[技术问答] 【MA35D1】如何修改配置让MT29F8G08ABACA NAND可以正常启动
792|10
 楼主| 麻花油条 发表于 2023-1-20 11:26 | 显示全部楼层 |阅读模式
nand flash 8G, page size 4K , 64pages/block, block size 256Kbytes
1、NuWriter:
header-nand.json:
    "header":
        "version": "0x20210119",
        "spiinfo":
            "pagesize": "4096",
            "sparearea": "224",
            "pageperblk": "64",
            "quadread": "0x6B",
            "readsts": "0x05",
            "writests": "0x01",
            "stsvalue": "0x02",
            "dummy1": "0",
            "dummy2": "1",
            "suspintvl": "1"
        "secureboot": "no",
        "entrypoint": "0x28000000",
        "aeskey" : "5E76953BF598581F925B7995157844747FABE669ABF000345E0EE21B63624D59",
        "ecdsakey": "5E76953BF598581F925B7995157844747FABE669ABF000345E0EE21B63624D59",
        "image":
              "offset": "0x300000",
              "loadaddr": "0x28023000",
              "type": "3",
              "file": "bl2.dtb"
              "offset": "0x380000",
              "loadaddr": "0x28000000",
              "type": "4",
              "file": "bl2.bin"
pack-nand.json:
    "image":
          "offset": "0x000000",
          "file": "header.bin",
          "type": 1
          "file": "bl2.dtb",
          "type": 0
          "file": "bl2.bin",
          "type": 0
          "offset": "0x400000",
          "file": "fip.bin-nand",
          "type": 1
          "offset": "0x600000",
          "file": "uboot-env.bin-nand",
          "type": 1
          "offset": "0x700000",
          "file": "Image.dtb",
          "type": 1
          "offset": "0x800000",
          "file": "Image",
          "type": 1
          "offset": "0x1C00000",
          "file": "rootfs.ubi",
          "type": 1
2、TFA:
ma35d1.dtsi:
        nand: nand@401A0000 {
                compatible = "nuvoton,ma35d1-nand";
                nand-on-flash-bbt;
                /* nand information */
                nand-ecc-strength = <8>;
                nand-ecc-step-size = <512>;
                nand-page-size = <4096>;
                nand-oob-size = <224>;
                nand-page-count = <64>;
                nand-block-count = <4096>;
                nand-image-offset = <0x400000>;
3、uboot:
CONFIG_NAND_BOOT=y
CONFIG_ENV_SIZE=0x100000
CONFIG_ENV_OFFSET=0x600000
CONFIG_MTDPARTS_DEFAULT="mtdparts=nand0:6m(uboot),1m(uboot-env),1m(device-tree),20m(kernel),100m(rootfs)"
4、Linux:
ma35d1.dtsi:
                nand-on-flash-bbt;
                partitions {
                        compatible = "fixed-partitions";
                        #address-cells = <1>;
                        #size-cells = <1>;
                        uboot@0 {
                                label = "nand-uboot";
                                reg = <0x0000000 0x600000>;
                                read-only;
                        uboot-env@600000 {
                                label = "nand-uboot-env";
                                reg = <0x600000 0x100000>;
                        device-tree@700000 {
                                label = "nand-device-tree";
                                reg = <0x700000 0x100000>;
                        kernel@800000 {
                                label = "nand-kernel";
                                reg = <0x800000 0x1400000>;
                        rootfs@1C00000 {
                                label = "nand-rootfs";
                                reg = <0x1C00000 0x6400000>;
5、Rootfs:
BR2_TARGET_ROOTFS_UBI_PEBSIZE=0x40000
BR2_TARGET_ROOTFS_UBI_SUBSIZE=4096
BR2_TARGET_ROOTFS_UBIFS_LEBSIZE=0x3E000
BR2_TARGET_ROOTFS_UBIFS_MINIOSIZE=0x1000
BR2_TARGET_ROOTFS_UBIFS_MAXLEBCNT=400
Candic12e 发表于 2023-5-19 14:06 | 显示全部楼层
确定固件程序配置
Charlene沙 发表于 2023-5-19 15:10 | 显示全部楼层
在升级固件程序之前备份代码
Estelle1999 发表于 2023-5-19 16:15 | 显示全部楼层
肯定得兼容才能让其正常启动
Emily999 发表于 2023-5-19 17:18 | 显示全部楼层
你是换nand的芯片型号了?
Carina卡 发表于 2023-5-19 18:20 | 显示全部楼层
估计你需要修改底层的函数才能实现了吧
Charlotte夏 发表于 2023-5-19 19:27 | 显示全部楼层
话说MA35D1是啥芯片啊?能驱动MT29F8G08ABACA NAND?
Betty1299 发表于 2023-5-20 07:09 | 显示全部楼层
你找个技术支持吧,能快速点的帮你解决
Alina艾 发表于 2023-5-20 08:15 | 显示全部楼层
启动不了提示什么啊?
Betty996 发表于 2023-5-20 10:18 | 显示全部楼层
你用逻辑分析仪,抓一下时序试试吧
alxd 发表于 2023-5-20 12:40 | 显示全部楼层
这个不好查,你看原来用的是那款nand芯片,你换成这个试试
