我这个程序用单片机数码管显示相关内容 反映很慢
1070|3
kbkbk|  楼主 | 2022-3-6 17:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "reg52.h"
#include "HX711.h"
#include "uart.h"
#include "LCD1602.h"
#include "temp.h"
typedef unsigned char u8;
typedef unsigned int u16;
u16 KEY_NUM=0;
unsigned long HX711_Buffer=0;
unsigned long Weight_Maopi=0;Weight_Shiwu=0;
bit Flag_OK=0;
sbit key_stop = P3^0;
sbit key_star = P3^1;
sbit key_fen = P3^2;
sbit key_shi = P3^3;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
u8 DisplayDataTemp[8];
u8 DisplayWeight[8];
u8 DisplayData[8];
u8 code smgduan[11]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x67,0x6f};
u8 miao=0;
u8 fen=0;
u8 shi=0;
u8 miao_L,miao_H,fen_L,fen_H,shi_L,shi_H;
u8 State=1;
u16 counter=0;
void delay(u16 x){  //ÑÓʱº¯Êý
        while(x--)
}//delay
void Delay_ms(u16 n)
        u16 i,j;
        for(i=0;i<n;i++)
                for(j=0;j<123;j++);
void key_delay(int xms){  //¡ã¡ä?¨¹?¨®¨º¡Ào¡¥¨ºy x ms
        u16 i, j;
        for(i=0; i<xms; ++i)
                for(j=0; j<110; ++j)
}//key_delay
void T0_Init(){  //¶¨Ê±Æ÷³õʼ»¯
        TMOD = 0x01;
        TH0 = 0x3c;
        TL0 = 0xb0;
    EA = 1;  //¿ª×ÜÖжÏ
        ET0 = 1;
        TR0 = 1;
}//T0_Init
void dataprosTemp(int temp)
           float tp;
        if(temp< 0)                                //µ±Î¶ÈֵΪ¸ºÊý
                DisplayDataTemp[0] = 0x40;           //   -
                //ÒòΪ¶ÁÈ¡µÄζÈÊÇʵ¼ÊζȵIJ¹Â룬ËùÒÔ¼õ1£¬ÔÙÈ¡·´Çó³öÔ­Âë
                temp=temp-1;
                temp=~temp;
                tp=temp;
                temp=tp*0.0625*100+0.5;
                //ÁôÁ½¸öСÊýµã¾Í*100£¬+0.5ÊÇËÄÉáÎåÈ룬ÒòΪCÓïÑÔ¸¡µãÊýת»»ÎªÕûÐ͵Äʱºò°ÑСÊýµã
                //ºóÃæµÄÊý×Ô¶¯È¥µô£¬²»¹ÜÊÇ·ñ´óÓÚ0.5£¬¶ø+0.5Ö®ºó´óÓÚ0.5µÄ¾ÍÊǽø1ÁË£¬Ð¡ÓÚ0.5µÄ¾Í
                //Ëã¼ÓÉÏ0.5£¬»¹ÊÇÔÚСÊýµãºóÃæ¡£
        else
                DisplayDataTemp[0] = 0x00;
                tp=temp;//ÒòΪÊý¾Ý´¦ÀíÓÐСÊýµãËùÒÔ½«Î¶ȸ³¸øÒ»¸ö¸¡µãÐͱäÁ¿
                //Èç¹ûζÈÊÇÕýµÄÄÇô£¬ÄÇôÕýÊýµÄÔ­Âë¾ÍÊDz¹ÂëËü±¾Éí
        DisplayDataTemp[1] = smgduan[temp / 10000];
        DisplayDataTemp[2] = smgduan[temp % 10000 / 1000];
        DisplayDataTemp[3] = smgduan[temp % 1000 / 100] | 0x80;
        DisplayDataTemp[4] = smgduan[temp % 100 / 10];
        DisplayDataTemp[5] = smgduan[temp % 10];
void datapros()
        DisplayData[0] = smgduan[miao_L];
        DisplayData[1] = smgduan[miao_H];
        DisplayData[2] = 0x40;
        DisplayData[3] = smgduan[fen_L];
        DisplayData[4] = smgduan[fen_H];
        DisplayData[5] = 0x40;
        DisplayData[6] = smgduan[shi_L];
        DisplayData[7] = smgduan[shi_H];
void DigDisplayTemp()
        u8 j;
        for(j=0;j<6;j++)
                switch(j)         //λѡ£¬Ñ¡ÔñµãÁÁµÄÊýÂë¹Ü£¬
                        case(0):
                                LSA=0;LSB=0;LSC=0; break;//ÏÔʾµÚ0λ
                        case(1):
                                LSA=1;LSB=0;LSC=0; break;//ÏÔʾµÚ1λ
                        case(2):
                                LSA=0;LSB=1;LSC=0; break;//ÏÔʾµÚ2λ
                        case(3):
                                LSA=1;LSB=1;LSC=0; break;//ÏÔʾµÚ3λ
                        case(4):
                                LSA=0;LSB=0;LSC=1; break;//ÏÔʾµÚ4λ
                        case(5):
                                LSA=1;LSB=0;LSC=1; break;//ÏÔʾµÚ5λ
                P0=DisplayDataTemp[5-j];//·¢ËÍÊý¾Ý
                delay(100); //¼ä¸ôÒ»¶Îʱ¼äɨÃè
                P0=0x00;//ÏûÒþ
void DigDisplay()
        u8 i;
        for(i=0;i<8;i++)
                switch(i)
                        case(0):
                        case(1):
                        case(2):
                        case(3):
                        case(4):
                        case(5):
                        case(6):
                                LSA=0;LSB=1;LSC=1; break;
                        case(7):
                                LSA=1;LSB=1;LSC=1; break;
                P0=DisplayData[i];
                delay(50);
                P0=0x00;
void keyscan(){  //°´¼üº¯Êý
        if(key_stop == 0){
                key_delay(20);
                if(key_stop == 0){
                        EA = ~EA;  //¹Ø×ÜÖжϣ¬¼´Í£Ö¹
                        while(!key_stop);
        }//key_stop
        if(key_star == 0){
                key_delay(20);
                if(key_star == 0){
                        State = State+1;
                        if(State==4)
                                State=1;
                        }                        //¿ª×ÜÖжÏ
                        while(!key_star);
        }//key_star
        if(key_fen == 0){
                key_delay(20);
                if(key_fen == 0){
                        fen++;
                        while(!key_fen);
        }//key_fen++
        if(key_shi == 0){
                key_delay(20);
                if(key_shi == 0){
                        shi++;
                        while(!key_shi);
        }//key_shi++
void dataweight()
        DisplayWeight[1]=smgduan[Weight_Shiwu/1000];
        DisplayWeight[2]=smgduan[Weight_Shiwu%1000/100];
        DisplayWeight[3]=smgduan[Weight_Shiwu%100/10];
        DisplayWeight[4]=smgduan[Weight_Shiwu%10];
        DisplayWeight[5]=0x6f;
void DigDisplayWeight()
        u8 j;
        for(j=0;j<6;j++)
                        case(0):
                        case(1):
                        case(2):
                        case(3):
                        case(4):
                        case(5):
                P0=DisplayWeight[5-j];//·¢ËÍÊý¾Ý
                delay(50); //¼ä¸ôÒ»¶Îʱ¼äɨÃè
                P0=0x00;//ÏûÒþ
void Get_Weight()
        HX711_Buffer=HX711_Read();
        HX711_Buffer=HX711_Buffer/100;
        if(HX711_Buffer>Weight_Maopi)
          Weight_Shiwu=HX711_Buffer;
          Weight_Shiwu=Weight_Shiwu - Weight_Maopi;
                Weight_Shiwu=(unsigned int)((float)Weight_Shiwu/4.40+0.05);
void Get_Maopi()
        Weight_Maopi=HX711_Buffer/100;
void main()
        char k=10;
        T0_Init();
        Send_Word("Welcome to use!\n");
        Send_Word("Made by CZQ Group!\n");
  Delay_ms(800);//ÑÓʱ0.8Ãë
        Get_Maopi();
        Delay_ms(1000);//ÑÓʱ1s
//        LcdWriteCom(0x80+0x40+6);
//        LcdWriteData(0x5c); ½ðÇ®·ûºÅ
//        LcdWriteCom(0x80+0x40+15);
          Get_Maopi();
        while(1)
                keyscan();
                dataprosTemp(Ds18b20ReadTemp());
                k--;
                if( Flag_OK==0)
                         if(k==0)
                                 Get_Weight();
                                 k--;
                         if(k<0)
                                 k=10;
                         Send_ASCII(Weight_Shiwu/1000+0x30);
                         Send_ASCII(".");
                         Send_ASCII(Weight_Shiwu%1000/100+0x30);
                         Send_ASCII(Weight_Shiwu%100/10+0x30);
                         Send_ASCII(Weight_Shiwu%10+0x30);
                         Send_Word(" kg  \n");
                if(State==3)
                  dataweight();
                  DigDisplayWeight();
                if(State==1)
                        DigDisplay();
                        datapros();
                if(State==2)
                        DigDisplayTemp();
void timer0_Init() interrupt 1{  //ÖжϺ¯Êý
         counter++;
         if(counter == 20){
                 counter = 0;
                 miao++;        //i = 100
                if(miao == 60){
                        miao = 0;
                        fen++;
                        if(fen == 60){
                                fen = 0;
                                shi++;
                                if(shi == 24){
                                        shi = 0;
                                        fen = 0;
                                        miao = 0;
                miao_L = miao%10;
                miao_H = miao/10;
                fen_L = fen%10;
                fen_H = fen/10;
                shi_L = shi%10;
                shi_H = shi/10;
}//timer0_Init
gx_huang| | 2022-3-6 19:53 | 只看该作者
浏览器提示是否需要越南语翻译
速度慢,肯定是架构不对,软件死延时等待。
xch| | 2022-3-7 09:29 | 只看该作者
把MCU 资源都耗在delay上了,难道mcu是体制内的?
海洋无限| | 2022-3-7 12:18 | 只看该作者
延时太多了
