PROGRAM Main
USE, INTRINSIC :: ISO_C_BINDING, ONLY: &
C_F_PROCPOINTER, C_FUNPTR, C_INTPTR_T, &
C_NULL_CHAR, C_CHAR, C_ASSOCIATED, C_DOUBLE, C_INT, C_LONG
IMPLICIT NONE
INTERFACE
FUNCTION LoadLibrary(lpFileName) BIND(C,NAME='LoadLibraryA')
USE, INTRINSIC :: ISO_C_BINDING, ONLY: C_INTPTR_T, C_CHAR
IMPLICIT NONE
CHARACTER(KIND=C_CHAR) :: lpFileName(*)
!GCC$ ATTRIBUTES STDCALL :: LoadLibrary
INTEGER(C_INTPTR_T) :: LoadLibrary
END FUNCTION LoadLibrary
FUNCTION GetProcAddress(hModule, lpProcName) &
BIND(C, NAME='GetProcAddress')
C_FUNPTR, C_INTPTR_T, C_CHAR
IMPLICIT NONE
!GCC$ ATTRIBUTES STDCALL :: GetProcAddress
TYPE(C_FUNPTR) :: GetProcAddress
INTEGER(C_INTPTR_T), VALUE :: hModule
CHARACTER(C_CHAR) :: lpProcName(*)
END FUNCTION GetProcAddress
END INTERFACE
INTERFACE
function PEA256Init() Bind(C, name="PEA256Init")
logical(C_BOOL) :: PEA256Init
end function PEA256Init
function PEA256Open() Bind(C, name="PEA256Open")
INTEGER(C_INTPTR_T) :: PEA256Open
end function PEA256Open
SUBROUTINE PEA256Close(handle) Bind(C, name="PEA256Close")
INTEGER(C_INTPTR_T), intent(in), VALUE :: handle
end SUBROUTINE PEA256Close
function PEA256EncryptUserKey(handle, keystr, keybuff, keyfile) Bind(C, name="PEA256EncryptUserKey")
character(C_CHAR), intent(in)::keystr(*)
character(C_CHAR), intent(in)::keybuff(*)
character(C_CHAR), intent(in)::keyfile(*)
INTEGER(kind=4) :: PEA256EncryptUserKey
end function PEA256EncryptUserKey
function PEA256DecryptUserKey(handle, keystr, keybuff, keyfile) Bind(C, name="PEA256DecryptUserKey")
INTEGER(kind=4) :: PEA256DecryptUserKey
end function PEA256DecryptUserKey
function PEA256EncryptBytes(handle, bytes, len, subkey) Bind(C, name="PEA256EncryptBytes")
character(C_CHAR), intent(inout)::bytes(*)
INTEGER(kind=4), intent(in), VALUE::len
INTEGER(kind=4), intent(in), VALUE::subkey
INTEGER(kind=4) :: PEA256EncryptBytes
end function PEA256EncryptBytes
function PEA256DecryptBytes(handle, bytes, len, subkey) Bind(C, name="PEA256DecryptBytes")
INTEGER(kind=4) :: PEA256DecryptBytes
end function PEA256DecryptBytes
function PEA256EncryptBytesEx(handle, inbytes, outbytes, len, subkey) Bind(C, name="PEA256EncryptBytesEx")
character(C_CHAR), intent(in)::inbytes(*)
character(C_CHAR), intent(out)::outbytes(*)
INTEGER(kind=4) :: PEA256EncryptBytesEx
end function PEA256EncryptBytesEx
function PEA256DecryptBytesEx(handle, inbytes, outbytes, len, subkey) Bind(C, name="PEA256DecryptBytesEx")
INTEGER(kind=4) :: PEA256DecryptBytesEx
end function PEA256DecryptBytesEx
function PEA256EncryptArrayEx(handle, inbytes, outbytes, index, len, subkey) Bind(C, name="PEA256EncryptArrayEx")
INTEGER(kind=4), intent(in), VALUE::index
INTEGER(kind=4) :: PEA256EncryptArrayEx
end function PEA256EncryptArrayEx
function PEA256DecryptArrayEx(handle, inbytes, outbytes, index, len, subkey) Bind(C, name="PEA256DecryptArrayEx")
INTEGER(kind=4) :: PEA256DecryptArrayEx
end function PEA256DecryptArrayEx
function PEA256Test() Bind(C, name="PEA256Test")
logical(C_BOOL):: PEA256Test
end function PEA256Test
END INTERFACE
INTEGER(C_INTPTR_T) :: hInstLibrary
INTEGER(C_INTPTR_T) :: handle
INTEGER(kind=4) :: subkey
INTEGER :: i
character(C_CHAR), dimension(0:3) :: ArrayByte
character(C_CHAR), dimension(0:3) :: ArrayEncrypt
character(C_CHAR), dimension(0:3) :: ArrayDecrypt
TYPE(C_FUNPTR) :: fnPEA256Init
PROCEDURE(PEA256Init), BIND(C), POINTER :: fpPEA256Init
TYPE(C_FUNPTR) :: fnPEA256Open
PROCEDURE(PEA256Open), BIND(C), POINTER :: fpPEA256Open
TYPE(C_FUNPTR) :: fnPEA256Close
PROCEDURE(PEA256Close), BIND(C), POINTER :: fpPEA256Close
TYPE(C_FUNPTR) :: fnPEA256EncryptUserKey
PROCEDURE(PEA256EncryptUserKey), BIND(C), POINTER :: fpPEA256EncryptUserKey
TYPE(C_FUNPTR) :: fnPEA256DecryptUserKey
PROCEDURE(PEA256DecryptUserKey), BIND(C), POINTER :: fpPEA256DecryptUserKey
TYPE(C_FUNPTR) :: fnPEA256EncryptBytes
PROCEDURE(PEA256EncryptBytes), BIND(C), POINTER :: fpPEA256EncryptBytes
TYPE(C_FUNPTR) :: fnPEA256DecryptBytes
PROCEDURE(PEA256DecryptBytes), BIND(C), POINTER :: fpPEA256DecryptBytes
TYPE(C_FUNPTR) :: fnPEA256EncryptBytesEx
PROCEDURE(PEA256EncryptBytesEx), BIND(C), POINTER :: fpPEA256EncryptBytesEx
TYPE(C_FUNPTR) :: fnPEA256DecryptBytesEx
PROCEDURE(PEA256DecryptBytesEx), BIND(C), POINTER :: fpPEA256DecryptBytesEx
TYPE(C_FUNPTR) :: fnPEA256EncryptArrayEx
PROCEDURE(PEA256EncryptArrayEx), BIND(C), POINTER :: fpPEA256EncryptArrayEx
TYPE(C_FUNPTR) :: fnPEA256DecryptArrayEx
PROCEDURE(PEA256DecryptArrayEx), BIND(C), POINTER :: fpPEA256DecryptArrayEx
TYPE(C_FUNPTR) :: fnPEA256Test
PROCEDURE(PEA256Test), BIND(C), POINTER :: fpPEA256Test
hInstLibrary = LoadLibrary(trim('D:\\libpea256x64\\libpea256x64.dll') // C_NULL_CHAR)
IF (hInstLibrary == 0) STOP 'Unable to load DLL'
fnPEA256Init = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256Init' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256Init)) &
STOP 'Unable to obtain procedure address'
CALL C_F_PROCPOINTER(fnPEA256Init, fpPEA256Init)
print*, fpPEA256Init()
fnPEA256Test = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256Test' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256Test)) &
CALL C_F_PROCPOINTER(fnPEA256Test, fpPEA256Test)
print*, fpPEA256Test()
fnPEA256Open = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256Open' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256Open)) &
CALL C_F_PROCPOINTER(fnPEA256Open, fpPEA256Open)
fnPEA256Close = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256Close' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256Close)) &
CALL C_F_PROCPOINTER(fnPEA256Close, fpPEA256Close)
fnPEA256EncryptUserKey = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256EncryptUserKey' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256EncryptUserKey)) &
CALL C_F_PROCPOINTER(fnPEA256EncryptUserKey, fpPEA256EncryptUserKey)
fnPEA256DecryptUserKey = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256DecryptUserKey' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256DecryptUserKey)) &
CALL C_F_PROCPOINTER(fnPEA256DecryptUserKey, fpPEA256DecryptUserKey)
fnPEA256EncryptBytes = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256EncryptBytes' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256EncryptBytes)) &
CALL C_F_PROCPOINTER(fnPEA256EncryptBytes, fpPEA256EncryptBytes)
fnPEA256DecryptBytes = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256DecryptBytes' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256DecryptBytes)) &
CALL C_F_PROCPOINTER(fnPEA256DecryptBytes, fpPEA256DecryptBytes)
fnPEA256EncryptBytesEx = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256EncryptBytesEx' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256EncryptBytesEx)) &
CALL C_F_PROCPOINTER(fnPEA256EncryptBytesEx, fpPEA256EncryptBytesEx)
fnPEA256DecryptBytesEx = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256DecryptBytesEx' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256DecryptBytesEx)) &
CALL C_F_PROCPOINTER(fnPEA256DecryptBytesEx, fpPEA256DecryptBytesEx)
fnPEA256DecryptArrayEx = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256DecryptArrayEx' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256DecryptArrayEx)) &
CALL C_F_PROCPOINTER(fnPEA256DecryptArrayEx, fpPEA256DecryptArrayEx)
fnPEA256EncryptArrayEx = GetProcAddress(hInstLibrary, &
C_CHAR_'PEA256EncryptArrayEx' // C_NULL_CHAR)
IF (.NOT. C_ASSOCIATED(fnPEA256EncryptArrayEx)) &
CALL C_F_PROCPOINTER(fnPEA256EncryptArrayEx, fpPEA256EncryptArrayEx)
handle = fpPEA256Open()
if (handle > 0) then
do i = 0, 3
ArrayByte(i) = char(i)
ArrayEncrypt(i) = char(i)
end do
print*, ""
subkey = fpPEA256EncryptUserKey(handle, "123" // C_NULL_CHAR, "" // C_NULL_CHAR, "" // C_NULL_CHAR)
write (*,"(Z8.8)") subkey
subkey = fpPEA256EncryptBytes(handle, ArrayByte, 4, subkey)
do i = 0, 3
write (*,"( Z2.2$)") ichar(ArrayByte(i))
end do
print*, ""
subkey = fpPEA256DecryptUserKey(handle, "123" // C_NULL_CHAR, "" // C_NULL_CHAR, "" // C_NULL_CHAR)
subkey = fpPEA256DecryptBytes(handle, ArrayByte, 4, subkey)
do i = 0, 3
write (*,"(Z2.2$)") ichar(ArrayByte(i))
end do
print*, ""
subkey = fpPEA256EncryptUserKey(handle, "" // C_NULL_CHAR, "0123456789ABCDEF0123456789ABCDEF" &
subkey = fpPEA256EncryptBytesEx(handle, ArrayEncrypt, ArrayDecrypt, 4, subkey)
do i = 0, 3
write (*,"( Z2.2$)") ichar(ArrayDecrypt(i))
end do
print*, ""
subkey = fpPEA256DecryptUserKey(handle, "" // C_NULL_CHAR, "0123456789ABCDEF0123456789ABCDEF" &
subkey = fpPEA256DecryptBytesEx(handle, ArrayDecrypt, ArrayEncrypt, 4, subkey)
do i = 0, 3
write (*,"(Z2.2$)") ichar(ArrayEncrypt(i))
end do
print*, ""
subkey = fpPEA256EncryptUserKey(handle, "" // C_NULL_CHAR, "" &
// C_NULL_CHAR, "123.PEA.KEY" // C_NULL_CHAR)
subkey = fpPEA256EncryptArrayEx(handle, ArrayEncrypt, ArrayDecrypt, 0, 4, subkey)
do i = 0, 3
end do
print*, ""
subkey = fpPEA256DecryptUserKey(handle, "" // C_NULL_CHAR, "" &
subkey = fpPEA256DecryptArrayEx(handle, ArrayDecrypt, ArrayEncrypt, 0, 4, subkey)
do i = 0, 3
end do
print*, ""
call fpPEA256Close(handle)
end if
print*, "PEA256COM!!!"
END PROGRAM Main
