[开发工具] STM32官方的ETHERCAT开发板2
1109|15
 楼主| wangjiahao88 发表于 2021-10-12 09:19 | 显示全部楼层 |阅读模式
 楼主| wangjiahao88 发表于 2021-10-12 09:20 | 显示全部楼层
The STEVAL-ETH001V1 has been developed for motor control applications and multi-axial position control in
factory automation applications.
The board is characterized by a 6-layer stack structure for a better noise immunity and features:
Ethernet real-time communication with on-board EtherCAT protocol
Three-phase motor driver inverter based on STDRIVE101 gate driver and STH270N8F7-2 power MOSFET
STM32F767ZI microcontroller Arm®32-bit Cortex®-M7
NETX90 network controller
Operating supply voltage up to 48 V with a max. overvoltage robustness of 60 V
Max. power dissipation up to 700 W
Motor brake dissipative energy circuit
Digital actuation section for industrial loads
RS485 interface for digital encoder and host interface
On-board DC-DC converter and linear regulator
The STEVAL-ETH001V1 has a compact form factor to facilitate engine assembly. The board structure can be
schematized as shown below.
 楼主| wangjiahao88 发表于 2021-10-12 09:21 | 显示全部楼层
 楼主| wangjiahao88 发表于 2021-10-12 09:24 | 显示全部楼层
 楼主| wangjiahao88 发表于 2021-10-12 09:25 | 显示全部楼层
 楼主| wangjiahao88 发表于 2021-10-12 09:26 | 显示全部楼层
 楼主| wangjiahao88 发表于 2021-10-12 09:27 | 显示全部楼层
 楼主| wangjiahao88 发表于 2021-10-12 09:28 | 显示全部楼层
PDF文件
um2807-getting-started-with-the-low-voltage-servo-drive-for-multiaxial-position-.pdf
3.58 MB, 下载次数: 5
 楼主| wangjiahao88 发表于 2021-10-12 09:29 | 显示全部楼层
原理图文件
Parameter-Dictionary-man-1.pdf
1.39 MB, 下载次数: 4
paotangsan 发表于 2021-11-3 13:55 | 显示全部楼层
看着功能很多啊
renzheshengui 发表于 2021-11-3 14:04 | 显示全部楼层
相关资料还挺齐全
wakayi 发表于 2021-11-3 14:07 | 显示全部楼层
可以跑系统吗
tpgf 发表于 2021-11-3 14:08 | 显示全部楼层
呵呵呵有官方例程吗
wowu 发表于 2021-11-3 14:25 | 显示全部楼层
这个好调试吗
xiaoqizi 发表于 2021-11-3 14:29 | 显示全部楼层
有配备的代码吗
xiaoqizi 发表于 2021-11-3 14:30 | 显示全部楼层
官网的资料多不多
