busybox1.1.3制作yaffs文件系统ARM,busybox,LINUXandroid
550|0
 楼主| 冰糖炖雪梨 发表于 2018-8-24 15:48 | 显示全部楼层 |阅读模式
  OK-2440-III文件系统移植--busybox+mdev
  Busybox版本:busybox1.1.3
  编译工具:arm-linux-3.3.2
  目标板:FLOK-2440-III
  编译平台:redhat9
  一、配置安装busybox
  1.配置busybox:
  #    make menuconfig
  Busybox Settings
  General Configuration
  Support for devfs
  Build Options
  Build with Large File Support(for accessing files  2GB)
  Do you want to build Busybox with a Cross Compiler?
  (/usr/local/arm/3.3.2/bin/arm-linux-)Cross Compiler prefix
  //上面的选项用来指定编译工具,我刚开始没有选择这个选项,结果编译出文件系统下到开发板上运行,串口打印信息为:
  大家可以试试。
  Init Utilities  init Support reading an inittab file   Be _extra_ quiet on boot    Support running init from within an initrd (not initramfs) poweroff, halt, and reboot mesg
  Shells
  Choose your default shell (ash)
  (X) ash
  ()hush
  ()lash
  ()nsh
  ()none
  --- ash
  --- Ash Shell Options
  --- Bourne Shell Options
  Hide message on interactive shell startup
  Standalone shell
  command line editing
  vi-style line editing commands
  (15)  history size
  history saving
  tab completion
  username completion
  Fancy shell prompts
  Coreutils
  cp
  cat
  ls
  mkdir
  echo (basic SuSv3 version taking no options)
  env
  mv
  pwd
  rm
  touch
  Editors
  vi
  Linux System Utilities  mdev                //不选这个启动不起来系统,大家可以去掉试试看有什么现象   Support /etc/mdev.conf     mount
  umount
  Support loopback mounts
  Support for the old /etc/mtab file
  Linux Module Utilities---
  insmod
  rmmod
  lsmod
  lsmod pretty output for 2.6.x Linux kernels
  modprobe
  Multiple options parsing
  --- Options common to multiple modutils
  Support tainted module checking with new kernels
  Support version 2.2.x to 2.4.x Linux kernels  //此项一定不要选!!!
  Support version 2.6.x Linux kernels
  Networking Utilities
  ifconfig
  ping
  Archival Utilities---
  tar
  Enable archive creation (NEW)
  Enable -j option to handle .tar.bz2 files
  现在配置完成,保存退出之后,执行:make 编译
  #    make ARCH=arm CROSS_COMPILE=/usr/local/arm/3.3.2/bin/arm-linux-
  成功编译完成后执行make install安装
  #    make install
  这样就在busybox1.1.3目录下产生_install文件夹,里面就是编译好的文件系统。
  2、创建根文件系统目录
  要创建的目录有:bin sbin dev etc lib home root usr var proc mnt tmp sys
  可以先创建一个目录比如/usr/src/rootfs,然后进入该目录,创建以上目录。
  #    cd /usr/src/
  #    mkdir rootfs
  #    cd rootfs
  #    mkdir bin sbin dev etc lib home root usr var proc mnt tmp sys
  目录创建好之后把busybox生成的_install目录里那些都复制过来。
  接下来我们要在etc目录下创建两个文件和一个文件夹,两个文件分别为fstab和inittab,文件夹为init.d。
  (1)
  #    cd etc
  #    vi fstab
  fstab的内容是:
  #device        mount-point        type            options        dump        fsck    order
  proc       /proc            proc         defaults           0            0
  tmpfs       /tmp            tmpfs         defaults         0             0
  sysfs       /sys             sysfs        defaults         0             0
  tmpfs       /dev             tmpfs         defaults            0            0
  文 件/etc/fstab用来定义文件系统的“静态信息”,这些信息被用来控制mount命令的行为。
  (2)
  #     vi inittab
  inittab的内容是:
  #/etc/inittab
  ::sysinit:/etc/init.d/rcS
  s3c2410_serial0::askfirst:-/bin/sh    如果不使用mdev则s3c2410_serial0改ttySAC0
  ::ctrlaltdel:/sbin/reboot
  ::shutdown:/bin/umount -a -r
  (3)
  #    mkdir init.d
  #    cd init.d
  #    vi rcS
  init.d\rcS文件的内容:
  #!/bin/sh
  ifconfig eth0 192.168.1.17
  mount -t tmpfs mdev /dev
  mkdir /dev/pts
  mount -t devpts devpts /dev/pts
  mount -t sysfs sysfs /sys
  mount -a
  echo /sbin/mdev  /proc/sys/kernel/hotplug
  mdev –s
  echo My first rootfs
  将rcS文件的属性改成可执行的,这一步很重要,必须改。
  #    chmod 775 etc/init.d/rcS
  (4)我在配置busybox的时候用的是动态库,,所以要把/usr/local/arm/3.4.1/arm-linux/lib下面的3个库文件和一个加载器拷贝到/filesystem_install/lib下:ld-2.3.2.so ld-linux.so.2 libc.so.6libcrypt.so.1libm.so.6
  (5)在/usr、src/rootfs/dev下建立设备节点:
  Console  null
  #    sudo mknod console c 5 1
  #    sudo mknod null c 1 3
  到此为止,必要的文件已经建立好了,现在要生成yaffs文件系统。
  我们用光盘里带的mkyaffs2image工具来生成。将其解压拷贝到主机的/bin目录下即可。转到建立的那个/rootfs目录的上一级,也就是/usr/src目录,然后执行:mkyaffs2image rootfs rootfs.yaffs 就可以生成文件系统镜像了,将rootfs.yaffs烧进板子,当看到My first rootfs Please press Enter to activate this console.就表明你成功了!!!
我的也成功了,不过也看一看看这个。
我的停在:
  VFS: Mounted root (yaffs filesystem).
  Mounted devfs on /dev
  Freeing init memory: 160K
  不走了
  按回车还能换行
回复 9# yaoyulian
  你的rcS文件写的对吗?
我的板子是OK2440IV,它提供的文件系统是qte_yaffs.tar.bz2,解压,用mkyaffs2image 工具来制作文件系统:./mkyaffs2image qte_yaffs qte.yaffs 0
  我不知道是不是就不需要在使用busybox制作了。如果要将应用程序烧进去,是不是只需要放到bin下烧写即可。望指教!!
回复 13# gyzwl
  板子理带的那个qte。。。的文件系统是带GUI的文件系统,这个是最简单的文件系统,不是用不用的问题,学会做文件系统是学习的一部分,这是个过程,也是学好这个必经的过程
先攒钱,,,,
回复 16# yongma62
  想问一下lz,不带GUI的文件系统启动后是什么样子?黑屏吗?
  飞凌提供的qte_yaffs文件系统是否可以运行其他GUI程序,如minigui?
  楼主脑残么,发个制作文件系统的帖子有必要要那么多金币么
  你自己之所以能弄成功,不也是前辈们辛苦摸索,总结出来的经验么
  无聊
购买了就没有金币了。。。穷哦。。。。
楼主,问个问题。我按照你的做法试了一下。不过出现如下问题:
  Starting pid 378, console /dev/tts/0: '/etc/init.d/rcS'
  Bummer, could not run '/etc/init.d/rcS': No such file or direct
  请问是什么问题呢?
飞凌OK-2440-III文件系统移植--busybox+mdev
  目标板:飞凌OK-2440-III
  编译平台:redhat9
  一、配置安装busybox
  1.配置busybox:
  #  make menuconfig
  Busybox Settings
  Support for devfs
  Build Options
  大家可以试试。
  Init Utilities
  init
  mesg
  Shells
  (X) ash
  ()hush
  ()lash
  ()nsh
  ()none
  --- ash
  Standalone shell
  (15)  history size
  history saving
  tab completion
  username completion
  Fancy shell prompts
  Coreutils
  cp
  cat
  ls
  mkdir
  env
  mv
  pwd
  rm
  touch
  Editors
  vi
  mount
  umount
  insmod
  rmmod
  lsmod
  modprobe
  ifconfig
  ping
  tar
  #  make install
  2、创建根文件系统目录
  #  cd /usr/src/
  #  mkdir rootfs
  #  cd rootfs
  (1)
  #  cd etc
  #  vi fstab
  fstab的内容是:
  (2)
  #   vi inittab
  inittab的内容是:
  #/etc/inittab
  (3)
  #  mkdir init.d
  #  cd init.d
  #  vi rcS
  init.d\rcS文件的内容:
  #!/bin/sh
  mkdir /dev/pts
  mount -a
  mdev –s
  Console  null
请教楼主:在配置好busybox后,出现如下问题:
  [root@localhost busybox-1.1.3]# make
  /bin/sh: line 1: /usr/i386-linux-uclibc/bin/i386-uclibc-gcc: 没有那个文件或目录
  /bin/sh: line 1: /usr/i386-linux-uclibc/bin/i386-uclibc-ld: 没有那个文件或目录
  GEN include/bbconfigopts.h
  GEN .depend
  CC applets/applets.o
  make[1]: *** [/tmp/gaoyg/busybox-1.1.3/busybox-1.1.3/applets/applets.o]
  Error 127
  make: *** [_all]
  Error 2
  不知道问题出在哪了,该如何解决呢?请多指教,不胜感激。
“(4)我在配置busybox的时候用的是动态库,,所以要把/usr/local/arm/3.4.1/arm-linux/lib下面的3个库文件和一个加载器拷贝到/filesystem_install/lib下:ld-2.3.2.so ld-linux.so.2 libc.so.6libcrypt.so.1libm.so.6
  请问这一步里面的库文件和加载器应该是/usr/local/arm/3.3.2/arm-linux/lib 吧?
  然后是拷到我们自己创建的文件系统目录里面的lib文件夹下吧?也就是/usr/src/rootfs/lib
  如果是的话,我的怎么到这一步就卡住了
  Freeing init memory: 132K
  /linuxrc: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
  Kernel panic - not syncing: Attempted to kill init!
  请楼主给解释一下,如果可以,能把你创建的文件系统的目录,就是/usr/src/rootfs这个文件夹打包发给我看看吗?不胜感激啊!!596468834@qq.com
回复 1# yongma62
  感谢分享!
请教楼主:我按资料说的方法制作文件系统,结果在运行后出现如下错误:
  Failed to execute /linuxrc.Attempting defaults...
  Kernel panic - not syncing: No init found.Try passing init= option to kernel.
  是怎么回事呢?帮忙解决下。。非常感谢。
楼主,你好。为什么你用ARM-LINUX-3.3.2动态编译BUSYBOX1.1.3,那为什么要把/3.4.1/arm-linux/lib拷到/filesystem_install/lib下呢。而不拷/3.3.2/arm-linux/lib的库呢?
适合飞凌的所有的开发板不?
  我OK6410的说
我没有钱啊,怎么办 郁闷了……………………………………
先攒钱,,,,
  看看,,学些
挺他妈垃圾一个人,搞个文件系统还要钱,你他妈也就是这个水平了。
非常感谢。。。。。。。。。。。。。。。。。。。。。
回复 12# yongma62
  rc.S文件的作用是什么?
学习学习,谢谢分享!
看不太懂啊,这样重新制作busybox后就可以ping域名了吗?
没钱了,呜呜。。。。。
  呜呜,没钱真可怜
  楼主可以免费发放不,邮箱526216967@qq.com,跪求
看看自己有多多多多多多多多多多多多多多少钱
为了大家以后方便下载,特意改成免费,祝大家赶快学习好嵌入式系统
