[应用相关] stm32 PWM捕获学习
962|3
 楼主| laocuo1142 发表于 2024-10-16 10:33 | 显示全部楼层 |阅读模式
发现官方有个例子,固件库里面自带PWM输入功能,经调试稳定可用,代码如下:
C代码  [url=][/url]
//计时器和gpio口的初始化
  NVIC_InitTypeDef NVIC_InitStructure;
  /* TIM2 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* GPIOB clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  /* TIM2 chennel2 configuration : PA.01 */
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP ;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Connect TIM pin to AF1 */
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_1);
  /* Enable the TIM2 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
    TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0x0;
  TIM_PWMIConfig(TIM2, &TIM_ICInitStructure);
  /* Select the TIM2 Input Trigger: TI2FP2 */
  TIM_SelectInputTrigger(TIM2, TIM_TS_TI2FP2);
  /* Select the slave Mode: Reset Mode */
  TIM_SelectSlaveMode(TIM2, TIM_SlaveMode_Reset);
  TIM_SelectMasterSlaveMode(TIM2,TIM_MasterSlaveMode_Enable);
  /* TIM enable counter */
  TIM_Cmd(TIM2, ENABLE);
  /* Enable the CC2 Interrupt Request */
   TIM_ITConfig(TIM2, TIM_IT_CC2, ENABLE);
相关中断函数如下:
C代码  [url=]
[/url]
void TIM2_IRQHandler(void)
  RCC_GetClocksFreq(&RCC_Clocks);
  /* Clear TIM2 Capture compare interrupt pending bit */
  TIM_ClearITPendingBit(TIM2, TIM_IT_CC2);
  /* Get the Input Capture value */
  IC2Value = TIM_GetCapture2(TIM2);
  if (IC2Value != 0)
    /* Duty cycle computation */
    DutyCycle = (TIM_GetCapture1(TIM2) * 100) / IC2Value;
    /* Frequency computation
       TIM2 counter clock = (RCC_Clocks.HCLK_Frequency)/2 */
    Frequency = RCC_Clocks.HCLK_Frequency / IC2Value;
  else
    DutyCycle = 0;
    Frequency = 0;
这个方法经测试,是简单好用的,但根据资料表明这个是通道1和通道2配合实现,其他资料也没有说明如何捕获多个通道,是否能用3和4通道配合捕获,是否1个定时器能捕获2个通道。于是网上查到另一种方法可以1个定时器捕获4个通道,但是待测试,记录如下:
C代码  [url=]
[/url]
// STM32 TIM2 4 Channel Input Capture STM32F0-Discovery - sourcer32@gmail.com
#include "stm32f0xx.h"
#include "stm32f0_discovery.h"
void TIM2_Config(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_ICInitTypeDef        TIM_ICInitStructure;
  /* TIM2 Periph clock enable */
  /* TIM2 Configuration */
  TIM_DeInit(TIM2);
  /* Time base configuration */
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Prescaler = (SystemCoreClock / 1000000) - 1; // 1 MHz, from 48 MHz
  TIM_TimeBaseStructure.TIM_Period = 0xFFFFFFFF; // Maximal, TIM2 is 32-bit counter
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; // Rising/Falling/BothEdge
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
  TIM_ICInit(TIM2, &TIM_ICInitStructure);
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_3;
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_4;
  /* TIM1 enable counter */
  /* Enable the CCx Interrupt Request */
  TIM_ITConfig(TIM2, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3 | TIM_IT_CC4, ENABLE);
volatile uint32_t Freq[4];
    uint32_t Current, Delta;
    static uint32_t Last[4];
  if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
        /* Clear TIM2_CH1 Capture compare interrupt pending bit */
        TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
        Current = TIM_GetCapture1(TIM2);
        Delta = Current - Last[0];
        Last[0] = Current;
        if (Delta)
            Freq[0] = 1000000 / Delta; // 1MHz clock
  if (TIM_GetITStatus(TIM2, TIM_IT_CC2) != RESET)
        /* Clear TIM2_CH2 Capture compare interrupt pending bit */
        Current = TIM_GetCapture2(TIM2);
        Delta = Current - Last[1];
        Last[1] = Current;
        if (Delta)
            Freq[1] = 1000000 / Delta; // 1MHz clock
  if (TIM_GetITStatus(TIM2, TIM_IT_CC3) != RESET)
        /* Clear TIM2_CH3 Capture compare interrupt pending bit */
        TIM_ClearITPendingBit(TIM2, TIM_IT_CC3);
        Current = TIM_GetCapture3(TIM2);
        Delta = Current - Last[2];
        Last[2] = Current;
        if (Delta)
            Freq[2] = 1000000 / Delta; // 1MHz clock
  if (TIM_GetITStatus(TIM2, TIM_IT_CC4) != RESET)
        /* Clear TIM2_CH4 Capture compare interrupt pending bit */
        TIM_ClearITPendingBit(TIM2, TIM_IT_CC4);
        Current = TIM_GetCapture4(TIM2);
        Delta = Current - Last[3];
        Last[3] = Current;
        if (Delta)
            Freq[3] = 1000000 / Delta; // 1MHz clock
void NVIC_Config(void)
  /* Enable and set TIM2 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0x00;
void GPIO_Config(void)
  /* GPIOA Periph clock enable */
  /* Configure TIM2 input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  /* Connect TIM pins to AF2 */
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_2); // TIM2_CH1 PA5
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_2); // TIM2_CH2 PA1
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_2); // TIM2_CH3 PA2
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_2); // TIM2_CH4 PA3
int main(void)
  NVIC_Config();
  GPIO_Config();
  TIM2_Config();
  while(1); /* Infinite loop */
 楼主| laocuo1142 发表于 2024-10-16 10:34 | 显示全部楼层
还有另外一种方法待测试:
C代码  [url=]
[/url]
// Hold onto the Channel 1 init structure -- we will use it to reverse
// polarity on every edge interrupt.
static TIM_ICInitTypeDef TIM_CH1_ICInitStructure;
#define GPIO_AF_TIM2 GPIO_AF_2
void ConfigPwmIn() {
TIM_DeInit(TIM2 );
/* GPIOC clock enable */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOD, ENABLE);
/* TIM2 GPIO pin configuration : CH1=PD3, C2=PD4, CH3=PD7, CH4=PD6 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_7 | GPIO_Pin_6;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
/* Connect pins to TIM3 AF2 */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource3, GPIO_AF_TIM2 );
GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_TIM2 );
GPIO_PinAFConfig(GPIOD, GPIO_PinSource7, GPIO_AF_TIM2 );
GPIO_PinAFConfig(GPIOD, GPIO_PinSource6, GPIO_AF_TIM2 );
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
/* Enable capture*/
TIM_CH1_ICInitStructure.TIM_Channel = TIM_Channel_1;
TIM_CH1_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
TIM_CH1_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
TIM_CH1_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
TIM_CH1_ICInitStructure.TIM_ICFilter = 0;
TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
TIM_ICInitStructure.TIM_ICFilter = 0;
/* Enable TIM2 */
/* Enable CC1-4 interrupt */
/* Clear CC1 Flag*/
TIM_ClearFlag(TIM2, TIM_FLAG_CC1 | TIM_FLAG_CC2 | TIM_FLAG_CC3 | TIM_FLAG_CC4 );
static volatile uint32_t ccr[4];
static volatile char pulseState = 0;
void TIM2_IRQHandler() {
if (TIM2 ->SR & TIM_IT_CC1 ) {
  TIM2 ->SR &= (~TIM_IT_CC1 );
  if (pulseState == 0) {
   TIM_CH1_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
   // Any time we get a rising edge on CH1, we reset the counter. All channels are
   // phase aligned, so they all use this as a reference.
   TIM_SetCounter(TIM2, 0);
  } else {
   // Pull the value on the falling edge.
   ccr[0] = TIM_GetCapture1(TIM2 );
  pulseState = !pulseState;
  // Reverse polarity.
  TIM_ICInit(TIM2, &TIM_CH1_ICInitStructure);
if (TIM2 ->SR & TIM_IT_CC2 ) {
  TIM2 ->SR &= (~TIM_IT_CC2 );
  ccr[1] = TIM_GetCapture2(TIM2 );
if (TIM2 ->SR & TIM_IT_CC3 ) {
  TIM2 ->SR &= (~TIM_IT_CC3 );
  ccr[2] = TIM_GetCapture3(TIM2 );
if (TIM2 ->SR & TIM_IT_CC4 ) {
  TIM2 ->SR &= (~TIM_IT_CC4 );
  ccr[3] = TIM_GetCapture4(TIM2 );
