0_Init(void) { //Timer0 TMOD = 0X11; //16位定时器 TCON = 0X00; TMCON = 0X00; //12分频 TL0 = (65536-(32000000)/(12*1000)); //定时1ms TH0 = (65536-(32000000)/(12*1000))>>8; // TR0 = 1; ET0 = 1; //中断 } //============================================ //周期 (0x63F+1)/32(MHz) = 50us 周期 //占空比 0x320/(0x63F+1) = 50% void PWM_Init(void) { PWMMOD = 0x00; //独立模式,边沿对齐 PWMCFG = 0x86; //7:开关 5-4:时钟源选择 3-0:周期设置高4位 PWMCON = 0x3F; //周期设置低8位,50us PWMRD_52 = 0x8000 | 0x320; //开启PWM口,设置占空比 PWMRD_53 = 0x8000 | 0x320; //开启PWM口,设置占空比 IE1 |= 0x02; //开启中断标志位 } //============================================== int main(void) { P0CON = 0x00; //设置P0为输入带上拉模式 P0PH = 0xFF; P1CON = 0x00; //设置P1为高阻输入模式 P1PH = 0x00; P2CON = 0xFC; //设置P20,P21为输入带上拉模式,其他推挽输出 P2PH = 0xFF; P3CON = 0xFF; //设置P3为强推挽模式 P3PH = 0x00; P4CON = 0xFF; //设置P4为强推挽模式 P4PH = 0x01; P5CON = 0xFF; //设置P5为强推挽模式 P5PH = 0x00; TimeTick = 0; Pwm_duty = 0x320; Pwm_flag = 0; Uart0_Init(115200); Timer0_Init(); PWM_Init(); EA = 1; Delay_ms(1000); while(1) { Delay_ms(100); Uart0SendStr("SinOne SC95F8617 Test. By WoodData.\n"); PWMRD_52 = 0x8000 | Pwm_duty; //开启PWM口,设置占空比 PWMRD_53 = 0x8000 | Pwm_duty; //开启PWM口,设置占空比 if(Pwm_flag == 0) { Pwm_duty += 0x10; if(Pwm_duty >= 0x640) { Pwm_flag = 1; } }else { Pwm_duty -= 0x10; if(Pwm_duty <= 0x320) { Pwm_flag = 0; } } } return 0; } //=============================================== //中断 void Timer0_ISR() interrupt 1 { TL0 = (65536-(32000000)/(12*1000)); //定时1ms TH0 = (65536-(32000000)/(12*1000))>>8; // if(Time_1ms) Time_1ms--; TimeTick++; } void PWM_Interrup() interrupt 8 { if(PWMCFG & 0x40) { PWMCFG &= ~0x40; //清除中断标志位 } } void Uart0_ISR() interrupt 4 { if(TI) { TI = 0; } if(RI) { RI = 0; } }
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
发帖类勋章
时间类勋章
人才类勋章
等级类勋章
127
4786
28
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
